Question about Frigidaire GLEF378 Electric Kitchen Range
Stove top cracked while in use
I want to see if it is still under warranty.
0 characters
1 Points
Need help opening an older Caloric Prestige Series Range top
Generally you just need to place a flat blade screw driver in the crack about 3 inched below stove top and pry up, this exposes the entire under pan of the stove top.
Apr 07, 2014 | Stoves Kitchen Ranges
Kitchenaid stove code f68
This stove should absolutely still be under warranty. I would start with calling the KA customer service. They are pretty good and will usually do all they can to help you. The number for them is:
Jan 03, 2014 | KitchenAid Electric Stove Range...
Who can replace a Admiral stove glass top?
i cracked mine too. the tops cost enough to make you just wanna buy a new stove.
Jul 16, 2009 | Frigidaire FEF366 Electric Kitchen Range
Broken glass top for my gas stove
You can buy just the glass for your glasstop stove. I too need to replace my glass...I have a whilpool electric glasstop. Its not cheap...may just buy new stove. I priced just the glass for my whilpool at the cheapest I can find for $320.00. Thats a lot. Mind you its not the elements under the glass..its just the glass! So...idk bout you, but a whole new stove might be my best option. If you want to price the glass for your model just keyword search your number and brand of stove and type replacement glass. GOODLUCK! :)
Feb 16, 2009 | Frigidaire FES367 Electric Kitchen Range
Replacing glass top on stove
its not too bad.kill the power.then under the frount of the top where the top meets the oven door .under there are screws remove those and the top lifts up as on hinges.their is a ground screw wire to loose and unplug the the wire harness that connects the burners to the rest of the stove.then all is disconnected so lift entire top off from hinged area and set upside down on table.transfer all burners to new top thats nexted to old one upside down also.when done reinstall.ive done lots wont be bad.please dont for get to help me with my rateings.God bless ,tom
Jan 05, 2009 | GE Profile Spectra JBP90SFSS Electric...
Replacing smooth top
You said, you broke the top of my stove - how do i go about replacing it? I have a maytag smooth top stove I don't have the model number its torn off the stove was here when I moved in and now its broken and has a big crack in it how do I get a replacement please help.
This is more than likely your ranges model # MER6772 Gemini Electric Kitchen Range
Maytag will be able to replace the top once they come out!
Below is the info and help you asked for!
Thank You , Huuum
Please remember to leave a solved rating before you leave!!
Here is what you asked for!
Call the dealer from whom your appliance was purchased or call Maytag Appliances
Sales Company, Maytag Customer Assistance at 1-888-462-9824, USA to locate
an authorized servicer.
Be sure to retain proof of purchase to verify warranty status. Refer to WARRANTY
for further information on owner’s responsibilities for warranty service.
If the dealer or service company cannot resolve the problem, write to Maytag
Appliances Sales Company, Attn: CAIR® Center, P.O. Box 2370, Cleveland, TN
37320-2370, or call 1-888-4Maytag for PriorityOne Service (1-888-462-9824).
U.S. customers using TTY for deaf, hearing impaired or speech impaired, call
NOTE: When writing
Oct 14, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Replacement of glass top
Check your warranty in the back of your use and care book. If the unit was manufactured prior to 1/1/06 it may have a five year part (not labor) warranty as long as you did not physically abuse it. The glass top comes as an assembled top (glass, the black seal, and the metal frame holding it)
Disconnect power. remove screws under the front edge of cook top. lift cook top and remove crossbars holding burners up against glass top. Unhook cook top / frame assemble. Install new top in reverse order.
Aug 22, 2008 | GE Spectra JBP78 Electric Kitchen Range
Cast iron pans
Cast iron cookware is NOT recommended due to the weight and the potential damage it can cause to the glass top surface. There's nothing better than a good old-fashioned cast iron skillet that's been broken in over a number of years of use, but they are better suited for gas ranges rather than electric. I hate it. I have several cast iron skillets that I only use on the outdoor grill, because I currently own a glass top electric range.
Aluminum bottom pans and copper bottom pans heat well, but can leave metal transfer marks on the cook top surface. If the marks are cleaned after use with an approved stove top cleaner, you shouldn't have any problem retaining the condition of the glass surface, however. Stainless Steel seems to offer good resistance to metal transfer, but takes a little longer to heat than aluminum or copper. have somewhat of a trade off. Baked enamel cookware seems to be the best recommendation because it heats wells and causes the least amount of damage to your glass top surface.
IMPORTANT: Make sure the bottom of your cookware is FLAT. If your pans are warped or bowed, this can cause uneven heat transfer on the heating elements and potentially cause the cook top to crack. Most manufacturers will not replace the top if it still under warranty if it is determined that your cookware caused the problem.
A little over kill, but I hope this helps you.
Feb 14, 2008 | Maytag MER5770 Electric Kitchen Range
Frigidaire GLEF378 Electric Kitchen Range Logo
19 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Barrett Palumbo
Barrett Palumbo
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
