Question about LG Prada KE850 Cellular Phone
Micro sd flash card & external cards.
Can anyone tell me how can i install external memory cards? What is maximum size micro sd cards that I can use in this phone? and max size for external cards?
  • tina wheel Jul 07, 2008
    Could anyone please tell me how to install my memory card in my Prada. It is contantly telling me that my memory is full... its driving me mad!! I am only able to get 2 songs onto my phone. I have tried everything. Please help x
2 GB
Posted on Sep 23, 2007
2gb is the max
Posted on Sep 08, 2007
SOURCE:
How to view contents from flash drive
There are external memory card readers, you can connect to any USB port of all modern computers. Perhaps even your flash drive has an USB connector, so you can put it in an USB slot from the computer.
If the flash five is a mini or micro SD card, you need an adopter from Mini (Micro) to SD ann that combination should be inserted in the external memory card reader.
Sep 26, 2014 | Electronics - Others
8G micro SD only shows 1.87
If you "formatted" the card using the 'FAT16' file-system format, the maximum size is 2 billion bytes (1.87 Gigabytes).
Copy all the files onto your computer, and reformat it with the 'FAT32' file-system format, which does support your 8 billion bytes of memory.
Mar 14, 2014 | Electronics - Others
I have a 2 g memory card which when full I uploaded to my PC and then deleated all photos from the memory card I tried to use this card again but the camera tells me the memory card is full also it tells...
Exactly the same problem occurred with my San Disk 1GB micro-SD Memory Card. And I solved this problem formatting my micro-SD Memory Card using a software which you can download by clicking here.
To format your micro-sd card:
- First plug in your micro-sd card into you PC.
- Run the installed "HPUSBFW_2.2.3_MASTER.exe" file.
- In the program menu window, select the device (your memory card).
- Select FAT32 as file system,
- Confirm that all the format options unchecked. (Uncheck the quick format option)
- And click the "Start" button to begin formatting.
That's all my friend. This solved my problem and I hope this helps you too.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Apr 11, 2010 | SanDisk 2GB microSD Memory Card
Can I attach an 8 GB Micro SD Card in the expansion slot of my Sansa e250? If not, what is the maximum storage size it supports?
The e250 uses microSD cards, not microSDHC cards. The maximum size of microSD cards is 2GB. Anything larger are microSDHC cards.
Mar 16, 2010 | SanDisk Sansa e250 MP3 Player
Installing Micro SD card to Sansa e260R
The Sansa e260 Rhapsody (e200R series) supports:
1. micro SD cards ( not the HC type )
2. micro SD cards up to 2 GB of memory capacity
See next site:
http://kb.sandisk.com/app/answers/detail/a_id/200/related/1
Jan 10, 2010 | SanDisk 4GB microSD High Capacity Memory...
Cannot install 4GB card into TL220. Do I have the
According to Samsung's page on this camera, the following memory can be used:
External Memory(Optional) : Micro SD (up to 4GB)
Micro SDHC (up to 8GB)
4 GB is acceptable, but I think you do not have the correct type of card. You should be using a Micro SD or "Micro Secure Digital" (up to 4GB capacity) or a Micro SDHC or "Micro Secure Digital High Capacity" (up to 8 GB capacity) card. This is very different from an SD or SDHC card. These Micro cards are very small (smaller than your thumbnail) and are often packaged with an SD adapter card. Regardless if sold with or with out the adapter, the package should say Micro SD or Micro SDHC on it somewhere.
Oct 02, 2009 | Samsung Cameras
How do i upload music from my micro sd to my phone
Does your phone support external memory? If so, just plug the micro sd to your phone.
Jul 24, 2009 | SanDisk 2GB microSD Memory Card
Maximum SD card size for TomTom ONE XL
The XLS which is not that much different and supports 4Gb as used in mine which allows me to keep maps of the US,Canada, UK, and the whole of europe on it and swap at will. I bought a cheap generic one. I do kow that those cards that use micro sd can and do have problems so best to avoid the micro type unless your device takes those specifically
Nov 29, 2008 | Tomtom ONE GPS Receiver
What is the maximum amount of SD/MMC memory on e330
In my opinion there is no any limitation. I am pretty sure that you can use 1GB SD Card without any problems. Only thing that can happen is that access to your data can be a little bit slower.
Sep 11, 2005 | Toshiba e330 Pocket PC
LG Prada KE850 Cellular Phone Logo
200 people viewed this question
Top LG Cell Phones Experts
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
