Question about Sony RCD-W500C 5-Disc CD Recorder
5-Disc CD Player (NS- CD512) Can't get player to power up 12K02NSCD512026543
  • 112 Answers
SOURCE: sound from only one channel
If there is a headphone output on the unit try listening through it to see if the sound is in both channels. If so,it is likely a dry / fractured solder joint on or near the jack connector. If not it could point to a failure of the digital -> analogue convertor IC chip.
Posted on Jan 25, 2008
AREA51S4B
  • 30 Answers
SOURCE: my cd player does not recognize discs.
this could be several things , one would be the cd spindle motor, needs to be cleaned, if it starts out sluggish and then reads..it needs to be cleaned..this can as simple as spraying some contact cleaner into the motor
Posted on Jul 28, 2009
smarthome2
  • 1114 Answers
SOURCE: disc(s) jammed in sony 5-disc player--eject won't work
There are 6 or 7 phillips head screws that keep the top on; remove them and pop the top. This will give you access to all CD's. Remove them all, then plug the unit back in and press the open close button and check for normal operation. If it still wont open, it's broken a gear and needs to be serviced. You may consider replacement of the unit if inoperative, the replacement model is priced at $129.00 and a repair would probably cost the same if not more. If you need further help, post a comment and I can help you further.
Posted on Dec 22, 2009
  • 1340 Answers
SOURCE: I have a 5 disc
It needs a new laser,also called an optical eye.Since you cleaned it and that did not help,definitely.If the optical eye is bad,no disc will read and it will do just as you described,search and search all day.Probably close to $100 minimum to send it somewhere and have it fixed.When I was doing repair about 12 years ago,the eye alone was about $60.The shop normally has a parts price markup of 20%,then S&H and labor.I looked for a more accurate price on a few sites but couldn't find one.Optical eyes are somewhat universal though so they should be able to do something somewhere.Here is Sony.Good luck,Greg
http://esupport.sony.com/
Posted on Dec 02, 2010
gopakumarg43
  • 74245 Answers
SOURCE: cd player won't spin disc
HelloCheck the sled motor. it is the motor that spins the disc inside, as soon as it has been loaded. Check the voltage comes to the leads of the motor first. If the voltage is there, and the motor does not spins, repalce the motor. It is a stepper motor, can be bought from most of the electronic spare part shops at your town. it is not a very colstly component. OK.
Posted on Dec 21, 2011
What adapter to use for for CD player Insignia ns p5113?
Hi there, Check near where you plug the adapter into the cd player, it should tell you what power input it requires - 6 volts or something, then head to your nearest elctrical store and find a replacement.
Aug 06, 2014 | Insignia Portable CD Player with Digital...
I LOST MY INSIGNIA DRIVER CD
Software for the NS-DV2G player is available under Software / Downloads. See next link:
http://insigniaproducts.com/products/portable-audio/NS-DV2G.html?supportTab=open
Manual for this player ( pdf file, readable with Adobe Reader ):
http://insigniaproducts.com/cms/documents/NS-DV2G%20UM%20EN.pdf
Jul 29, 2010 | Insignia NS-DV2G MP3 Player
My Insignia CD player says there's no disc when there is.
Try a lens cleaner. Also, ensure that your disks are clean. If you're playing CD-Rs, make sure that the disks have been finalized properly. If the problem persists, you may carry the unit in to the place of purchase to pursue service options.
Mar 16, 2010 | Insignia NS-DV2G MP3 Player
Insignia blu-ray player only plays music cd'
I would need to know which Insignia Blu Ray player you have to get a better idea of what potential problems you may be experiencing. Model number should be NS-XXXXXXX.
It sounds like the loader is failing, the lens is scratched/dirty, or the firmware isn't performing properly.
Recomendations:
Try using a Blu-Ray cleaning kit to clean the lens. Don't use a CD or DVD cleaner kit since these are too harsh for the Blu-Ray lens.
Try updating the firmware to the latest version by going to www.insigniaproducts.com and searching for your model number. Updates allow for more functionality of your player as well as greater compatibility with Blu-Ray discs and other disc formats.
Hope this helps!
Dec 26, 2009 | Insignia NS-BRDVD Blu-Ray Player
It keeps saying unknown disc,every time i put a disc in there every disc that i put in the player...it will not play it...it keeps saying Unknown-disc...including an audio-disc.
hi, try first to insert a clean up CD, and test your Cd or Dvd player with an original CD or Dvd, if the problem persist , your laser sense is defficient you have to go to fix it to a specialist.
hope this helps you
Sserpentio
Apr 12, 2009 | Insignia NS-VDVD1
Unlock codes Insignia NS-8PDVD
You may have missed a step in the procedure try this one. This information was found on the following website http://www.videohelp.com/dvdhacks/insignia-ns-7dpdvd/8394 It is dated as working on 01-08-08. I hope this information help you with your problem. 1.- Power on with no DVD inside the player; 2.- Press open on the DVD player; 3.- Press Menu button on DVD (or SETUP on remote control), (you see General Setup Page on the screen); 4.- Press the right key 3 times to select the Preference Page; 5.- On the remote control press 9653; 6.- Use the up and down key to select the Region, Select 0 for all regions; 7.- Press Enter. (This works with NS-7PDVD and NS-8PDVD)
Jan 16, 2009 | Insignia NS-8PDVD
Insignia ns-dvd1-a
Also having same problem. Code bove is not working. DVD player may have been updated with new code.
May 28, 2008 | Insignia NS-PDVD8 Portable DVD Player
Insignia portable dvd player
Do other DVDs work? Try a music CD to see if it will work. If it does not work, then the Laser pickup unit is failing and will cost more to repair then replace the whole unit. Sorry for the bad news.
Thanks for reading!
May 01, 2008 | Insignia NS-PDVD9
Insignia NS B2110 boombox CD not playing
Try an audio CD which has been purchased. I think you have MP3's on your cd and your boombox maybe does not support MP3
Mar 07, 2008 | Insignia Sport lDM9700-2 Personal CD...
Sony RCD-W500C 5-Disc CD Recorder Logo
80 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
