Question about Admiral AW22 Top Load Washer
WATER DRAINS WATER KEEPS RUNNING OUT THE DRAIN
  • Anonymous Mar 28, 2009
    Thank you for this! We had the same problem, and it WAS the drain pipe! Someone had CRAMMED it way down deep into the drain hole between the hot and cold spigots on the wall, so I pulled it up just a bit so that the hose was as tall as the washer, tried it again, and VOILA!
    Thanks so much for saving me hundreds on a service call!!!
    President:
  • 1,294 Answers
In your manual what does it say as to what height to fix the drain pipe. Try to maintain the height, approx 3 feet or so. The machine pumps the water out OVER the height..... The drain pipe shd not go straight into the drain at floor level.
Posted on Sep 01, 2007
Motor keeps running. Water heats fine. Help
One of the reasons for motor not draining during normal cycle is the check valve is stuck. It is meant to return to normal during drain cycle but close during wash. I think the cancel is resetting it and letting water out.
See this discussion.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/26-129-977852-/Bosch-Dishwasher-won-t-drain-SHE43RF2UC64
Apr 02, 2014 | Bosch 24-in Built-In Dishwasher Color:...
I have a WF328AAW washer and it drains yet the nd code appears after
Find the drain sensor, it will be somewhere low in the plumbing. Check to see if it is dirty, check it electrically, too.
Nov 24, 2013 | Samsung WF328AAW Front Load Washer
Admiral LNC6762B water keeps running when starting
try these one of the following is not operating properly.
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
  • Test the timer control
Oct 19, 2009 | Admiral AAV7000A
My washer will not fill. The water keeps running and it never fills and just drains out the drain tube.
Check and see if the height of your drain is right. Sometimes if the drain is too low, it will cause the water to just flow right out of the machine. Check out the attached photo. Hope this helps and best wishes.
Aug 02, 2009 | Washing Machines
My washer keeps on tripping my GFCI when running the drain cycle -- the basket spins, but water doesn't seem to be draining.
Sounds like ither the water syphon tube that drains the water is plugged causing the pump to work to hard or the pump is going bad. I have pulled a sock from a drain hose before. It is also not uncommon for a GFCI to go bad. Cheaper to replace than paying a plumber or service tech if you can do it yourself - or talk a neighbor or friend into replacing it for you.
Jul 04, 2009 | Roper RAS8445KQ Top Load Washer
Water will not stay filled in tub on rinse cycle
It sounds like a siphon issue.
Check that the drain hose does a high loop before it goes into the drain pipe. (ie. drain hose loops above the water level inside the tub). Make sure the drain hose is not pushed too far down into the drain pipe. Also if the drain hose is sealed to the drain pipe this will create an airlock and a siphon will occur, allow air to enter between drain hose and drain pipe connection.
This should help you but if there is still a problem let me know and I'll try to assist you further.
Mar 21, 2009 | Maytag Washing Machines
18 in dishwasher drains water during cycles
find out how the dishwasher is set up to drain. Pour water into dishwasher 4 or 5 gallons, see if water disappears. if so, your drain is ran wrong
Jan 05, 2008 | Kenmore 15121 Built-in Dishwasher
Admiral AW22 Top Load Washer Logo
122 people viewed this question
Top Admiral Washing Machines Experts
Sal De
jimorris77
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
