FixYa.com
Tags:
Umax Astra 1220P Flatbed Scanner
Needing to hook up my scanner (by 2 users)
posted by canboop on Sep 01, 2007
I was given a 1220p scanner with no cords. I have the cd software but no cords. I have a Dell pc that I want to hook this scanner up to. The only 2 available places to plug in my scanner is a small 9 pin blue plug above my monitor plue and the printer 25 pin plug. What do I need to get as far as a cord and where do I plug it?
Thanks,
Kimberly
Comment by canboop, posted on Sep 07, 2007
The scanner is not being noticed by my hardware wizard. I tried everything. I know the scanner works, my mom used it before I brought it home. Is there anything else I can try? I'm not going to give up yet.
Thx
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Apr 16, 2008
4600 hp
Best Solution
posted on Sep 01, 2007
Helpful (85)
Silverdragon
Rank:Wiz Wiz
Rating: 82%, 705 votes
You are going to need a 25 way cable a "Printer" type cable, A Male to Male, BUT with ALL 25 pins wired thru pin To Pin. This plugs straight into the "Printer" port.
These machines often have a "Pass Through" port on them so ya can also connect to a Printer, however if ya printer is USB then it's NOT used.
I found drivers below.
http://www.opendrivers.com/
driver/211491/
umax-scanner-astra-1220p-
vistascan-3.55-parallelport-free-download.html
Rating Locked! (?) canboop has rated this solution as Helpful
Can you Help with these Scanners problems?
Scanners
scanjet 4050
can not install software from... Answer This...
Scanners
driver for umax scanner 4500
i can't find driver for umax... Answer This...
Scanners
help
do you have scanner codes Answer This...
colour of the scanned copy
when i use the scanner the... Answer This...
Need Driver for XP of Umax...
Hi, I will appreciate if you... Answer This...
Repair Service
Find Scanner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
