Question about Maytag Washing Machines
Lnt washer message - Maytag Washing Machines
I have an 8' meade telescope and cannot find my operating manual. Where may I find one for my old telescope?
This manual is located on the Meade web site here:
http://www.meade.com/manuals/index.html
and here is your manual:
http://www.meade.com/manuals/TelescopeManuals/LXseries/LX90-LNT.pdf
Aug 03, 2011 | Meade 8" LX90 LNT Schmidt Cassegrain...
Leveling sensor seems to be inoperative, tube continues to slew along vertical axis until I have to turn off the computer to avoid damage. I have replaced the 3 volt battery in the Smart Finder, which, I...
Probably your hand controller cable is broken. First thing to try is a new hand controller cable.
Also check the small watch style battery inside the LNT module.
If a new cable and a new battery do not fix this then it an internal circuit gone bad. Only Meade can repair this:
http://www.meade.com/support/index.html
Try the new cable first.
Nov 28, 2010 | Meade 8" LX90 LNT Schmidt Cassegrain...
I need the armature for a Remington LNT-2, 10 inch chainsaw.
They are no longer in production and replacement parts are mostly depleted. I went here:
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link
Did the above (LNT-2) and found part number 107481-01 (for 10 and 12"), status BO with no delivery date.
Opened service note part number 113616-01 NLA
An Internet search for "Remington PartNumber(both)" also netted no parts.
I am sorry you are disappointed in RemingtonPower. Please do not punish me for their short coming. I provided a very good answer just not what you hoped to hear. Sorry
Lou
Jan 17, 2010 | Remington Garden
Repair parts for LNT-2 remington chainsaw
I went here:
Remington.com
  • Typed "LNT-2" into the "Model #:" window, then clicked search.
  • Click the LNT-2 12 - Remington Electric Chain Saw "View Model" link.
  • Click "View Illustrated Parts Breakdown" I think you want item 12, 107713-01, Internal Gear
  • On the original view in the "Search for your parts by Part #:" type "107713-01" and click "Search"
  • Click the 107713-01 - USE REPLACEMENT PART # 122511-01 "View Part" link.
Results follow:
Part #: 122511-01 Price: $16.99
SPROCKET DRIVE GEAR BEARING KIT 747
3 piece replacement kit.
If this is what you need I suggest you order it soon.
RemingtonPower has stopped production and replacement pars are almost exhausted. Sooner or later a part you need will be NLA. HTH
Lou
Nov 10, 2009 | Remington Garden
Where can I get parts for my remington limb n trim chain saw model # lnt-2, serial #037215
Your model is LNT-2 you can find an IPL here:
http://www.desaparts.com/remington-chainsaw.html
I recommend you print it. Click the part number you need. HTH
Lou
Sep 26, 2009 | Remington Electric Chain Saw
Problem with alignment of Meade LX90 8" telescope
Start from scratch-
RESET the hand controller.
Calibrate motors using the same power source you will use outside.
Re-train the drives
Calibrate sensors on Polaris
Use either the 110 volt power cord, or buy a 12 volt power pack and the proper Meade 12 volt cable. (www.scopestuff.com carries the right 12 volt cable)
If your scope is NOT the LNT or GPS model you must level the tripod before you align. Go to home depot and buy the $3 small plastic two way bubble level, or the bulls-eye style bubble level.
Further trouble, I suggest going to the LX90 Yahoo group forum, and asking questions there.
Good Luck
Aug 30, 2009 | Meade 8" LX90 LNT Schmidt Cassegrain...
On my lx 90 LNT the DEC wheel came off, unable to reattach...?
You broke something??? Possibly this clutch kit will help you repair the scope-- or a return to Meade will be required.
http://www.scopestuff.com/ss_ezck.htm
Jun 25, 2009 | Meade 8" LX90 LNT Schmidt Cassegrain...
Backlash on scope tube meade lx90
The washers are there for a reason-- there is an adjustment screw for the worm gear-- and the Dec axis works off a friction clutch when you tighten the knob on the fork arm.
Are you talking about the center bolt on the tripod that holds the telescope on the tripod-- ??? If you overtighten this it will interfere with the rotation of the telescope....and can break the motor.
Here is Jan's LX90 web site with disassembly instructions and pictures--
http://jan.eaglecreekobservatory.org/
Apr 02, 2009 | Meade 8 2000mm f/10 LX90 LNT Motorized...
Meade LX90 8" SCT I am having trouble getting a firm fixing of the scope to the tripod. I may have cross threaded the fixing. I notice that the fixing at the bottom of the yolk is secured by...
You may need to add one or two small washers to the central screw to tighten things up a bit. A "C" clip holds the big screw on the tripod. If you break it any hardware store can supply a replacement for less than $1.00.
Oct 31, 2008 | Meade 8" LX90 LNT Schmidt Cassegrain...
LX6 Hand controller....error message
If the hand controller on the LX6 has stopped working you have a problem since meade does not support this very old telescope. My only suggestion would be to place an ad on www.astromart.com looking for a new hand controller.
If the error message indicates a "motor fault" make sure you have a good power supply and or fresh batteries-- as low voltage will cause a motor fault error.
Later you said it was an LX90 LNT-- ?? so which scope do you actually own???
Apr 25, 2008 | Meade 8" LX90 LNT Schmidt Cassegrain...
Washing Machines Logo
13 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
