Question about Philips pd9016 37 9 portable dual lcd dvd players
Phillips pd9016/37 7 second player keeps saying bad disc
5 Suggested Answers
  • 3 Answers
SOURCE: phillips portable player PET724
I had the same problem with my PET724. I tried cleaning the lens, letting the battery run dead, even beating on it but nothing worked. When I was cleaning the lens again with some cleaning agent I accidentally slid the laser head as far away from the center as it would go. When I loaded another disc it has worked fine ever since. I have played at least two dozen discs so far with no problem.
Hope this helps.
Posted on Jun 10, 2009
projdoc
  • 2236 Answers
SOURCE: my phillips 5.1 dvd player not playing dvd disc, only playing vcd
the laser lens on the optical pickup is dirty or scratched. to clean: buy a disk cleaner and use it per instructions. if it doesn't help, you can do it manually. remove the top, remove the top off of the disk assembly (you may have to remove the whole assembly first) until you see the lens. be careful with the cables and wires. use a lint-free swab (not a q-tip and not your finger), gently wipe off the lens. replace the covers and test. if it still doesn't work, it may be scratched or damaged. in which case, it needs to be replaced.
Posted on Jul 30, 2009
SOURCE: if i insert a disc in the player it says no disc
only use original no coppies
Posted on Oct 06, 2009
SOURCE: my dvd player is not recognizing copied discs or
If someone answer you, or if you found the solution, please, let me know. I have the same trouble.
I need a fast solution-
renquintanilla@gmail.com
Nicaragua
Posted on Aug 24, 2011
Why does my cd player say cd error & make cd skip
cd magazine/ player is going bad. most likely its the springs that keep it balanced while it spins the discs
May 14, 2014 | 1999 BMW 323i
Keep said no disk
It is not seeing or reading the disc, either a dirty or bad optical pickup in the unit----most likely bad and cheaper to buy a new player than fix that.
Dec 06, 2012 | Curtis Sylvania SDVD7014 DVD Player
My dvd player is not recognizing copied discs or original dvds, it keeps saying no disc. It's a Phillips dvp 3960
Nicaragua
Jan 11, 2011 | Philips DVP3960
My phillips HTS3090 system keeps saying BAD DISC
for some reason the unit is not happy with the disc have you tried running a lazer cleaner through it? although i wonder if that will work as the words bad disc does seem to mean a lazer read problem but then it can only be either a dirty lazer or the lazer is miss aligned withch means it need s a pro service .... try cleaning the laser
Jul 03, 2010 | Televison & Video
Says loading disc then no disc pops up and it just won't play. Tried the phillips lense cleaner still does same message (loading the no disc)
The reason the player keeps loading and showing no disc is simply because the lens of the player is weak.
To fix this,
  1. Open the cover of the player with the appropriate screwdriver,
  2. Open the disc tray,you will see the lens, like a crystal or diamond like object,
  3. Replace the lens by removing it with the mechanism that supports it and fixing the new lens,
  4. Test it with a DVD disc.
  5. Cover the player back.
Take care
Jun 21, 2010 | Televison & Video
My dvd player keep saying bad disc. What do I do?
this occurs because of the disc is badly scratched,,so try to clean the disc by a soft colth, even after this the disc shows bad, the disc cannot be used with player,, thank you plz rate me...
Jun 28, 2009 | Daewoo DVRS05 DVD Recorder/VCR
Player justs keeps saying "bad disc" !!
clean your dvd lens with dvd disc cleaner.
May 30, 2009 | Cyberhome CH-DVD 300 DVD Player
Saying no disc
Dirty disk?? Check the disk out make sure it is free of scratches,dirt,residue. You can also buy a DVD cleaner and clean the actual player and see if that is it.
Apr 21, 2009 | Televison & Video
Try to play a disc and the player says ''bad disc''
Have you tried unplugging the DVD player and letting it sit for a couple of minutes? If that doesn't work try holding the power button as you unplug/plug the machine.
Nov 16, 2008 | RCA DRC8052N DVD Recorder
Philips pd9016 37 9 portable dual lcd dvd players Logo
71 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
