you don't need a signal booster. Instead what you need is a WIFI signal repeater. This device basically captures your router's signal and repeat it to other devices. Basically place is somewhere between the router and your computer.
There are many out there but here's a cheap one on ebay
The problem is with the speedo. The speedo has a "lean switch" that works in conjunction with the turn signal canceller. If the bike does not detect a "lean", the TSC will not cancel the turn signals Resolve the speedo problem and the turn signal problem will go away. As for what's causing the speedo problem, I have no idea other than maybe a loose connection. I've read a LOT of problems with the speedo not working on this forum but since I don't work the bikes built in 2000 and later, I'm afraid I have no experience with the problem and therefore cannot offer any advice.
The most common cause of an E20 error code would be a clogged or damaged drain pump. Other possible issues would be a loose wire to you pressure switch, loose wire at your control board, loose wire at your drian pump, or failed control board. This is not a specific error but from my experience the most likely cause of this issue would be a bad drain pump. Something is clogging the pump or the motor is bad.
from our experience rebuilding woofers once the lead wires get pulled too much or start to strain you have been running too much power into the woofer and making the cone move too far in and out.You need to cut the input signal from your preamp down and cut the volume down on the speaker input on you eon. We keep seeing too many of these amped speakers blown from too much signal.
hi there, im taking a shot in the dark look at the crank sensor at the crankshaft it might be damaged or loose connections this part control the timing for the computer and if it looses signal youll experience this type of problem good luck
judging from experience although with a sony ericsson, the usual diagnosis for that problem would be the earpiece of your d840. There simply could've been a loose connection with it.
