Question about Toyota Genuine DVD navigation NKP-W51
Live wire for nkp-w51 - Toyota Genuine DVD navigation NKP-W51
I need to put a relay in my fridge because its making a clicking sound how do i take it out the old relay KIC motor is samsang SD162Q-L1UA W51
if it is clicking, I would say the relay is working. The question would be "What is making it go on/off?"
Nov 28, 2016 | Refrigerators
It is possible to change input language.
perhaps your dealer can read chinese and change it for you
Jul 07, 2015 | GPS
How Do I Get My NKT-w51 To Work In English Version In Jamaica
Try Control Panel > Regional and Language Settings
Feb 25, 2014 | Computers & Internet
Hello I have a ncn-w51 DVD navigation display in my car but it is in Japanese language is there any ways to change it to english and can I insert maps of my current location?
Hi dude, kindly tell me what is your car model??, then i will guide u, i get some information from http://www.gari.pk/used-cars , according to this language change is based on setting of your car.
Aug 29, 2011 | Car Audio & Video
Dear Sir/Madam, I have a motherboard of a Fujitsu Siemens D1520 (Foxconn) with name: w26361-w51-z1-04. The connections of the Frontal Panel (power LED, IDE LED, reset switch and power switch) consist of...
On the Foxconn boards all connectors are the standard model, always with the name of the connector printed on the board. In your case probably the speaker has a wide connector - 3 pins wide instead of 2.  Just pair the matching names.
Here are some generic instruction - http://www.pcguide.com/byop/byop_OtherCaseConnectorsandSwitches.htm
Sep 13, 2009 | Foxconn Computers & Internet
I have a 3 prong wire but dont know how to tell which one goes where
3 prongs, are as follows live wire-- nuetral--- live wire.. the middle terminal is always the nuetral line.. so normal color codes are red(live)-white(nuetral)- black(live), or black(live)--whiite(nuetral)-red(live). so long as you nuetral hooks to center post either live wire can go to either side
Oct 31, 2008 | Dryers
Unlock code of classic 231
I have a classic231 mobile set, i use ruim card at the present time, so i want to be now use virgin card so please help me and send me unlock code on my Email ID- manojkumar.nkp@gmail.com
Mar 21, 2008 | Timex Fashion Classics 23161 Wrist Watch
Restarts Unit/Clock Every time car turns off
Hi the problem is due to it been wired in wrong their should be two live wires coming from the unit one is permenant live this stores the time and any setings you change and the other live is main live that turns the unit on when ignition is on.
What you need to do is locate these live wires they will either be wired up to one live wire coming from the car this causing the problem you need to have one live wire going to live auxilary and the other should goto a permanent live wire.
The permanent live wire is the one that stores the time and setting etc it usually an orange wire and the permanent live wire is usually red.
What you can do is use search engine and look for wiring diagramme for your unit this will show you whats permanent live and what aux live hope this is some help.
If you are unsure let some one look at it for you its only five minute job thats all ok
Feb 26, 2008 | Car Audio & Video
Toyota Genuine DVD navigation NKP-W51 Logo
91 people viewed this question
Top Toyota Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Toyota Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
