Question about Admiral AW22 Top Load Washer
WATER DRAINS CONSTANTLY - Admiral AW22 Top Load Washer
  • 291 Answers
Sounds like your water valve is bad... thats what you washer hose's are connected to on the washer
Posted on Sep 01, 2007
?my laundromaid constantly drains water out before it has finished washing. i have had it for the past 4 years and have never been serviced. what could be the problem
problem program board is the most .logical answer as it thinks that it should be in the spin cycle but it is still washing
Jul 15, 2016 | Washing Machines
Low water level
Try to unstick the float. The float tells the DW how much water is in it at any given time. It is shaped like a mushroom on the bottom of the DW basin. Gently pick it up and set it back down. Does it seem free? Try the cycle again.
Jan 10, 2014 | Samsung DMT400RHS Builtin Dishwasher
Water constantly drains into tub when not in use. Started off just a little bit now really leaking into tub. Any ideas?
check you drain line, make sure there is no siphoning. if there is none, then your water inlet valve could be malfunctioning.
Feb 12, 2011 | GE WBVH6240F Front Load Washer
Saniplus draining in pulses
When you flush the toilet, the Saniplus will turn on and off once or twice, this is normal. If it turns on 3 times or more then could be a problem with venting or the discharge pipe installation may not be properly installed. But when you run the sink or shower it will turn on and off constantly, this is normal. The Saniplus pumps out the water as it comes in.
Jun 20, 2010 | Saniflo & Saniplus& Macerator Pump
Kitchen drain constantly drains (Noisy)
If your heraring a ticking noise, it will most likely be the begining of a clog , usually if its an older home ,with garbage disposer,are the most common.Hope This helps!
Apr 03, 2009 | Plumbing
Aprilaire 560 constantly drains water
check to see if you have 24 volts between to 2 yellow wires coming out of the water solenoid. if you have 24v, then it is still getting energized to run. if it does not have 24v and the water is still running, the solenoid is stuck open. most likely from water deposits. sometimes you can take the solenoid apart and clean it, but probably better off just getting a new solenoid.
Feb 07, 2009 | Aprilaire Humidifiers
Washer Fills/Drains at the same time
check that the drain hose saises above the water level of the tub. I f the hose does not come above the water level, the water will just drain right out
Dec 01, 2008 | Whirlpool LSB6200KQ Top Load Washer
Drain pipe under eaves on second story
Yes. You can buy couplings, elbows and pipes at a hardware store and divert the water precisely where you want it to go. Hope this helps.
Sep 11, 2008 | Kenmore 75085 Air Conditioner
Admiral AW22 Top Load Washer Logo
Top Admiral Washing Machines Experts
Sal De
Marvin
Marvin
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
