Question about Sony Playstation 3 (PS3) Console
Hdmi i've got a samsung hd tv and im having difficulties getting my ps3 to work with it via a hdmi cable, i dont know what resolution my tv is..pls help
  • 944 Answers
Which TV do you have? Hopefully then we can help. :)
Posted on Sep 01, 2007
SOURCE:
How do I get my PS3 to work over hdmi?
Try swapping out HDMI cable. The version of cable. (1.2, 1.4 etc ) might be too old/faulty for PS3.
If your Tv is HD ready and not Full HD lower the video quality in the PS3 settings
Aug 06, 2015 | Samsung LN-S3251D 32 in. LCD HDTV
Hi I've just got my son a relisys tv model
I thought they only made computer monitors, but you are right they make televisions as well.
relisys tv model Google Search
Apr 01, 2017 | Video Game Consoles & Games
Trying to use ps3, even after using hdmi cable on input 6 or 7, it says check your device output and i see green lines on my screen?
hi
There maybe some problem with your TVs resolution. ps3 outputs full hd high resolution video(1080p) through its HDMI. May be your TV is not supporting that resolution. Connect ps3's component video out to your TV's component video input and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution your TV will not support. Your tv is hd ready one, not full hd. ps3 's HDMI out is full hd (1080p).
or try this
Connect your ps3 to any full hd tv and then goto video setup of ps3. change resolution to 1080i (down scaling ). then connect to your TV via HDMI. surly u will get the video.
ok
Jun 09, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
Hi I have a 32 inch hd vizio tv and a ps3 system and I bought s Belkin hdmi audio and video cable and I'm trying to figure out how connect the cable to the tv and ps3 to get hd channels and hd games and...
Cable: First you need to be using an HD Cable box to get the HD channels that your provider offers. if you don't, you can't get HD channels. Keep in mind that not all of the channels that your provider offers are in HD. Out of the 300+ channels that my provider Cox Communications in Las Vegas offers, they offer 91 of them in HD. If you have an HD box, you need to go into the settings menu and make sure that your video output is set to constant as you do not want it bouncing between different resolutions when you change channels. In your case you will have two options, 720p and 1080i (1080p does not exist for cable due to the amount of bandwidth required). Choose 720p because your set is under 40" and you won't see a a difference between 720p and 1080i except for that because it's progressive, HD may actually look better. (NOTE: although your analog channels will display at 720p, they are not in HD. They are simply up converted SD so don't expect that they will look like HD channels.) Also be sure to set your audio settings on your box to "HDMI out."
In general, HDMI devices should automatically detect HDMI input but since I don't know what kind of box you are using, it is possible that HDMI-out is disabled in the settings. My box (Scientific Atlanta) doesn't have that option, but I don't know about others. As far as the set is concerned, plug the HDMI cable into the input you want to use (if it's a new Vizio, I'm assuming there are three inputs as that's what my 32" Vizio in the kids' room has) and the set will auto-detect the HDMI input and automatically set the resolution accordingly.
SIDE NOTE: The only other way you're going to get HD channels from cable without a box is if you're using your COAX cable directly in to the TV and that is only if your cable provider has them floating on the line and you're only going to get the 5 major networks and Univision in HD.
PS3: This is even easier. WIth your PS3 powered off and your TV powered on, connect one end of your HDMI cable to the HDMI out on the PS3 and the other end to the appropriate HDMI input on your TV (of your choosing). Power on your PS3. Your TV will automatically detect the HDMI input from the PS3 and put that HDMI input on the screen. You will get an on-screen message from the PS3 detecting HDMI and it will ask you if you want o use HDMI or words to that effect (I can't remember the exact message... it's been a while). Choose "yes" and it will adjust the picture accordingly and should automatically choose the highest video resolution your television can display. To verify your settings, first hit the "guide" button on your Vizio remote control and in the upper right corner it will tell you at exactly what resolution it is displaying at. If it's not where you want it to be, on your PS3, go the Settings Menu and scroll down to "Display Settings" and the first item on the list is "Video Output Settings." Follow the step by step on screen menu prompts to determine your display settings, and choose "automatic" when prompted. If everything is copasedic, the highest resolution your television can display at will be listed at the top (and will be the current setting) and all of the other resolutions will be listed below it. If something is wrong between the "handshake" between the HDMI from the PS3 to the TV and it doesn't display in HD, go back into Video Output Settings" and when prompted, choose manual in stead and set the resolution on the PS3 the highest your TV can display. NOTE: Most 32" TV's have a maximum resolution of 720p fir the reasons I stated earlier. Check your manual for the specifics on yours. Furthermore, all PS3 games are in 720p so even if you have a 1080p TV, don't expect higher resolutions than that. AS far as Netflix is concerned, not all of their programming is in HD. The scale for Netflix is SD/Low/Medium/High/X-High. HD/Low/Medium/High/X-High, your quality depends on the program and strength of your Internet connection.
Closing: I'm a little confused by your issue as HDMI is automatic and you should automatically be getting HD so the only other thing I can think of is that your display needs calibrating and you just think you aren't getting HD. In order to get the most out of your new TV and your PS3, I would highly recommend that you calibrate your set with a Blu-Ray calibration disc that comes with color filters. It will take you about an hour or so to get the hang of and use correctly but the results will be very noticeable. The presets that come out of the box and the settings that they use on the floor in the store are awful and you don't realize how much you've been missing in picture quality until you calibrate. Do not rent this disc from Netflix as it does not come eith the color filters. You can buy a calibration disc at Amazon. I got the DVE one, from what I understand, the Spears and Munsel one is very good as well.
http://www.amazon.com/s/ref=nb_sb_ss_i_0_24?url=search-alias%3Daps&field-keywords=blu-ray+calibration+disc&sprefix=blu-ray+calibration+disc
Apr 23, 2011 | Video Game Consoles & Games
I have a ps3 that i tried to hook up to our emmerson tv through an hdmi cable and the tv screen says format not supportedf why?
If you recently moved the PS3 from one tv to another, it's setup to work on that other tv.
Press and hold the power button on the PS3 until you hear a beep. This should default the video output to whatever is plugged in and the PS3 should output normally via the HDMI connection.
Mar 05, 2011 | Sony Playstation 3 (PS3) Console
Ps3 hdmi is saying format not supported on my 32"
hi
there maybe some problem with ur tvs resolution. ps3 outputs full hd high resolution video(1080p) through its hdmi. may be your tv is not supporting that resolution. connect ps3's component video out to ur tv and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution ur tv will not support. ur tv is hd ready one, not full hd. ps3 's hdmi out is full hd (1080p).
or try this
connect ur ps3 to any full hd tv and then goto video setup of ur ps3. change resolution to 1080i (down scaling ). then connect to ur tv via hdmi. surly u will get the video.
ok
Dec 14, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Resolution problems/ Game problems
Well it might be becuase your ps3 is european. Im no expert on the matter, but when i bought an hdmi cable and hooked it up to my hd compatible tv, i switched to the hd input (which happened to be input4 on my tv) and a message popped up saying that the ps3 has detected hd output, would you like to change settings? and it did it automatically after i hit yes.
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
Picture flashing
If it is an older "hd" tv it is probably 'hd ready.' Check for adjustments on your source. The tv will most likely only display the highest resolution it is given.
Dec 28, 2007 | Zenith C27V36 27" TV
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Sony Playstation 3 (PS3) Console Logo
69 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
