Question about Belkin N450 Wireless N Router
Faint purple light communicating modem - Belkin N450 Wireless N Router
How can I obtain a user guide for Acatel optus one touch 250 P/N16513 corded phone?
Optus Network Approved modem and equipment list
If you are supplying your own DSL modem and/or telephone filters, you must ensure they meet the requirements
below before connecting them to the OptusNet DSL network. Connection of unapproved equipment is prohibited.
The modem list contains equipment that has been certified by manufacturers as having passed interoperability tests
r
equired for use on a DSL network. If your modem make and model isn't listed below,
call Optus Customer Service for further information on
1300 309 333.
F
ully supported by OptusNet DSL Broadband Customer Service, the OptusNet DSL Broadband Installation CD-ROM will automatically
c
onfigure this modem.
D-Link ADSL Modem 302G
The OptusNet DSL Broadband Installation CD-ROM provides detailed information to manually configure these modems, and OptusNet
DSL Broadband Customer Service will provide limited connection support for them.
(Equipment Certification date in brackets)
F
or modems and routers other than those above, OptusNet DSL Broadband provides only the network connection settings needed for
manual configuration. While this equipment can be used on the OptusNet DSL Network, no OptusNet DSL Broadband Customer Service
will be provided for connection configuration or equipment-related connection difficulties.
Alcatel SpeedTouch - 510 ADSL Modem (15.01.2003)
Alcatel SpeedTouch - 530 ADSL Modem (15.01.2003)
Alcatel SpeedTouch Pro - 4 port (10.09.2001)
Alcatel SpeedTouch Pro - Firewall (09.10.2001)
Alcatel SpeedTouch PCNIC (04.08.2000)
Alcatel SpeedTouch USB (04.08.2000)
Askey/Dynalink - ALE 070 (08.01.2001)
Askey/Dynalink - ALH 110 (21.03.2001)
Askey - RTA100 ADSL Modem (25.10.2002)
Billion Electric - BIPAC-711 CE ADSL Modem (25.10.2002)
Cisco WIC - 1ADSL-DG (30.06.2003)
Cisco 827 (19.02.2001)
Cisco 827H (11.07.2002)
Cisco 827-4V (19.02.2001)
Cisco 837 (01.04.2003)
Cisco SOHO77 (29.11.2001)
Cisco SOHO77H (11.07.2002)
Cisco SOHO97 (01.04.2003)
D-Link ADSL Modem - DSL 100D (08.08.2001)
D-Link ADSL Modem - DSL 500 (08.08.2001)
D-Link ADSL Modem - DSL 504 (08.08.2001)
Efficient Networks - C10 Communications - Speedstream 3060 (08.01.2001)
Efficient Networks - C10 Communications - Speedstream 4060 (08.01.2001)
Efficient Networks - C10 Communications - Speedstream 5260 (08.01.2001)
Efficient Networks - Siemens - Speedstream 5400 (07.04.2003)
Efficient Networks - C10 Communications - Speedstream 5660 (21.03.2001)
Efficient Networks - C10 Communications - Speedstream 5667 (10.09.2001)
Efficient Networks - C10 Communications - Speedstream 5861 (21.03.2001)
Juni NetAce - ADSL USB Modem (15.01.2003)
Juni NetElite 2000ES - ADSL 4 port Modem (15.01.2003)
Juni/Samsung SAM-215 USB Modem (18.07.2001)
Juni/Samsung SAM-335A Ethernet Modem (18.07.2001)
NetComm ADSL Modem - BusinessSmart (08.08.2001)
NetComm ADSL Modem - USB - NB1200 (27.08.2002)
NetComm ADSL Router Modem - NB1300 (20.11.2002)
Open 501r ADSL Router Modem (05.04.2002)
Alcatel - Central, Part No. 3AU 04804 AAAA
Alcatel - In-Line, Part No. 3AU 04805 ABAA
Askey/Dynalink - In-Line, DT60-002BA
C10 Communications - Dynamic - In-Line, C10290
C10 Communications - In-Line, C10611 & C10611T
C10 Communications - In-Line, C10645 & C10645T
C10 Communications - In-Line, C10610
Te
l
ephone Equipment - Central, TE-ACP20AUS01
C10 Communications - In-Line, C10211
C10 Communications - In-Line, C10111
C10 Communications - In-Line, C10145
C10 Communications - In-Line, C10245
D-Link - Central, DSL-10SP
D-Link - Central, DSL-10CF
D-Link - In-Line, DSL-10MF
Alcatel SpeedTouch Home
D-Link ADSL Modem - DSL 200
D-Link ADSL Modem - DSL 300
D-Link ADSL Modem - DSL 300+
D-Link ADSL Modem - DSL 302G
Optus supplied modem
Optus preferred modems
List of all other certified modems/routers
List of certified filters/splitters
Information correct as at 2 February 2004.
