Question about Toshiba 55HX70 55" Rear Projection Television
Model 55X70 Toshiba Projection tv
Our tv started with horizontal lines and then shut off and the power light continues to blink. Is this under warranty? It is three years old.
    Scholar:
  • 173 Answers
Dont know about warranties but horizontal lines means your horizontal frequency which runs about everything has drifted off sync and if too high or low it will activate shut down circuits in high voltage and power suppy, even causing HOT transistor to short. good luck and call a tech.
Posted on Sep 01, 2007
SOURCE:
Red power button blinking but tv won't power on
chec your ic register diode and transistor.
aslo check poer supply waltage and earthing properly.
Oct 11, 2008 | Toshiba TZ50V61 50" Rear Projection...
Toshiba 52hm94 when powered on continuously shuts on and off with blinking red and green light and static noise
that happened to my old LED tv it was the tubes that have gone go into currys and ask an expert thats how i found out what was wrong with mine
Aug 02, 2012 | Toshiba 52HM95 52" HDTV Projection...
62hmx95, blinking light, powers on then off
Examine in order the lamp, the ballast, the fans.
Apr 29, 2012 | Toshiba 62HMX95 62" HDTV
Blinking power light & black screen on toshiba 57h81
This TV could have one of several problems including but not limited to; convergence IC's,bad capacitors, shorted horizontal output transistor. Call a good TV Tech. Check with the BBB before you decide on one.
Jul 11, 2009 | Toshiba 57H81 57" Rear Projection...
No picture & the red power light just blinks
If it shuts off and then the power light starts blinking red or never turns on but the power light blinks red continuously that is usually indicative of the convergence ICs (STK 392-110). You never want to replace the ICs without also replacing the resistors that are associated with them. There are usually 6 resistors, one for each of the colors and there corresponding direction, IE Red horizontal, red vertical, blue horizontal, ect. In the case of this model tv all of the resistors are 2.2 Ohm and 2watts. You will find them right where the STK 392-110 ICs are. Right in front of them. They are blue and have this color code on them: Red, red, gold, gold. These are represented by stripes on the resistors. You can get the parts from www.bdent.com They carry the ICs and the resistors. If you do not feel comfortable completing this repair I could do it for you if you send me the board. My email address is: [email protected] The cost is 375.00 and that includes all parts.
Good Luck.
Mar 08, 2009 | Toshiba TP43H95 43" Rear Projection...
Toshiba TP43H95 projection tv has power but no picture
If it shuts off and then the power light starts blinking red or it never comes on but the power light just blinks red continuously that is usually indicative of the convergence ICs (STK 392-110). You never want to replace the ICs without also replacing the resistors that are associated with them. There are usually 6 resistors, one for each of the colors and there corresponding direction, IE Red horizontal, red vertical, blue horizontal, ect. In the case of this model tv all of the resistors are 2.2 Ohm and 2watts. You will find them right where the STK 392-110 ICs are. Right in front of them. They are blue and have this color code on them. Red, red, gold, gold. These are represented by stripes on the resistors. You can get the parts from www.bdent.com They carry the ICs and the resistors. If you do not feel comfortable completing this repair I could do it for you if you send me the board. My email address is: [email protected] The cost is 375.00 and that includes parts.
Good Luck.
Nov 03, 2008 | Toshiba TP43H95 43" Rear Projection...
Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
Jerry G.
Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Toshiba TN 50V71.
the start up or standby power is in need of troubleshooting. I would start by checking the regulator and horizontal output transistors.
Mar 14, 2008 | Toshiba TZ50V51 50" Rear Projection...
Power indicator light blinking
Check soldered in micro fuses...F850, F851 etc.....
1) solder jumper wires on signal board = 008,010,017,048,600
2) Check / replace STK392-110 convergence IC's with Toshiba
part # 23135090 or upgade to Hitachi part # CZ01341
Let me know....................T.
Jan 04, 2008 | Toshiba 65HX81 65" Rear Projection...
Toshiba 55HX70 55" Rear Projection Television Logo
129 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
