Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Bad cooling fan - Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
    New Friend:
  • 3 Answers
I had this issue at the 2 year mark and i had to change the fan. Still works great till today (a year later)
Posted on Sep 17, 2013
Cooling fan is ok by cpu so cool
Still could be bad power supply even though the cooling fan is working. Recommend replacing the ps first since they are fairly cheap. If that does not work then the CPU is bad and needs to be replaced
Jul 04, 2016 | Gigabyte GA-G41M-ES2L Motherboard
I have a 94 plymouth sundance 6 cylinder the fan that cools he radiator is not working what is he problem
3liter 6cyl? (5 or 6 engines used, 2.2L up to 3.8)
in all cases (engine rad cooling fan) (seems not)
clutch fan failure? (if old mech. type fan) replace it.
if electric fan?
  1. bad control sensor.
  2. bad controller
  3. bad fan relay
  4. bad fan
  5. bad wire/ connections between them.
what we do is get it hot and see if fan works at the FSM stated trip temperature. (225F is a guess, ) alldata.com has this number too.
if the fan is dead, we check voltage the fan, 12v ? fan is dead.
0 volts? yes, then control is bad.
the work backwards from here, finding true cause. easy huh?
any cheap voltmeter made works .
the ECT is for the engine. EFI system. TBI?
but the Fsm states.
All models equipped with electric cooling fans use this sensor to control the cooling (radiator) fan operation.
i dont have the wiring set for this car.
try alldata.com and use that for fan wiring ,etc.
Mar 12, 2014 | 2003 Suzuki Aerio
Cooling fans are not coming on, what could be the problem?
Either the temp sensor is bad, or the relay is bad. or the fan motor is bad. Or you have a blown fuse.
Look for fuse first.... To test if fan motor is bad disconnect the connector to the fan and jumper it to the battery.if it spins it's good. the other two. use a component locator to find their location and replace. they are inexpensive. Temp sensor is in the cooling circuit (radiator...maybe next to thermostat) the relay will be in a fuse box under the hood.
Oct 25, 2012 | 2003 Suzuki Aerio
1985 new yorker cooling fan won't operate.
could be a bad coolant tempurature sensor if radiater cooling fan does not work, or a bad relay for fan in fuse box for the fan.. if all is ok ! disconnect fan at the connectors. on the motor side, run a wire from positive on battery, to pos itive fan motor. ground other wire to negative on battery. if the fan works its ok. good-day ! check relay and fuse for the fan first.
Feb 01, 2012 | Dodge Vehicle Parts & Accessories
95 lexus es300 over heats when ac is turn on
Is your radiator cooling fan operating when the A/C is turned on? The cooling fan should be running at all times with the A/C on. If it does not, then your problem is being caused by a bad cooling fan motor, a bad cooling fan relay, a broken fan motor circuit, or broken fan control circuit.
Aug 27, 2011 | Lexus ES 300 Cars & Trucks
2001 buick lesabre is running slightly hot. i just replaced the thermostat and 2 elbow joints (sorry dont know what their called) and did a complete flush about a month ago
replacing the thermostat is exactly what i would have suggested for your vehicle for the overheating issue. try this,with the engine running at operating temperature,check to insure that the cooling fans coming on when the engines gaining temperature. your cooling fan may be going bad and not coming on when needed,in this case it may be a bad cooling fan sensor,or just a bad cooling fan altogether.with the engine running after you've driven the car until it gets warm,open the hood and look visually at the cooling fan to insure it's running{the engine fan} in front of your radiator. if it's not running {fan} check in the main fuse box under the hood for a bad engine fan relay 1st if no bad relay,then check for a bad engine fan motor.with the key switch in "off"position try to spin the engine fan manually by hand. if it does spin by hand it still may be a bad fan motor. or bad fan sensor.do you have a check engine light on? if so you can have it code read at any auto zone or advance auto for free.this may be of great assistance to you if the check engine light is on. hope this helps and thank you for choosing fixya.com
Mar 24, 2011 | Buick LeSabre Cars & Trucks
Cooling fans not working
Nonfunctioning engine cooling fans could result from a broken electrical connection (not hooked up, not grounded, loose ground, or a blown fuse) or a bad fan relay. It is unlikely for the motors of both fans to go bad simultaneously.
Nonfunctional interior cooling fan could result from a blown fuse or a bad climate control switch.
Jan 08, 2011 | 1999 Chevrolet Malibu
How do i check the cooling fan my car is over heating
HOT WIRE COOLING FAN USING JUMPER WIRES TO BATTERY.IF FAN DONT RUN WHEN HOT WIRED FAN MOTOR BAD NEED REPLACING. IF FAN RUN WHEN HOT WIRED. CHECK COOLING FAN FUSE AND RELAY.IF ALL IS GOOD.YOUR ENGINE COOLANT TEMPERATURE SENSOR NOT WORKING.IT CONTROL COOLING FAN AT SET TEMPERATURE IF SENSOR OPEN OR FAULTY THE COOLING FAN WONT TURN ON.CHECK COOLING FAN WIRES FOR DAMAGE.IF ALL STILL CHECK OUT GOOD HAVE VECHICLE SCANNED FOR PCM FAULT.IF IT FAILS NO COOLING FAN WONT TURN ON.
Dec 13, 2010 | Hyundai Elantra Cars & Trucks
Radiator fan motor does not run
1. check the cooling fan fuses
2. supply battery voltage directly to the fan assembly plug
a. if fan is good
locate and test/replace cooling fan relay
b. if bad
replace cooling fan assembly
if still is not working check continuity cooling fan system circuit/wiring
Aug 19, 2010 | 1999 Nissan Quest
Fans not working right
MOST OF THE TIME IF THE COOLING FAN FAILS TO OPERATE.THE COOLING FAN RELAY OR FUSE IS BAD.ALSO THE COOLANT TEMPERATURE SENSOR IS OPEN.THE COOLANT FAN WONT TURN ON.TO HELP YOU PIN POINT YOUR PROBLEM.GET IT SCAN.IT WILL TELL YOU IF THE COOLING FAN CIRCUIT IS WORKING OR YOU HAVE A BAD COOLANT TEMPERATURE SENSOR.YOU NEED THESE TWO COMPONENTS TO GET YOUR COOLING FAN TO OPERATE AUTOMATIC AGAIN.
Sep 18, 2009 | 1990 Ford Taurus
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
54 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
