SOURCE: My goodman cple18-1c model central
Ths sounds like the outside unit or compressor is not kicking in, check for power to the unit at the breaker box, or at the bottom of the contacts!
SOURCE: ac fan on, blowing air, but not cold
Check outside unit if unit and compressor are running feel the large line to see if it is cold. If compressor is running and line is not cold possible charge problems. You may have a capacitor problem outside. they go out quite often. You can change this yourself, Open up outside unit and the cap is the silver bullet with terminals out the top. Bad cap can cause compressor to not operate and also the fan. You need to clean the coil inside or at leat check the coil to see if it is clean. You can clean theis with a toilet brush do not go against the coil bit brush with the fins. You may need to call a service tech but try these options first. russ
SOURCE: unit not cooling
Low on refrigerant charge! Low side line should be cold like a beer can at the inlet of the compressor with some sweat beads around it. 55deg. The discharge should be around 125deg just hot enough you cant hold it long!
SOURCE: My Goodman Central AC Unit
Hi, have you checked all breakers, fuses in the disconnect box at the outdoor unit as most have them in behind the pull out off plug. Please give me more information on this and I can solve this for you.
Sincerely,
Shastalaker7
A/C,
SOURCE: Goodman Central AC Model #
That is a high pressure safety switch....either the switch is bad or you are running extremely high pressure and need to unit serviced...you should hire a pro to find out the exact cause of your problem...gauges will need to be placed on the unit to determine that exact problem.
heatman101
