Question about Dacor Preference SGM304 Gas Cooktop
Dacor SGM304... no ignition
Was cooking with gas just fine this morning. Then the ignitors stopped working. Checked all the obvious things (power cord, circuit breaker). Plugged unit into extension cord to a distant outlet. Nothing. Don't see anyway to get into the unit for any fuses or anything. What should I do next?
  • samina62 Feb 07, 2008
    my gas cooktop has the integation noice like tick tick and i try every thing it did not work what should i do
  • skjr Mar 29, 2008
    no spark on the burner- How do I replace the spark plug?
  • 183 Answers
There is no fuses, as long as you have a power supply into unit then the only item that can cause this fault is a faulty spark generator.the hob will need to be dismatled to repair, remove the knobs, remove the burners and then remove the obvious screws, top will lift off Regards Advisor
Posted on Sep 01, 2007
SOURCE:
Gas Kleenmaid cook top, one igniter continues to
the switch for the ignitor is stuck. might need to free the switch, of
> call the repair man.
Oct 20, 2013 | Jenn-Air 30 in. CCG2423 Gas Cooktop
When I turn on any of the knobs the ignitors start however there is no gas flowing.
Hi,Check for gas to the cooktop...if you have gas up to it...
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Sep 16, 2011 | Dacor Preference SGM304 Gas Cooktop
One of the burners on my Dacor 4 burner gas cooktop no longer ignites automatically, it just continues to spark, but it will light with a match. Is this something I can fix myself, and if so, what should I...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 28, 2010 | Dacor Preference SGM304 Gas Cooktop
Dacor sgm304s, Ignitor constantly snapping.
under burner control knob broken plastic cam that operates switch.
Sep 07, 2009 | Dacor Preference SGM304 Gas Cooktop
My ignitor will not go off. The burner will light
Unplug the appliance for at least 1/2 hour and then plug it back in and see if the problem goes away. If not, you may have a defective ignition board or a bad connection somwhere.
Aug 01, 2009 | Dacor Preference SGM304 Gas Cooktop
Single Burner no ignition
Hi
If all the other ones are working correctly, then the problen is the sending unit, each knob has an electric sending unit that works independantly, the one that it's not working, My advise is to pull it out and cleaned first and try it. If it does not work, then replaced it.
If you need help with the procces let me know.
Eddie Rentas
Tupper Lake NY
Jan 10, 2009 | Dacor Preference SGM304 Gas Cooktop
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Dacor cooktop ignition problem
TAKE THE BURNER CAPS OFF AND CLEAN THEM REALLY WELL AND MAKE SURE THAT THEY R PUT BACK ON PROPERLY THRER ARE GENERALLY A NOTCH THAT HAS TO BE LINED UP JUST RIGHT FOR THE CAPS TO FULLY SEED TO PROMOTE PROPER LITING
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
May 27, 2008 | Dacor Preference SGM304 Gas Cooktop
Dacor Preference SGM304 Gas Cooktop Logo
428 people viewed this question
Top Dacor Cooktops Experts
MARLON KELLER
jdthefixer
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
