Question about Palm Treo 600 Handheld
Esn is not on treo 600 w/ cam
My ens was deleted somehow on the treo. I did a soft reset, no reslove. I did a full back up before doing a hard reset. Esn still not on pda.
    Problem Solver:
  • 14 Answers
My ESN was also missing from my treo until i switched on the wireless. try it.., let it load the network then look for the ESN. note my network did not have a sim card. you may need to put in a sim card if your treo network requires it then check. good luck.
Posted on Nov 10, 2007
I forgot my code to unlock my palm treo 650 cell phone
A last resort is to hard reset the device, but you will loose your data.
See here how to hard reset.
Jan 09, 2009 | Palm Treo 650 Handheld
Palm Treo 700W Smartphone is stuck on speaker phone
Soft Reset
A Soft Reset stops all active (or open) programs and "reboots" the handheld. When the Treo powers back up, you'll start with all programs closed and the unit will be ready to use. The soft reset is intended to reset the Treo if it is malfunctioning or has become bogged down.
The Palm Treo 750 can be soft reset by quickly pressing and releasing the tiny red button beneath the miniSD memory card door:
diagram.jpg Hard Reset
A Hard Reset wipes the internal memory and returns the Treo to its factory specs, in effect returning the Treo 750 to the state it was in when you purchased it. All data entered, preferences set or software installed on the Treo after purchase will be lost after a hard reset and will have to transferred or reinstalled via ActiveSync / Windows Mobile Device Center.
power_button.jpg The Palm Treo 750 can be hard reset by pressing and holding the power button (seen left) while at the same time pressing and holding reset button beneath the miniSD memory card door. Press and hold the two buttons until the screen completely fades. When the screen returns, you'll be given the option to "Erase all data." Select Yes to complete the hard reset. The Treo will now be as it was when it left the factory and you can start fresh. You may have to perform a soft reset after the hard reset to get the unit to power on.
May 11, 2008 | Palm Treo 700w Smartphone
Hard reset
hold K, return key, and press reset. reconnect charger to turn back on.
Apr 01, 2008 | Palm Treo 600 Handheld
Treo 600
if your ESN is cleared for activation then you can just call customer service and and the they can do it while you are on the phone with them. If the ESN isn't clear take your phone into your service providers store/
Feb 12, 2008 | Palm Treo 600 Handheld
Palm treo 600, hangs while picking up calls and wireless mode goes off, deleting all data
Perform a hard reset, and clear the data off the treo.
Hold down backspace and the K key. While holding both of those down, hit the reset button on the back. Hold all for a few seconds. The screen will flash white and then turn off.
Then plug it into the charger cable. It'll turn back on and get you to put in all the settings again.
Then it will work correctly.
Feb 07, 2008 | Palm Treo 600 Handheld
Palm treo reset
You want to perform what is called a "Hard Reset"
It's pretty easy. You hold the power button while you push the reset button on the back. The treo will ask you if you want to erase all the data.
  • Unscrew the tip from your stylus
  • Locate the "RESET" hole on the back of your Treo 600
  • Press and hold the power button on the top of your Treo and then press the reset button with the stylus pin
  • Remove the pin from the reset hole FIRST, hold both for a few seconds, and then release the power button.
  • The screen will say "erase all data?", tap the up arrow to answer yes
  • Here is a explaining what I just said above:
    http://mytreo.net/archives/2004/05/hard-reset-the-treo-600.html
    Sep 22, 2007 | Palm Treo 600 Handheld
    My treo is doing hard reset automatically
    try performing a battery reset..it will reset the internal radio and the charging circuitry..only problem here is that u need an AC charger to switch the phone back on. this will wipe out all data u may want to back it up before trying this option heres how to do it Battery Disconnect Reset Treo 600 only A battery disconnect reset is a last resort step you can take to cut battery power, wipe all data, and regress a Treo 600 to its factory-fresh state. It only works on a Treo 600 smartphone. Important: A battery disconnect reset will erase everything on your smartphone, and also reset the wireless radio and disconnect the internal battery. All your data will be removed, and your formats, preferences and other settings are restored to their factory default settings. Don't perform a battery disconnect reset unless you've backed up your data, or you're willing to lose everything. You won't be able to turn your Treo 600 back on until you connect it to a power adapter, so do not perform this type of reset without your Treo 600 charger and a power source. HotSync note: Some third-party applications change the way your handheld backs up data. Other third-party applications do not back up data. If you have third-party software on your device, please contact the developer to learn what components are backed up during a HotSync operation, and if HotSync conduits are altered. Any data not backed up will be lost. To perform a battery disconnect reset: 1. Disconnect your Treo 600 from the AC charger. 2. Hold down the K and Backspace keys simultaneously. (Note: for French AZERTY keyboard, press K and M; for other language overlays, please refer to the customer support for your region) 3. While continuing to hold down the K and Backspace keys, press the RESET button inside the hole on the back panel of your device (where's the reset hole?). 4. Finding it hard to do? Good. We made this type of reset very awkward to perform, so that it would not happen by accident when your Treo 600 is jostling around in a pocket or bag. Sorry for the inconvenience. You might want to ask a friend to lend a hand if you find it too difficult to do by yourself. 5. Continue holding down K and Backspace. The screen will flash white briefly, and then go black. Release K and Backspace after this happens. Your Treo will appear to be "dead" and the screen will not turn on. If you see any activity ? such as the screen turning back on ? the reset was performed incorrectly; try again 6. To revive your Treo 600, connect it to the AC charger and plug the charger into a socket. The screen will stay blank for several seconds (as long as half a minute), then it will turn on. The LED will glow solid red, indicating charging. 7. Finally, follow the steps for recovering after a hard reset (a battery disconnect reset is an extended type of hard reset).
    Aug 06, 2006 | Palm Treo 600 Handheld
    Deletinjg contacts.
    I suggest you hard reset the Treo 600 to remove all former data and the username associated with the phone. Press the power button next tot he antenna and perform a soft reset at the same time. Dont let go of the power button until the Palm Logo appears. Then you will see a message asking if you want to delete all data. Removing portions of the old data is not an easy task.
    Sep 12, 2005 | Palm Treo 600 Handheld
    BIG PROBLEM: After hotsynch Palm resets over and over
    You need to hold the "up arrow" while resetting, this will allow you to delete all info. That may not be what you want to do, if so, the only other option you really have is to do a soft reset, which is holding the up arrow and selecting "don't delete data". If the delete all data is STILL hanging after a hard reset, you can do a battery reset, which drains the battery, erases all data and goes back to "factory settings" There are two methods for this: While holding down the J & L keys, click the reset button on the back and hold it for 4 seconds. Or While holding down the K & backspace keys, click the reset button on the back and hold it for 4 seconds. Google "treo 600 battery reset" for more details
    How do I purge contacts from the Treo 600?
    Best would be to perform a hard reset. This will delete all your contacts, but also all your other data on your phone as well such as mail, sms, call log, settings etc.
  • Remove the pin from the reset hole FIRST, and then release the power button.
  • Sep 11, 2005 | Palm Treo 600 Handheld
    Palm Treo 600 Handheld Logo
    76 people viewed this question
    Top Palm Computers & Internet Experts
    Marvin
    Marvin
    JC Meredith
    JC Meredith
    Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
