Back to:
Tags:
Konica Minolta DiMAGE S414 Digital Camera
Camera dying?
posted by sybrkatz on Sep 01, 2007
It will powerup like normal.
But when a CF card (tried different ones)is in the camera and you press the button to take a photo, the screen will either shut off clean or give a flash of scrambled image then shut off and freeze. The only way to reset is to remove the batteries. It is also draining the batteries in the few attempts to power it on.
When no card is in there it will stay 'alive' for a bit longer but pressing any button on it and the lense will power down leaving the lcd display stuck on.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Sep 02, 2007
Not Rated (0)
poolseman
Rank:Guru Guru
Rating: 89%, 287 votes
CCD problem is the likely cause here and once you have another one put in camera should work fine.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Camera dying?:
I don't want to Accept this solution
Can you Help with these Digital Cameras problems?
Hi. When I try to take a picture, the camera focuses (even...
camera will not take a picture then shuts down and...
I recently bought a used Minolta Dimage S414 as an interim...
I turn the camera on, focus and I'm able to get 1-2...
Hello, I took pictures on my last ski trip but the...
Loading problems.
Repair Service
Find Digital Camera Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
