Question about Hitachi Travelstar 5K100 HTS541060G9SA00 60GB 5400rpm 150MBps Serial ATA Serial ATA/150 I... (0A26923FT) Hard Drive
My burner is not working
My burner is not picking up any thing it won't burn cds play movies or music cd it makes a "different" sound when i insert a disk of any kind and it does not pick up nothing
  • Hitachi Master
  • 12,061 Answers
This sounds to me like your CD/DVD is borked,& you need a new one, sorry.. Ya see, really the only way ya can "see" if it is OK, or not, is to try another one... to isolate the problem. They break down quite commonly I have found. If you are unable to do this, then it's off to the repair shop.. As I always say in these cases get a firm "Quote" and an explanation of repair.
Posted on Sep 01, 2007
SOURCE:
CDS BURN BUT CANNOT PLAY WHY?
You mean, you burn the CD in your PC but you can't play it in external CD player ?
Maybe you didn't burned it in "movie" mode, just burned in "data" mode. As you know, CD player can't play .avi or .mkv or other video formats. They only can play movie in .DAT format, and when you burn in "make a movie" mode, the burner will convert your movie to this format so you can re-open your movie via CD player.
Or there is an error during the burning time, if this happen then you have to re-burn your movie into another CD.
Hope this help and be kind to rate this answer.
(^_^)
Jan 06, 2011 | LaCie Dupli DVD121 DVD±RW Dual Layer...
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
I had to download all kinds of drivers to get my computer to do basics like viewing movies hearing music and finally burn music now i learned i can only save data(lots of songs at one time) or make a cd on...
cd-r80 are for music. Your best option is to buy a program like nero. I assume you are just dragging and dropping files to burn them right now. dvd's are more meant for backing up data or making movies because they hold a lot more data then a cd. Are you able to burn disc's at all? Just like all things involved with computers it can get complicated real quick.I hope this helps a little and if you have more questions let me know
Thanks,
Lee
Nov 05, 2009 | Dell Inspiron E1505 Notebook
My cd rom won't detect blank cds
try re-installing your burning software ( nero-Roxio et,c )
Does it play a standard Music/Audio CD.
if not un-install and re-install the drive.
Are the cables to the drive connected correctly ?
Does the drive support CD+ And CD- media ?
Are the cds definately Blank, any small amount of data written to them, after failed burn attempts will not show the disk as being empty.
Mike @ Compurepair.
Jun 13, 2009 | Dell Computers & Internet
Dimension E510 dvd burner will not burn
Go to this link and click on the Fixit box. Microsoft has an issue with CD/DVD recognition and created a patch. This happens a lot when Windows Update runs and installs SP3. Hope this solves your problem. If it doesn't, right click on your DVD drive and ensure that recording is enabled. Hope this solves your recording issue.
Greg
http://support.microsoft.com/default.aspx?scid=kb;en-us;314060
May 18, 2009 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
Burning movies
Yes. Many burning apps (such as Nero) support the creation of Video-CDs, and most current DVD players support playing these Video-CDs.
Apr 12, 2009 | QPS Que! CD-Rewriter CD-RW Burner
Dvd drive will read/play dvds but will not recognize a cd
go to safemode and try reading CDs in safemode. If your burner still can't read CDs then it's most likely bad. You could get an external usb burner.
Mar 18, 2009 | HP Pavilion dv4000 Notebook
Dvd burner wont work
are you able to play dvd movies? what operating system are you using? what dvd burning software are you using?
Jun 12, 2008 | HP LightScribe dvd640i (DVD640I)...
Cdj 800 error 8301
Error Code
E-72 01
E-83 01
E-83 02
E-83 03
E-91 01
Description
Player unable to read TOC data.
Disc is rotating, but rotation cannot be ascertained.
Player unable to play back currently inserted disc.
Mechanical operation has failed to complete within
specified time interval.
Possible cause and recommended action
Disc is cracked.
= Recommended action: replace disc.
Disc is soiled or dirty.
= Recommended action: clean disc.
If other discs play normally, the problem is with the disc itself.
Dust or some other form of foreign particles have found their
way into disc insertion slot.
= Recommended action: remove dust or other foreign particles.
Error Type
TOC READ ERROR
PLAYER ERROR
MECHANICAL TIME OUT
Jun 11, 2008 | Pioneer CDJ-800 Turntable
Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Jan 01, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
Open Questions:
Computers & Internet Logo
73 people viewed this question
Top Hitachi Computers & Internet Experts
Ekse
Alun Cox
Marvin
Marvin
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
