Question about GE 31GT660 TV
Unusable signal when i try to watch a dvd i go to channel 00 like usual but now its saying unusable signal. i can hear audio but no video. i already checked wires to make sure everything plugged in correctly. no manual.
    Genius:
  • 1,694 Answers
Substitute video jumper cable....
Re-check video out hook-up on back of DVD......
Sub out DVD with different DVD / VCR for test......................T.
Posted on Feb 11, 2008
Rca model j27435 trying to use dvd player says unusable signal
Most DVD players and maybe the Wi are connected via rear audio and video input jacks so that may be your issue.
Jun 11, 2012 | RCA F27442 27" TV
I am hooking the system to a yamaha stereo receiver and i need to know what jacks to hook it to out or in 3 wire or just 2 because of no video just audio red white yellow the stereo reciever just has ...
Let me write some basic things about audio and video signals and cables. Stereo audio has two channels, left and right, usually red and white (or black) jacks. You plug in audio cables. Video signals in old receivers are marked in yellow. If your receiver does not have video (yellow) input, usually located above the two audio inputs, you will not be able to watch any video signal through the receiver. The receiver will only play the sound of dvd, since its left and right audio channels are properly connected. Just aux and phono inputs are not enough. Hope this may help.
Sep 07, 2010 | Audio Players & Recorders
Entivoe DVD player worked fine. The next day, the tray opens, closes and the power turns on and off but the screen says only "Unusable signal", either with or without a video disc in the player. If there...
check the connection cable to the tv, unplug this an replug it to see if this helps.
if you used a cheaper HDMI cable for example the connectors are very wobbly and often make poor contact....
Aug 31, 2010 | Televison & Video
Unusable signal
video inputs do not have channels you must not have it on the right source. Turn your Wii on then change the input untill you find it.
Sep 08, 2009 | RCA F32648 32" TV
Unusable Signal for PS2
If you want to use a PS2 with an RCA stereo monitor Colortrak plus television, folllow these steps:
1.Buy a universal remote compatible with RCA televisions if you don't have the original.
2.If your remote needs programming, program it with the manual provided.
3.Goto Menu
4.Goto Alarm
5.Goto Alarm Channel
6.Set Alarm Channel to 00
7.Exit Menu
8.Goto channel 00 on the television by using the remote.
9.You should be in AV mode, and able to play your PS2.
P.S. I don't know if you need to set Alarm Channel to 00, but that's how i did it.
May 13, 2008 | Televison & Video
Input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Jan 05, 2008 | Sanyo DS24205 24" TV
Video
Bad video cable is first thing to check. The output is composite or progressive? need more info on your configuration to solve. It almost sounds like the IC for the video is heating-up.
Jan 01, 2008 | Memorex MVD4543A
Unusable signal
A brand and model would be helpful. However if you have some knowledge on TV's you could try replacing the Jungle IC first. This usually controls the AV inputs on a standard CRT. Probable cause, Static on the Video line. Good Luck. Jus004
Dec 07, 2007 | Televison & Video
My sylvania 19
Try channel "00" or Channel down 4-3-2-video.................
Do you have the owners manual for the tv??
Or power on DVD and activate channel auto-program......
Please rate this solution...............
Nov 14, 2007 | Televison & Video
Dvd burner
Can you try just running a/v cable from your tv output to the inputs on the ilo, then whatever you watch on your tv you can record on your dvd burner. My new SDTV doesnt have audio out except Coax so this won't work for me on that tv. Why doesnt the newer tv's have audio AND video outputs???
Oct 30, 2007 | iLO DVD Recorder DVDR05
GE 31GT660 TV Logo
343 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
