Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
Wont power on
When i turn on my tv, it goes from flashing red to green for about 4 seconds and then it powers down and goes back to flahing red
  • 1 more comment
  • oompa loompa Sep 01, 2007
    We just changed the bulb. After we changed the bulb, it would never power on. HELP.
  • oompa loompa Sep 02, 2007
    now if we hold the button down for 10 seconds it is staying red. but, if we just press power, it still flases green for 4 times, then goes to flashing red.
    found problem.......inspection plate before bulb needs to be on so that tv will power on. thanks for all of the other advice.
    Sergeant:
  • 279 Answers
Sounds like you need a new bulb, or possibly new lamp. The red/green flashing is the warm up to get the bulb ready. If it's shutting down after that, instead of turning on, it means the bulb isn't working - that's a common thing, for the bulb to burn out. Possibly the lamp's bad, but that's much less likely.
Posted on Sep 01, 2007
  • John Goodman Sep 01, 2007
    It won't power on a all after changing the bulb? As in, you aren't even getting the red/green light? That is odd. I'm not sure if a bad bulb could cause that, but it seems unlikely.
    Remove the bulb and put it back in, just to be sure it is fully seated properly. Make sure nothing was knocked loose while you were replacing it (and as silly as it sounds, make sure you didn't accidentally unplug it). If you still have the old, non-working bulb, put it back in and see if you get the red/green lights back. If you do (assuming you're not getting those lights with the new bulb), it has to be a bad bulb you added (or possibly the wrong bulb for your unit).
Why wont my tv turn on it flashes green for a second then goes back to red
Could be power supply failure. It tries to start, but can't.
May 03, 2016 | LG 42LD450 42 in TV
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
TV will not turn on. Red light flashes 4 times
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Mar 07, 2010 | Sony KDS-R60XBR2 Television
TV wont turn on
my TV does the same thing except it is a Sony
KDF-50WE655
Jan 16, 2009 | Polaroid FLM-3225 32 in. LCD Television
Xbox 360 won't stay on
I found this article on Microsoft's website that describes your problem:
http://support.microsoft.com/kb/906101
Dec 30, 2008 | Microsoft Xbox 360 Console
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
120 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
