Question about Philips 60P8341 60" Rear Projection Television
Picture convergence looks like the red is way out of line convergence does not move it back. it looks like many red lives and the letters are all double
  • metsfan Sep 01, 2007
    TANK YOU DO YOU HAVE AN ESTIMATE OF WHAT THAT SHOULD COST FOR HOME SERVICE CALL
  • metsfan Oct 03, 2007
    YOU WERE RIGHT I REPLACED BOTH CONVERGENCE IC'S AND 2 RESISTORS ONLY ONE IC WAS BURNT OUT BUT IT WAS RECOMMENDED TO REPLACE BOTH 180 DOLLARS
    GREAT PICTURE ONCE AGAIN THANKS
  • 398 Answers
There are 2 large convergence output IC's and one of them has burned out. The defective convergence IC should be replaced and the convergence circuits realigned by a qualified tech experienced in projection sets.
Posted on Sep 01, 2007
  • Mike Longo
    Mike Longo Sep 02, 2007
    When I do a housecall to replace convergence IC's I charge $150 but shops in your area will vary so be sure to ask around.
All the lettering on my screen as well as images have a red shadow
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board,must have to be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 21, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Blurring of lettering on bottom of screen
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 15, 2010 | Philips 60PP9202 60" Rear Projection...
Double lettering on red when in 1080i good picture in 480p
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 06, 2009 | Philips 55PP9401 55" Rear Projection...
JVC- red wave on screen and letters doubled
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Mar 12, 2009 | JVC AV-48WP74 48" Rear Projection...
Mitsubishi - cannot converge red
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic2_bing.gif,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 13, 2008 | Zenith R49W36 49" Rear Projection HDTV
I have a phillips rear projection 51PW9303 red and green lines showing in the left corners and red line thru middle of screen, bottom of screen shadows and so does left top corner if numbers and...
sounds like youre describing a convergence problem. Do the letters look like theyre 3D? If so you will need to replace both Convergence ICs STK392-120 you can get replacements at the following link and they include installation instructions with pictures plus gree tech support. heres the link.
http://servicemanuals.vstore.ca/
Apr 24, 2008 | Televison & Video
Convergence problem???
you must move red and blue lines into the green. change red to blue by useing the select button on the remote. till all convergance lines are white
Jan 12, 2008 | JVC AV-48WP30 48" Rear Projection...
Can't watch footbal
NOTE: ----DO NOT TOUCH THE CONVERGENCE BOARD " -------
1. Bring Up 1 Projector Light 2. Bring Your Color Convergence + Sign and Should Be Center In Your TV 3. If Not Adjust Center with The 2 Tabs Just Above That Projector Tube You Have Lighted 1 Tab Will Move + Sign Horizontal Then Roll The Other Vertical Then Roll..U Will See--" 4. Once Your + Sign Is Center Turn Up Your 2 Other Projectors Make Sure They Are Able To Adjust Across The + Sign You used 1st Make Sure the 2 Other + Signs Move Left And Right And Up And Below The Vertical and Horizontal Lines. If Not Adjust There Tab to Make This Possible. 5. Using Your REMOTE Converge The + Signs Together. ---------------- IF YOU MESSED WITH THE CONVERGENCE BOARD ------------------- 6. Now Lower The 2 Lights So Your 1st Projector Is Lighted 7. Bring Up A Menue On Your TV -- Look At It ...Are The Lettering Center and Square ..?? 8. If They are Lower That Projector and Light Your Projectors 1 At A Time To Verify Letters are Center and Square. ---------------If You Have To Adjust The Menue To Bring Center And Square -------- 9.Looking At The Convergence Board You Will See 3 Rows Of Adjustment Dials Each Row Is For 1 Projector. ---TAKE NOTE TURN THE ADJUSTMENT Slowly--- 10. Locate The Row that will adjust The Projector You Have LITGHTED".... 11. Label On A Paper What Each Knob Will Do To The Screen Very Help-Full 12.Adjust Your Letters Dead Center and Square then Lower That Projector Light And Bring Each Projector Lighted At 1 Time To Verify Menue Is Center And Square. 13.Leave On Your 3rd Projector and Bring Up Your Light On The 1st Projector 14. Adjust the Letters Of Your 1st Projector Over The Letter Of Your 3rd Projector 15. Switch To Your Convergence + Sign To Help --Turn Knobs Slowly --- 16. Make Your Letters Merge Together And Your Lines Square. 17. I Use The Top Letters and Lower Letters And Keep The box Square 18. Hey If Your Projector Colors When Looking Through The Rear Of The TV Are Not Equal With Take And loosen The Wing Nuts And Turn The Lens To Focus the Color and Make Narrow Or Wide....All 3 - Equal DO NOT GET UPSET THIS WILL TAKE TIME MAYBE ALL DAY SO RELAX HAVE FUN" Do Not go Sticking Your Hand Into The TV While TV Is Plugged into The Wall" ---
Dec 16, 2007 | Philips Televison & Video
Convergence problem
We need a better description of what you mean by shadowing. However I am assuming: 1. You mean it ''bleeds'' off to the right when you have something with a hard red/blue drive. 2. When you turn the contrast and color down a bit it gets better. unfortunatly I cannot tell you how to fix convergence, but I can think of some other possibilities. In this case the red/blue emmision of the crt is dying off and going into saturation when driven hard. To fix, replace with a new picture tube/crt. In some cases you can get a little more life out of that tube (with a watchable picture) by having the screen, focus, cathode bias, and drives slightly readjusted. It will take someone with experience in doing these adjustments on a weak tube to get it looking as good as possible. Given the construction of the cathodes (guns) in that crt, only a very low level crt reactivate should be tried on it. The hard rejuv most crt testers give is highly likley to completely destroy the cathode on that crt.
Mar 22, 2006 | Toshiba 55H70 55" Rear Projection...
Distorted Color and geometry of Picture
I've posted this solution several times but here goes. Try setting up the convergence through the menu by accessing the convergence setup menu. If this fails to work you have a bad digital convergence box and need a tech to replace it. About $60 to $100 fix.
Nov 03, 2005 | Panasonic PT-47WX49 47" Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