1270049 06/04
Nov 12, 2014 | Cell Phones
Is my modem is blinking is this normale
The POWER light should be 100% on.
The WIRELESS light should blink -- hunting for wireless devices, and communicating with them.
The NETWORK ight should blink when there is activity to/from the internet.
May 17, 2014 | D-Link DSL 200 (DSL-200) Modem
No lights showing
I would turn both the modem and the router off. Then turn the modem on and let it cycle up for a minute or two. Then turn the router on and let it cycle up. The router always has to boot up after the modem since it is dependent on the modem.
If it does not work, then either your router is bad or your internet service has been interrupted.
Jun 05, 2012 | Zoom 4506 Router
Dsl light goes beyween blinking green, then goes solid red, then back to blinking green. Cannot connect to internet anymore.
The modem cannot get a signal from your service provider. The DSL light is an indicator if your modem is communicating with the network of your service provider. DSL light should always stay solid green. Try contacting your service provider. It might also be an indication of a bad modem.
Aug 31, 2011 | Arris 221002 DSL Modem Southwest Region...
I can't get online to google or anything because the laptop will not come out of the offline.
If you are on a wireless network with a router, power cycle all your equipment to get it back in sync with each other.
1. Turn off the power to your router( 1st) , your modem (2nd) and pc (3rd). in this order. Wait a few min.
2. Take out the ethernet cable from the router (until your modem reacquires a signal to the internet) and if the pc is connected to the router unplug the Ethernet cable from the back of the pc.
3. Turn on the power to your router wait for all the lights to come back up. Then turn on your modem and wait for all the lights to come back up and reacquire a signal. Once all the lights are on the modem, plug the ethernet cable back into the Internet jack of your router.
4. Turn on your laptop. After Windows loads and you get to your desktop, plug the Ethernet cable in to the back of the pc( if you connect wired) or try to connect to your wireless network.
5. Then open your browser and type in this web address:
http://www.purple.com
if a purple page comes up-You are connected to the Internet.
Apr 21, 2011 | Computers & Internet
Why does the i light flash
I light flash whenever there is data communication between router and modem
i light goes orange whenever there is no communication between router and modem or not getting interner from modem to router
Feb 13, 2010 | NetGear DG834G Router
Faint black bar rolling from the bottom
if the bar is black or purple you can try to use a ground lift plug and see if your having a grounding issue.
Jan 15, 2010 | InFocus ScreenPlay 4805 Multimedia...
How to reset moorola modem sb1520 surfboard
hi, to reset the modem follow these steps.
step 1 : Turn the Motorola Surfboard SB5120 Cable Modem so that the back of it is accessible to you. There's no need to disconnect any of the cables.
step 2 : Find the "Reset" button on the modem. It's a small recessed button located between the USB port and the cable outlet.
step 3: Use a pointed instrument to push the button. Hold it for 10 to15 seconds to allow time for the modem's indicator lights to go off.
step 4 : Release the Reset button. The lights will gradually begin to come on as the modem connects to the communications channels between the cable provider, the computer and the Internet provider. When all the connections are made, the lights will stablize.
step 5 : Release the Reset button. The lights will gradually begin to come on as the modem connects to the communications channels between the cable provider, the computer and the Internet provider. When all the connections are made, the lights will stablize.
Nov 22, 2009 | Arris SURFboard SB5120 Modem
Service 4wdrive
Unfortunately You need to read the codes for the Transfer Case Control Module. The Diagnostic codes will help you in the direction to repairing this problem. The switch light goes out when there is a problem and the Transfer case switch is disabled.
Thank You,
Roy
Aug 05, 2009 | 2007 Chevrolet Silverado 2500HD
Belkin N450 Wireless N Router Logo
97 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
