Question about Onkyo TX-DS939 Receiver
Need to buy the jumper plug
Where can I buy the jumper plug for my Onkyo TX-DS939
    New Friend:
    Problem Solver:
  • 6 Answers
What do you mean by a jumper plug. Are you referring to the preamp jumper plugs?
Posted on Sep 01, 2007
Can the speakers surround sound work if the optical out is not red?
Yes.
There are several other methods for your surround sound channels to operate without your optical connection.
Jan 01, 2011 | Onkyo TX-DS939 Receiver
Connecting Airport Express to my Onkyo Receiver
Plug it into the cd input, with the two rca cables. We've had this set up for years. No longer use a cd player at all.
Mar 24, 2009 | Onkyo TX-SR803 Receiver
Problem with onkyo tx 919 unit
Hi...
If you've had it "fixed" 3 times and the problem comes back either you have the wrong impedance (ohms) speakers connected or the power supply in the unit is the actual problem.
Happy new years,
Scott
Jan 01, 2009 | Onkyo TX-DS939 Receiver
GETTINF OVER HEAT
Onkyos are notorious for running a bit warm - though if yours is excessively warm, double-check the impedance of, and wiring -to- your drivers.
Nov 13, 2008 | Onkyo 630-Watt 7.1 Channel Home Theater...
Onkyo TX-DS939
I have to ask the obvoius, did you get the manual, have you used the onscreen menu to set up the speakers, you can calibrate the speaker levels on the TV screen if you use the S video or RCA vidoe connection .have you turned off tape monitor?
Apr 27, 2008 | Onkyo TX-DS939 Receiver
Desply and sound gos off Onkyo TX-DS939
On my device there were quite a few bad solderings on power card. May be you have the same and it does not tolerate heat. Power card is that horizontal one on top, when you open the box. It is easy to remove so that you see under the card to check those solderings. One screw from left side of case, which holds that noise eliminator on AC lines, six screws from back keeping those connectors and four screws away from board corners. I disconnected only that connector in the middle of card, because it was a bit tight. Then I was able to turn that card upside down and after some fixes to those bad solderings device is like new again.
Apr 23, 2008 | Onkyo TX-DS939 Receiver
Onkyo TX-DS939 optical selection problem help!
That coaxial, opt-1 and opt-2 are available only if they are not selected to some other channel. So you have to check if opt-2 is selected to Video-1,2,3,4,5,6,7,CD or DAT. Change that to Analog and then opt-2 is free to another device.
Mar 24, 2008 | Onkyo TX-DS939 Receiver
Onkyo TX-DS939 Receiver Problem
+22v line is missing. Check for 22v at R9207, not present check R9201,2 0.22ohm, R9203-6 1 ohm. Check also Q9201 12v reg ic, it supplies the led in the volume ctl. While your in there, solder up any cracked solder joints, bad connections.
Nov 04, 2007 | Onkyo TX-DS939 Receiver
Onkyo TX-DS939 Receiver Logo
378 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
