Question about Motorola Mobility RAZR V3c Cellular Phone
Mobile Phone - Flip
I am unable to charge my mobile ph either through the powerpoint or thein car charger. Both attempts to charge the phone came up with the same messages ... "unable to charge", once it even said "insert sim". I was able to make and receive calls....well that was before it went totally flat
  • kathleenanz Nov 04, 2007
    I dropped my motorola razor phone on the ground and the back and sim card came out.I replaced both of them and then tried to turn on my phone (I have done this before and it never seemed to be a problem). It would not turn on and when i tried to charge it it said "unable to charge" and once it said "insert sim card".
  • 29 Answers
"unable to charge", "insert sim". is your phone been dropped or got wet? if unable to charge, when using a wall charger, try different outlets. if using onl one charger, tr different chargers. if it won't work, try other compatible batteries if you would get a charging message. if does not work, have your phone checked with a service center
Posted on Sep 30, 2007
SOURCE:
Not charging flat batteries
hi, most mobility scooter charges will not attempt to charge below 10 volts,
the trick is to use a car battery charger to bring the voltage past 10 volts then you use the mobility scooter charger to fully charge.
However please be aware of a couple of points:
1. Car chargers will damage mobility scooter batteries.
2. Once a Gel or AGM battery voltage has dropped below 10 volts they may never fully hold the charge again if they do recover and that's a big if.
Regards
Robin
GeWiz.
Feb 18, 2013 | Health & Beauty
Motorola BQ50 is "unable to charge" after having
try charging on a wall charger? im assuming you have a usb wall connector to match your computer charger like i do, also try it on different options besides mass storage.
Jun 28, 2011 | Motorola Mobility W375 Cellular Phone
Can't charge phone
Hi guppy5,
If you are unable to charge your mobile phone with your charger, then the problem is that your charger is not plugged in firmly or it is in need of replacement.
if that is not the case then there might be a problem with the hard ware of your mobile phone.
I would highly advice for you to take your mobile to a mobile shop to solve this issue.
i hope this helps.
May 31, 2011 | Cell Phones
Charging problem
Buy a new charger. If your computer charger works, and either your house or car charger are not working it is whichever is not charging the phone that is the issue. .
May 06, 2010 | Motorola Mobility SLVR L7 Cellular Phone
"Unable to charge" message for W377 motorola (t-mobile)
Check the contacts between phone and battery, if necessary align or clean. Are you using original Motorola charger? This solved my problem; I was trying to charge it with one of those "universal" chargers.
Hope this helps!
Mar 06, 2010 | Motorola Mobility W375 Cellular Phone
Unable to charge W270 Motorola with Moto V3 Charger.
Jul 18, 2009 | Motorola Cell Phones
Razr will not charge with wall charger
Your charger is faulty. If your phone is able to charge off of other sources (computer, car charger, another wall charger) Then, the charger needs to be replaced. Some mobile companies have a 90 warranty on accessories like the charger and battery. Then the mobile manufacture (Motorola) has a 1 year warranty on the charge and battery. I would check on that, and get those replaced.
Feb 04, 2009 | Motorola Mobility RAZR V3c Cellular Phone
W850i mobile phone
My husbands mobile phone did the same thing. Turns out he had put the charger input in the wrong way and broken the connection and there fore the phone wasnt charging. Unable to be fixed.
Sep 13, 2008 | Sony Ericsson W850i Cellular Phone
Motorola razor
you may need to have the usb charger port replaced....if that does not work try reflash the original firmware on the phone....for this to be done it is best that you take the phone to a mobile center close to you.
Dec 20, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3c Cellular Phone Logo
698 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
