Question about IBM ThinkPad 770 Notebook
Hi, i had a problem like 4 weeks happen when my computer was updating from "microsoft update".i put it to automatic for it can update by its self,,,right,, so later when it finish updating a box came up and it said "in order to complte this update the computer is going to i press yes..2 minutes computer whent to its original logo and then a window came out and said " something that my computer is going to shut down because of a problem.. ( YOU HAVE TO HELP ME WITHOUT THIS I CANT DO MY HOMEWORK ) THANKS....... ***HERE IS MY YOUTUBE PAGE GO TO IT..I POSTED A VIDEO OF MY COMPUTER PROBLEM*** MY EMAIL IS:
  • IBM Master
  • 12,061 Answers
Ok the best thing is to boot into safe Mode, Press F8, upon boot Up. When it boots into safe mode, select add/remove programs and remove the latest "Updates" and then reboot and see if it is OK? Or you could restore your system to a previous date.. with System Restore. How to below.. You could try "Last configuration that worked" from the Safe Mode menu. Here is a link below showing how to use Safe Mode. Some extra repair tips..
Posted on Sep 01, 2007
0 characters
3 Points
Lenovo Thinkpad T500 windows not genuine
You should just contact Microsoft and tell them what happened. They should help you out.
Jun 12, 2012 | Lenovo ThinkPad T500 Notebook
Need driver
Here is a link to the driver download page. Choose your model and your OS, and it will link you to all drivers for the Thinkpad 770. Please let me know if you need further assistance.
Mar 11, 2010 | IBM ThinkPad 770 Notebook
IBM thinkpad 770 cannot get it to start atall
u may check ram. or motherboard may be damaged. go to any techanician and get it repaired, this fault cant be solved over internet
Dec 18, 2008 | IBM ThinkPad 770 Notebook
IBM Thinkpad 770
Try to format the System using NTFS and if it still says 'corrupted', the Hard Drive is faulty and you will have to get a new one
Hope This Helps
Nov 21, 2008 | IBM ThinkPad T20 2647 Notebook
IBM Thnink Pad R52 Shuts Down unexpectedly
it might be the battery, try plugging it in while doing that.
Jul 09, 2008 | IBM ThinkPad R52 Notebook
CPU Speed too slow
your sys is really so good.
check in task manager identify some unknown proess .
they are virus.
clean all temp files.
disk cleanup run.
scan your sys with avast,quick heal ,symantec one bye obe with update definition in safe mode.
then u get some malware and viruses.
then delete it.
after that run chkdsk utiliity.
then defragmen all drive
now your sys really speed up.
best of luck my friend.
Mar 25, 2008 | IBM ThinkPad T30 2366 Notebook
Please help
We did not find any results for restore it to factory IBM Thinkpad 600e2645. Other searches you may want to try: Related searches This is all i could find/ Sure hope it works for ya.Good Luck.........Please dont for get to Vote/Thank You.
Dec 18, 2007 | IBM ThinkPad 600E 2645 Notebook
Thinkpad 600E
Error 19990301 on a Thinkpad 600 usually indicates that the hard drive is not properly connected, and error code 19990305 signifies "no bootable device". So, it's the hard drive.
First of all, I would try removing and replacing the drive to see if that cures it. You can get the service manual from Lenovo at
If this doesn't fix it, the hard drive is faulty. However, small size hard drives (10 or 20Gb) which suit these older machines are very cheap on eBay.
IBM ThinkPad 770 Notebook Logo
54 people viewed this question
Top IBM PC Laptops Experts
John mullen
 Mike M
Mike M
Level 1 Expert
Are you an IBM PC Laptop Expert? Answer questions, earn points and help others
