Question about Acer Veriton M464 (4718235937997) PC Desktop
I have a veriton 3 years old, it was 1 gb ram and pentium dual core, i want its graphic driver but i cant find it here.could you provide some help here
    New Friend:
  • 31 Answers
The link below will take you to the Acer drivers download page where you will find all the drivers for the M464.
http://www.acer.co.uk/ac/en/GB/content/drivers
Posted on Sep 17, 2013
johnyu_05
  • 141 Answers
SOURCE: graphics card
Hi bob,
Is your onboard video busted? as i check your specs; you have these slots available in your motherboard
2 ( 2 ) x PCI ¦ 1 ( 1 ) x PCI Express x1 ¦ 1 ( 1 ) x PCI Express x16 ¦ 1 ( 0 ) x processor ¦ Memory
base from:
http://www.twenga.co.uk/specs-Aspire-T180-ACER-Desktop-PC-243132
so, you can go to your nearest computer shop and ask them for a videocard that uses PCI Express x16, if its for gaming then go for the higher specs, i can't assist you further with regard to the exact video card model though.
Posted on Jun 26, 2008
Teis
  • 340 Answers
SOURCE: Have a Acer Aspire E380
Your problem can arise from several things:
1. Keyboard not connected,
2. Monitor not connected
3. RAM error (defect RAM)
4. Graphic card defect.
5. HDD error
Solutions:
1. Have a look, check if both keyboard and mouse is mounted tight?
2. Have a look, is it mounted tight?
3. If, you have two blocks, on each 510MB, you swap them around, or, leave one at teh time, fire up, still the beeping, turn it off, take this one out, and put the other in.
If your RAM is one block of 1024MB, you would have to by yet another one to do this (and, it won’t hurt to have 2048MB, only make it faster.
4. Have you got another disk, put it in, Install your OS, and fire up.
If none of the above works, then I hope for you that the warranty is still active.
Regards
/Teis
If, this on the other hand was of some kind of help do vote before you leave, -thank you.
Posted on Dec 15, 2008
  • 461 Answers
SOURCE: Instal new rams to up grade from 1 gb to 2 gb
Either the RAM is not compatible or not inserted correctly. Try removing and reseating both modules, if no change try with only one stick then switch and try just the other to see if the problem is just with one. You could also try resetting the BIOS to factory defaults.
Posted on Jan 05, 2009
  • 415 Answers
SOURCE: acer veriton 5800
Follow the link for driver downloads
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3394#results
Mark
ps. thanks for the rating
Posted on Apr 10, 2009
  • 2386 Answers
SOURCE: Acer aspire m5100, AMD Athlon
Acer official site says:-
Up to 4 GB DDR2 533/667/800 MHz SDRAM
(dual-channel support on four DIMMs)
Try these bus speeds and for dual-channel support read this article :-
Dual-channel architecture requires a dual-channel-capable motherboard and two or more DDR, DDR2 SDRAM, or DDR3 SDRAM memory modules. The memory modules are installed into matching banks, which are usually color coded on the motherboard. These separate channels allow each memory module access to the memory controller, increasing throughput bandwidth. It is not required that identical modules be used, but this is often recommended for best dual-channel operation. It is possible to use a single-sided module of 512 MB and a double-sided module of 512 MB in dual-channel configuration, but how fast and stable it is depends on the memory controller.
If the motherboard has two pairs of differently colored DIMM sockets (the colors indicate which bank they belong to, bank 0 or bank 1), then one can place a matched pair of memory modules in bank 0, but a different-capacity pair of modules in bank 1, as long as they are of the same speed. Using this scheme, a pair of 1 GB memory modules in bank 0 and a pair of matched 512 MB modules in bank 1 would be acceptable for dual-channel operation.
Modules rated at different speeds can be run in dual-channel mode, although the motherboard will then run all memory modules at the speed of the slowest module. Some motherboards, however, have compatibility issues with certain brands or models of memory when attempting to use them in dual-channel mode. For this reason, it is generally advised to use identical pairs of memory modules, which is why most memory manufacturers now sell "kits" of matched-pair DIMMs. Several motherboard manufacturers only support configurations where a "matched pair" of modules are used. A matching pair needs to match in.
Good luck
Rate the solution if got help
Posted on Dec 06, 2010
Is this going to be surfice?
Yup this used pc has a superior processor running at 2.8 Ghz, more ram, and a better video card. Also windows 7 is a 64 bit system and it runs better even on slower pcs because its more compatible for dual core processors. Enjoy your faster pc.
