Bryant model 607cnx - Heating & Cooling
Model numbers for Bryant AC difference between a model pa4zna048 & a rspma48
The difference is the sticker on the outside of the unit and the slightly higher price for parts on the Bryant. Go with the Rheem but don't be mad at me when it breaks down, the Bryant will too. Honestly it's luck!!!
Aug 30, 2017 | Bryant Heating & Cooling
What seer and tonnage is a Bryant condenser unit model # 561CJ048 and serial # 4598E06708?
According to the specifications here: http://dms.hvacpartners.com/docs/1009/public/01/pds561c.18.10.pdf , all Bryant 561C air conditioners are 10 SEER. The 048 model has a 4 ton nominal cooling capacity.
I hope this helps.
May 04, 2017 | Bryant Heating & Cooling
Model 393 Bryant furnace fan or motor makes noise when first starting. Then it's quiet.
https://www.repairclinic.com/PartDetail/Bryant-Furnace-Dual-Run-Capacitor/P2914553RS/2386586?ss=a36b380&mr=0
That part is probably going bad. The motor uses it to get moving and when it fails then the motor wont start, makes buzzing or humming noise due to phase loss.
Jan 28, 2017 | Bryant Heating & Cooling
Bryant model 394GAD manual
The manual can be downloaded here: http://www.bobsmanuals.com/Household/Heating_and_Air_Conditioner/Bryant/394GAD/manual/
Jan 09, 2012 | Heating & Cooling
Manual for model no. 234c 5pw bryant boiler
I have a bryant boiler in my home and been having a plumbing co work on it since spring and they replaced the 3 speed pump with a single speed now cant get it to push air out of system
Nov 08, 2010 | Bryant Heating & Cooling
Bryant outdoor model # 567A-018E it humms like
open up it is probably the contractors. and easy fix you can push them down manually but be careful they are HOT- LIVE.if not sure call someone who does!
Jun 26, 2009 | Bryant 462AJC021BA Air Conditioner
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
