Question about Sharp MX-2300N Color Copier
Sharp MX-2300N Error code H2-02. How do I upgrade the firmware? No firmware to download. How can I reset the system?
    Habit-Forming:
  • Sharp Expert
  • 190 Answers
No need to upgrade .Just clear error.
Posted on Jan 07, 2014
SOURCE: error code h5-01
Yes H5-01 is when it jams in the fuser 5 times in a row, check the fuser section for a jam, the paper jams up in there and does't trigger any sensors, once you have confirmed that its clear reset with sim code 14
Posted on Jun 01, 2008
  • 24 Answers
SOURCE: Sharp MX-2300N Reset
Type in "p" "*" "C" " *" (that is p button, star button, p button, star button.) the machine will go into sim mode enter 14 then press execute which appears on the lcd and the yes to confirm, then press CA and the machine should turn off then back on again
Posted on Sep 12, 2008
  • 3 Answers
SOURCE: Sharp MX-2300N Maintenance required.code:TA
Maintenance TA is indicating the machine has reached its 100K scheduled service interval. It requires Transfer Belt Unit, Usually Black Drum & Developer, any feed rollers wornout replaced, any old firmware updated to latest version, and a general clean & check. It is reset in service mode once these parts are replaced.
Posted on Dec 26, 2008
007tech
  • 95 Answers
SOURCE: sharp mx-2300N printer error maintenance required
VK means black developer has reached end of life. You can safly carry on using the copier with this message displayed but over time the copy quality may slowly degrade. You will need to call a Sharp authorized dealer to replace the developer in the developer unit.
Posted on Jan 15, 2010
  • 14 Answers
SOURCE: Sharp MX-2300N with error code H3-00. . how do I
Ensure you are in COPY mode
press # * C * ( one after the other, fairly quickly)
when the screen changes enter the number 14 on the keypad
press the B&W start button
press 1 for Yes when the question displays
press thw CA button
machine will re-boot and fault should clear. If it doesnt you need a service engineer. This is a fuser temperature fault
Posted on Mar 09, 2010
Still having the problem of F2-64 error code for sharp mx 2300n I need the solution please
For support, the User Manual, and other documentation for your MX 2300n, go here:
http://siica.sharpusa.com/product-downloads
Good luck.
Dec 27, 2017 | Miscellaneous
A LOUD NOISE WHEN I TURN ON MY COPIER SHARP MX-2300N AND IT CAN NOT COPY OR PRINT
Hi Patience .
Have you got anything on the display ?
Any error codes ?
Jun 27, 2016 | Sharp Office Equipment & Supplies
Sharp MX-2300N error DK - which drum part number?
It looks like they are the same regardless what color you need to replace. Just buy one and go with it. Here is an example from amazon: http://www.amazon.com/SHARP-MX-2300N-1-COLOR-DRUM-MX27NUSA/dp/B00AA961GI/ref=sr_1_2?s=electronics&ie=UTF8&qid=1425339155&sr=1-2&keywords=sharp+mx2300n+drum
You can also contact a local specialized provider such as Cartridge World who can find exactly what you need for you.
Mar 02, 2015 | Sharp MX-2300N Color Copier
Sharp mx 2300N error code H5-01
http://www.copytechnet.com/forums/sharp/76512-sharp-mx-2300n-error-code-h5-01-a.html
Feb 15, 2015 | Sharp MX-2300N Color Copier
How do I fix the error code 'U2-30'on my Sharp MX 2300N color copier?
please reset the machine by eject the power and data cable for a one minute and also re installer the printer driver
Nov 22, 2014 | Sharp MX-2300N Color Copier
How do I get firmware program for Sharp MX-2300N color copier?
http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx?downloadtype=Driver&category=DocumentSystemsMFPsPrinters&model=MX-2300N&
Sharp mx 2300N error code U2-41
The U2 errors are usually related to memory or board level issues. You should try to disconnect the fax and network and then kill the main power inside the cover. Turn the main power on and then when you get a solid green light on the control panel press that power switch. If the machine boots with everything disconected then try conecting the options one at a time and try rebooting each time to see if you can narrow down the problem.
I’m happy to help further over the phone at https://www.6ya.com/expert/ethan_e84416e0b13809d2
Oct 16, 2014 | Sharp MX-2300N Color Copier
Mx-2300n firmware
The firmware is only available from a dealer. You can make an arrangement to get it on a USB thumb drive and update the machine using SIM 49
Apr 19, 2014 | Sharp MX-2300N Color Copier
How can I reset the system to remove an error code of H2-02? I looked the error code up and found that the firmware needed to be updated. Need to know how to do that as well. We have VBS this coming...
No need to stress.Remove all paper jam first and make sure no piece of paper is left inside.
Then press #*c* and you will enter simulation mode and press 14 and execute yes and when finish please restart machine.OK
Aug 02, 2013 | Sharp MX-2300N Color Copier
Network printing from a mac computer to sharp mx 2300n printer
HI,
Sounds like driver problem..
go to this site: Driver Update and make required updates.
wish you best of luck
cheers
Dec 17, 2008 | Sharp MX-2300N Color Copier
Sharp MX-2300N Color Copier Logo
351 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
