Remove the front lower panel, screws underneath.Be prepared for water, drain out from drain hose.Check filter for clogging, clean out.Sometimes when the load is unbalanced & the machine cannot adjust the load it stops.To avoid this make sure your wash is mixed with big and small clothes. If this does not work remove the rear panel & check belt, should have half inch ‘give’.Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver.Check the motor brushes, if it is any shorter than 5mm replace brushes.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Bosch Classixx WFO 2466 Front
There is water dripping on to the floor from the bottom left hand corner, what are the probable...
(More)
There is water dripping on to the floor from the bottom left hand corner, what are the probable causes and solutions to correct the leak? ie removing sides or front panels etc
bosch washing machine , black gunk in my soap drawer and i have to clean it once a month and its...
(More)
bosch washing machine , black gunk in my soap drawer and i have to clean it once a month and its getting annoying, also its starting to get on the clothes if i forget. have been told this is an issue with bosch washing machines. if so is this something bosch should sort out?
bosch maxx washing machine will drain and fill but not spin. also recently clothes are left with...
(More)
BOSCH Maxx washing machine will drain and fill but not spin. Also recently clothes are left with sludge on them. Have put on several cycles with cleaning agent.
For the very first wash, and following the instructions; -- Instead of putting 1 litre of water in...
(More)
For the very first wash, and following the instructions; -- Instead of putting 1 litre of water in the soap dispenser I put it in the washing macine barrel and soap suds are coming out of dispenser and the front of the machine - we paused it and put it to off, then tried rinse - -- BUT now the door won't open at all Thanks very much