Jan 23, 2014 | Computers & Internet
Which is the best graphic card for intel DG41RQ mother board
I have a motherboard intel dg41rq and intel core 2 duo E7200 and nvidia geforce 9500 GT and 4gb ram (DDR3).It will work with call of duty black ops 2 and FIFA 13.So your done.
Oct 02, 2012 | Intel DG41RQ Motherboard CPU Bundle - ...
I can't install AUTOCAD 2009 in my windows XP computer.It asks to install direct 3D
Most probably your hardware ie graphic card do not support software requirements.
Autocad 2009 system requirements for Win XP.
32-bit AutoCAD 2009
Running under Windows XP:
•Microsoft Windows XP SP2 operating system
•Intel® Pentium® 4 processor or AMD Athlon®, 2.2 GHz or greater
or
Intel or AMD Dual Core processor, 1.6 GHz or greater
•1 GB RAM
•750 MB free hard disk space for installation
•1024x768 VGA with true color
•Microsoft Internet Explorer 6.0 (SP1 or higher)
If you are using AutoCAD for 3D modeling, you should bump up your system as follows:
•Intel Pentium 4 processor or AMD Athlon, 3.0 GHz or greater
or
Intel or AMD Dual Core processor, 2.0 GHz or greater
•2 GB RAM or greater
•2 GB of additional free hard disk space
•1,280 x 1,024 32-bit color video display adapter (true color) 128 MB or greater, OpenGL or Direct3D capable workstation class graphics card.
Hope it helps.
Mar 22, 2011 | Computers & Internet
Pasos para instalacion de web camvx2000
Hola amigo primero que nada devemos saber que systema operativo usa tu computador Windows Xp Vista or Windows 7
Esta Web cam es configura automaticamente per piensa tambien en los requerimientos del su systema. aqui algunos tips.
Habla en espanol y solo pregunta ok
Techbelkin
System Requirements Operating System For Windows®-based PC
Requires a PC that meets the requirements for and has installed one of these operating systems
Processor Windows® 7
Mmimimum: Intel Pentium 4 (3 GhZ), 1 GB of RAM; recommended: Intel Pentium (Dual-Core 1.8 GHz), 2 GB of RAM, 1250 MB free Windows Vista®
Windows® XP with Service Pack 2 (SP2) or later
Other CD-ROM
USB 1.1 (2.0 recommended)
16-bit color depth or higher, 2 MB or higher video memory
Windows-compatible speakers or headphones Internet Broadband Internet access may be required for certain features. Local and/or long-distance telephone toll charges may apply.
Internet functions also require Internet Explorer® 6/7 for installation; 25 MB hard-drive space typically required.
Nov 03, 2010 | Microsoft LifeCam VX2000 Webcam
I want to buy a laptop. Please suggest me which processor is best? ie. Intel pentium processor or intel pentium dual core processor? Will intel pentium dual core processor overheat easily?
hello,,,,,,,,,,,,,
First you need to be clear that dual core is the family of Pentium series. so there is no processor called Pentium.............. now regarding your question i would suggest you do not go for dual core... Take core 2 duo or I3 /I5/I7 series of processor..............
I am giving you a configuration in a good budget
Rs 50,800/-
Intel 3 GHZ Core2 Duo Processor,3 GB DDR2/DDR3 RAM, and a 250/320/500 GB HDD. DVD writer, 15.4-inch display with a resolution of 1280 x 800 dpi. integrated Intel Graphics Media Accelerator X3100 video card, integrated modem and sound card, Wifi, Touchpad mouse and in-built speakers. It has interfaces like Express Card slot, S-Video port, 4 USB ports, Firewire port, bluetooth and a 6 in 1 Digital Media Reader. The laptop comes with an inbuilt camera .
It would be better if you can tell me your budget ............... So that i can give you a good configuration ......................
Jun 14, 2010 | Computers & Internet
I can upgrade to windows 7 in my n1000
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Personally i would recommend to upgrade ram then install win 7
Regards
Uttam
Windows 7 requirement If you want to run Windows 7 on your PC, here's what it takes:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
http://www.microsoft.com/windows/windows-7/get/system-requirements.aspx
Here is you laptop spec
Processor Processor Intel Pentium M 733 / 1.1 GHz
  • Core voltage technology Ultra Low Voltage (ULV)
  • Data bus speed 400.0 MHz
  • Processor features Enhanced SpeedStep technology , Power-optimized processor system bus
  • Chipset type Intel 855GME
Cache Memory Type L2 cache
  • Cache size 2.0 MB
RAM Installed Size 512.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM - 333.0 MHz
  • Memory specification compliance PC2700
Video Graphics Processor / Vendor Intel Extreme Graphics 2
  • Video Memory Dynamic Video Memory Technology 2.0
Operating System / Software
  • OS Provided Microsoft Windows XP Professional
  • Software Drivers & Utilities
Dec 10, 2009 | Averatec 1000 Notebook
Sims 3 keeps crashing
Maybe you have enough video memory, but the way your video card processes all the graphics is less than enough to what SIMS 3 requires.
