Question about Motorola Talkabout T5420 (14 Channels) 2-Way Radio
T5420 manual - Motorola Talkabout T5420 (14 Channels) 2-Way Radio
Can you use a Motorola T5420 with a T5500?
Yes. You would only need to select the same channel and have the interference code set to the same setting on each radio.
Here is a link to the user guides: http://content.giantintl.com/manuals/Moto/T5300_T5400_User_Manual_E.pdf
http://content.giantintl.com/manuals/Moto/T55xx.pdf
Best regards.
Oct 29, 2014 | Motorola Walkie Talkie 2-Way Radio
How to change the side channel or code
Here is a link to the user guide for the T5420 http://content.giantintl.com/manuals/Moto/T5320_T5410_T5420_User_Manual_E.pdf
Programming instructions start around page 15.
Best regards.
Oct 20, 2014 | Motorola Talkabout T5420 (14 Channels)...
What is the frequency range for motorola t5420?
All factory installed frequencies are between 462.000 - 468.000 MHz. They consist of FRS frequencies and some GMRS frequencies.
Here is a link to the User Guide (which does not seem to have a frequency chart) http://www.giantintl.com/ContentManage/manuals/Moto/T5320_T5410_T5420_User_Manual_E.pdf
Best regards.
Apr 05, 2010 | Motorola Talkabout T5420 (14 Channels)...
Lost tranmission capabilities on one of the units, is there a way to reset. Last night it worked fine, turned of at night, tried to use this morning - no output!!! Any suggestions? Model T5420
The only way to really reset this is to remove the power/battery for 8 hours, press power button for 3 seconds, then wait 1/2 hour. Then try it again.
If you need a manual for this radio, you can view it here:
http://www.motorola.com/mdirect/manuals/T5320_T5410_T5420_User_Manual_E.pdf
Nov 15, 2009 | Motorola Talkabout T5420 (14 Channels)...
No transmition
You can find the manual here http://www.giantintl.com/motorolafrsold.htm by using the menu to select your radio model.
You most likely will need to program your radios to match one another. Pay special attention to the interference eliminator code and the the Qt filter (if any). Both radios must match perfectly to communicate.
Apr 09, 2009 | Motorola Talkabout T5420 (14 Channels)...
Unable to download manual for motorola t5420
On the bar just below the web address there is an icon of a floppy disk that says "Save a Copy" next to it. Click on that. A window will open and you can direct it to your Documents , Desktop, or other folder.
Jan 14, 2009 | Motorola Talkabout T5420 (14 Channels)...
Motorola T5420
You possibly have the "code" set differently on one unit. Check your programming, including the Qt filter, if any. Here is a link to the user manual: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5320_T5410_T5420_User_Manual_E.pdf
Jan 12, 2009 | Motorola Talkabout T5420 (14 Channels)...
Can't make the T5420 operate without the beeps!
I have not looked up the T5420 user guide, however, on most Motorola TalkAbouts you hold in the minus (-) button while turning the radio on. Post back if this doesn't work, and we'll find the manual for you.
Nov 17, 2008 | Motorola Talkabout T5420 (14 Channels)...
Motorola Talkabout T5420 (14 Channels) 2-Way Radio Logo
76 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
