Question about Mitsubishi VS-60707 60" Rear Projection Television
Can you tell me how to stop my TV from Scrolling....
When I turn on the TV..It needs to warm up before the correct colors come in and now the picture starts scrolling...can you tell me how to fix this
    Genius:
  • 1,153 Answers
You would have to make some checks:1. CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. You can try and change that cap first. Hope this helps
Posted on Sep 10, 2007
SOURCE:
My Memorex MT2274 WILL NOT STOP Rolling................why?????
You may be trying to view an incompatible signal on the TV (NTSC or PAL), using one type while the TV only natively supports the other. If you see the image in black and white as well as the infinite scrolling effect, this is most certain.
However, if it's a scrolling image in color, then perhaps your V-hold is tuned incorrectly. Find the V-hold knob on the TV and turn it to fix the scrolling; if there is no V-hold, then maybe it's on the back of the TV, or it might be inside the TV. In rare cases I believe it could even be inside the TV menu, though this is doubtful (and also it would be extraordinarily difficult to access since the picture's already scrolling).
Jan 30, 2018 | Memorex Televison & Video
53SDX20B Projector TV - No Picture
It was condesnation from moving the TV from the cold outdoors to the warm indoors. I let it warm up for about 2 hours and then it was fine.
Jan 11, 2010 | Hitachi Televison & Video
Color red seems to be more prominant...than other
I've had this problem with my projection TV recently. I would say your lens/lamp is to blame. It might be time to change it, depends on the last time it was changed, most of the time, the TV will tell you that it needs to be changed, but not always. I think your best bet is the TV lamp.
Oct 20, 2009 | Hitachi Televison & Video
Mitsubishi VS-50707 screen is jittery when it first turns on
Sounds like the verticle circuit is failing a honest shop will take of this for you around 180-230 if you want to do yourself youll need a iron and some filters and an verticle ic
Sep 26, 2009 | Mitsubishi VS-50707 50" Rear Projection...
Samsung DLP HL-R4266W..no sound or picture. TV is completely dead
Assuming the noise is a high-pitched whine, then yes, it is the color wheel.  If the color wheel goes out, the TV will turn on for a while, then turn off when it can't establish color wheel sync.  The color wheel has to be in sync with the mirrors on the DLP, so if sync can't be established, the TV turns off.
You can order a new color wheel from Sears or partstore.com (among other places) and replace it yourself, if you are so inclined.
Jan 24, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Degaussing problem
There is an automatic de-gaussing circuit within the TV and it's likely to be the culprit. When the set is first turned on (before you even see a picture) this circuit is active and as it warms up, a thermistor opens up and stops the circuit from operating. It does this because as it heats up it's resistance rises and the circuit stops the current flowing through the de-gaussing coil. Over time from the heat/cool cycle, the connections to the circuit board fail. Simply re-soldering the thermistor is probabaly all that's needed.
Oct 07, 2008 | Televison & Video
Bad picture
Sounds like a dry solder joint. When the tv is on for 4/5 mins the crack warms up and the gap spreads. When you turn off it cools and when it warms up it starts again.
Mar 18, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Mitsubishi VS-60707 60" Rear Projection Television Logo
53 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
