Step 1: A memory slot is a slot in your motherboard where you place your RAM (Random Access Memory) card. In layman's terms, the RAM is the "temporary memory" that the computer utilizes whenever it is turned on. If the computer cannot detect a RAM card installed in one of your memory slots, you have to troubleshoot the problem immediately. Ensure that the problem is with the RAM slot and not the memory card. Turn off the computer, unplug all devices connected into the ports of your computer and open the computer casing. Refer to the manual of the computer to know the specific steps to follow in opening the computer casing. Remove the memory card from the RAM slot. To do this, unlock the card using both hands. Pull the card away from the slot to remove. Inspect the RAM card for any apparent physical damages. Wipe the card with a clean cloth to remove dust. Also wipe the memory slot in your motherboard. Place the RAM card back into the memory slot. Press the card into the slot until it clicks into place. Close the computer casing, connect the cables back into their respective slots and turn on the computer. Turn on the computer and see if the memory is detected. If the computer does not boot up, the RAM card is not detected by the computer. Assuming that you have two memory cards installed in the computer and the computer boots up, check if the second memory card is detected by the computer. Click "Start," right-click "Computer" and then "Properties." Under "System," check the amount of "Installed Memory (RAM)." If the RAM is not detected, the RAM slot or the RAM card itself may be malfunctioning. Place the RAM card into another memory slot in your motherboard and see if the card is detected. If it is detected, the other memory slot is malfunctioning. Do not install any RAM card into it to avoid further damage. If it is not detected, the RAM card may be malfunctioning. Insert another RAM card into the slot. If the RAM card is detected, the slot is malfunctioning. http://www.youtube.com/watch?v=wGp5AiyJInI repair memory slot
Confirm the power-on lamp and the monitor
are off and open the battery-chamber/
memory card slot cover.
Be sure to turn off the camera before opening the
battery-chamber/memory card slot cover.
Removing Memory Cards1Before removing memory cards, turn the camera offand confirm that the power-on lamp and monitor areoff. 2Open the battery-chamber/memory card slot coverand press the card in to partially eject the card. 3The card can then be removed by hand. Do not attempt toremove the card at an angle.
Insert the memory card.
4Slide the memory card in correctly until it clicks into
place.
5Close the battery-chamber/memory card slot cover.
It has a memory card slot (left-side towards the front), but your particular memory card might be too big for the slot. There are several different variations of memory cards out now. Of course the newer the variation, the smaller that card is. This laptop is fairly new so it might not be compatible with your memory card. Does your camera have a USB cable for transferring pictures? If so, then just use that.
did you try reading the memory card without any game discs put in via the ps2 menu?
is your memory card working properly? could be a corrupted memory card or a faulty memory card slot. try putting a friend's memory card on that same slot. if it works... then your memory card is gone bad... if it doesnt work...then your memory card slot has gone bad.
else try putting your memory card in your friend's ps2, see if that ps2 reads your memory card. if it does...then your memory card slot has gone bad.
The HP Color LaserJet 4650 printer also has three flash memory card slots for printer firmware, fonts, and other solutions. The HP Color LaserJet 4610n does not include any available flash
memory card slots.
■ The first CompactFlash slot is reserved for printer firmware.
NOTE Use the first flash memory card slot for firmware only. The slot is marked “Firmware Slot.”
■ The two additional CompactFlash memory slots in the HP Color LaserJet 4650 printer enable the user to add fonts and third-party solutions, such as signatures and personalities. The slots are
marked "Slot 2" and "Slot 3."
These card slots are located inside the Formater unit. Most likely you either are missing the firmware card or it's defective.
Hope this helps!
good luck!
THis is simple. Either your memory card has not enough room, the memory card is broken or the slot you are putting it in is broken. Try putting it in the other slot.
It might be talking about the GameCube memory card slots, not the SD card slots. There should be a door on the top/left side of the WII. See if it's talking abou that.
