Question about LG VX8300 Cellular Phone
No display How do you get the phone to display the time and date (on the front of the phone) my other phone did it automatically. Thanks for you help.
On my phone, I just have to tap any of the buttons on the cover and the clock will show
Posted on Oct 03, 2007
SOURCE:
I cannot reset time and date on my samsung z2
Want to set the date and time for your mobile phone? Follow these easy instructions.
From a Home screen, tap the Arrow icon to display all apps.
  1. Navigate: Settings > Date & time.
  2. To use network-provided values, turn on the following:
    • Automatic date & time
    • Automatic time zone
  3. When manually setting data & time, perform the following:
    Automatic date & time and Automatic time zone settings must be turned off to manually adjust date and time.
    1. Tap Set date.
    2. Adjust the date then tap OK.
    3. Tap Set time.
    4. Adjust the time then tap OK.
    5. Tap Select time zone then select a time zone.
  4. If desired, tap Use 24-hour format to turn on or off .
May 23, 2018 | Samsung Cameras
Now the outgoing message does not appear in the screen???
Hello Robert,
Please check if the phone is displaying right date and time. If not go to the Settings---> Date and Time---> Enable Automatic update of date and time. Enable automatic time zone.
Try sending the messages, you'll be able to seee the sent messages.
May 13, 2016 | Cell Phones
Time on phone keeps changing and doesn't stay when I put the correct tome in...which I shouldn't to do right....its suppose to be automatic but its constantly giving me the wrong time...help please
Your secondary battery located inside your unit which is for correct time display maybe drained. I have the same problem with my phone. After I had it replaced by a technician, my phone clock display is now working nomal. Another option if you don't want your secondary battery replaced is setting your phone to automatically detect your network's time. Go to settings, look for time and date settings and locate the automatically update time or something like that. Everytime you turn on your phone, it should automatically detect and display a correct time.
Dec 19, 2010 | HTC EVO 4G Smartphone
KX-T7230C HOW DO i CHANGE DISPLAY WINDOW TO SHOW DATE AND TIME
hi,
to do this, go to profile.
select your profile and personalize it.
then go to display and click on show time and date.
then,go back and activate the profile.
the time and date will display on your phone.
thanks for using fixya.
Jun 06, 2010 | Panasonic Lands Phones
Ge model 27909 answering machine gives wrong time on playback
I found it on the manual, it was in programming section!
Date/Time
NOTE: Time set on handset will be transferred to the base unit automatically.
1. Make sure your phone is OFF (not in talk mode).
2. Press the menu button to go to the main menu and use cid/vol (3or4) button to scroll to Date/Time.
3. Press menu button to enter the menu. Year 2006 shows in the display.
4. Use the touch-tone pad to enter the last two digits of the current year (range: 00 to 99).
5. Press menu button to save the year setting and proceed to date setting.
6. Date 01/01 shows in the display. Use the touch-tone pad to enter two digits for current month and day respectively.
7. Press menu button to save the month/date setting and proceed to time setting.
8. Time 12:01p shows in the display. Use the touch-tone pad to enter four digits for current time and use cid/vol (3or4) button to toggle between "p" (pm) and "a" (am).
9. Press menu button to save the setting. Saved shows in the display.
NOTE: If you subscribe to Caller ID service, the current date/time is set automatically when you receive your first CID record and will override manually set date/time.
Jan 08, 2009 | GE Lands Phones
Display time and date
Go to your phone's "Time & date" settings and select "show", u might have your date and time hidden this time. And more thing, set the time and date first, some phones displays time and date automatically after setting...unless the user choosed to hide it...good luck! i hope this solution solved your problem.......
Oct 09, 2008 | Motorola Mobility RAZR V3
How to set time & date on phone
If you subscribe to Caller Display services, the first incoming call will set your phone's date and time automatically. Otherwise, here is how you do it.
1. press Options 2. Press * three times The display shows "Enter time/date?"
You may set both time and date or you may set either of them separately
TO SET BOTH 1. Press # when the display shows "*=Next #=Enter" 2. Wait for each prompt. You will be asked to enter: - the time - am or pm - SAVE - the month - the day, and  - SAVE (Enter the hour, day, and month as two-digit numbers. For example, enter 02:15 for 2:15, 05 for May and 08 for the 8th of the month.)
TO SET ONLY THE DATE 1. Press # when the display shows "*=Next #=Enter" 2. Press * when the time appears 3. Enter the month and day when prompted. 4. Press SAVE
I have a question for you: Can you give me the specs of the AC adapter for this phone (usually written on the adapter)? 1. What is the OUTPUT in volts (V)? 2. What is the OUTPUT in milliamperes (mA)?
3. What is the polarity (i.e. is the + sign in the center of the jack or on the exterior)?
(The wall plug transformer has a diagram depicting two circles with the inner circle representing the center conductor. A line coming from the inner circle will show a minus (-) or a plus(+) symbol to let you know the polarity of the center conductor.)
Thanks!
Mar 30, 2008 | Lands Phones
GE 27831 Cordless - Date Time Issue
should be in the main menu thru the handset setup .unlike cell phones that reset automatically . you must go into setup and do it
Dec 23, 2017 | GE 27831 Cordless Phone
LG VX8300 Cellular Phone Logo
Top LG Cell Phones Experts
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