Please take a look at the sims 3 requirements and read the review about your laptop below.
EA has released the minimum system requirements for The Sims 3, which is out on February 20.
The specs, which emerged on site Gaming Today,show both desktop and laptop minimum requirements, though it should bestressed that the game probably won't run like butter on these rigs.
See the specs below:
PC / Desktop
XP (Service Pack 2)
Pentium IV 2.0 GHz / Athlon XP 2000+
1 GB Memory
Graphics
GeForce FX 5900 / Radeon 9500
Graphics Ram
128 MB
Vista (Service Pack 1)
Pentium IV 2.4 GHz / Athlon XP 2400+
1.5 GB Memory
128 MB Graphics RAM
Laptop
XP (Service Pack 2)
Processor Pentium IV 2.4 GHz / Athlon XP 2400+
1.5 GB Memory
GeForce Go 6200 / Radeon mobile 9600
128 MB Graphics RAM
2.0 GB Memory
128 MB Graphics RAM
This is Situation Publishing Ltd. review:
With the advent of Intel's Core 2 Duo processors we're at lastbeginning to see the kind of power and portability that was beingclaimed, somewhat optimistically, back in the early days of notebookcomputing. Not one to miss out, Dell has rolled out its Core 2 Duobased Inspiron 6400...The 6400, like so much of the Dell range, comes in a variety ofuser-defined guises so bear this in mind when it comes to theperformance numbers and features I'll be making reference to. Indeed,in the time we've had the notebook, a Dell special offer has upped thememory to 2GB from the two 512MB modules of DDR 2 SDRAM featured in ourversion.
Our particular model also came equipped with Intel's impressive newmobile Core 2 Duo processor, the T7200, which ticks along at 2.0GHz offa 667MHz frontside bus. 4MB of shared L2 cache helps speed things alongtoo. Like the entire mobile range of Core 2 Duo processors it operatesat between 1.0375V and 1.3V and runs comparatively cool for its speed.
Furthermore, our test unit arrived with an ATI Mobility Radeon X1400graphics chip and not the X1300 currently offered on Dell's website asstandard for all but the most basic version of the 6400. The X1400upgrade will set you back around £47 and is probably worth the extramoney seeing as the X1300 combined with the 15.4in WSXGA+ screen willnot be compatible with Windows Vista. In addition all models - again,except the basic one - now come equipped with an 8x dual-layer DVD°R/RWdrive. The hard disk is a Samsung 120GB SATA unit which should fend offobsolescence over the life of the notebook
VerdictWith a base price - for the T7200 Core 2 Duo - of £789 inc. VAT andshipping, the Inspiron 6400 is an excellent and affordable route intothe Core 2 Duo world. It has all the credentials to be a dependablemultimedia companion with its great screen, comprehensive connectivityand decent processing power. But be aware it's neither exciting to lookat nor to game on!
Best of luck
Jun 25, 2009 | Dell Inspiron 6400 Notebook
Still lagging in WoW!
Answered originally by TimIsHectic:
Assuming you mean a bad framerate and not actual 'lag', the problem would appear to exist in your processor, as it is old and outdated. and only just fits the minimum requirements to RUN THE GAME, not run the game well.
Answer: You should upgrade your CPU to a Pentium Dual-core at least.
WoW System Requirements
Processor:
Minimum: Intel Pentium 4 1.3 GHz or AMD Athlon XP 1500+
Recommended: Dual-core processor, such as the Intel Pentium D or AMD Athlon 64 X2
Memory: Minimum: 512 MB RAM (1GB for Vista users)
Recommended: 1 GB RAM (2 GB for Vista users) Video: Minimum: 3D graphics processor with Hardware Transform and Lighting with 32 MB VRAM Such as an ATI Radeon 7200 or NVIDIA GeForce 2 class card or better
Recommended: 3D graphics processor with Vertex and Pixel Shader capability with 128 MB VRAM Such as an ATI Radeon X1600 or NVIDIA GeForce 7600 GT class card or better
May 03, 2009 | Blizzard Entertainment World of Warcraft...
Problem wid Nvdia G force 7000m
hi!good pm...hope this will help...
go to the control panel>display>settings>check the screen resolution (pixels) & color quality...
Feb 05, 2008 | Computers & Internet
Acer Veriton M464 (4718235937997) PC Desktop Logo
104 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
