Question about Daewoo KOG867T9 1000 Watt 0.9 cu. ft. Compact Microwave Oven with 2 Sl
Toaster has stopped working! - Daewoo KOG867T9 1000 Watt 0.9 cu. ft. Compact Microwave Oven with 2 Sl
All works except toaster elements do not heat up. is there a quick fix?
unplug it and let it sit for a minute. then plug it back in. If that does not work, then its not going to be a quickfix. Rather it will be an internal issue with lots of screws and testing with meters.
Sep 02, 2015 | Samsung MT1088SB 1000 Watts Convection /...
My toaster oven won't come on
Check for any fuses at control board. F fuses ok main board already faulty
Sep 01, 2014 | Viante True Blue Convection Toaster Oven,...
Sharp Carousel Microwave Mdl 1875 for our RV is dead
>> We also tried plugging our toaster into the microwave plug outlet, and the toaster wouldn't work in that outlet, but worked just fine in a different outlet in the RV.
This means the outlet you plug your microwave into needs to be fixed in addition to fixing the oven. Breaker? Fuse?
>> I understand from another RV forum that microwave ovens for RVs have "special circuitry and cooling features" not found in regular countertop ovens for household use.
Not really in my experience. Any microwave supplied with clean AC power and proper venting space will be fine.
But I'd bet your microwave can be fixed affordably.
The main internal things which can result in this model being dead (no display, no light when you open the door, no beep when you press a pad on the keypad) would be the 20A fuse and the magnetron temperature fuse. There could also be bad connections on the noise filter board.
Also, sometimes a power surge can cause the power to be interrupted to the low voltage transformer on the board, and I regularly repair those boards. I can also write a technical statement to your insurance company or to an RV park as needed.
At my Web site, I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The relevant service manuals for this model are here and here.
You can order Sharp parts from Sears or Encompass.
Contact me directly if you need more help.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
Mar 08, 2017 | Sharp R1875: Over the Range Convection...
Start Toaster button doesnt work
replace the touch pad or, key pad. it has failed.
Jun 21, 2009 | LG LTM9000 Microwave Oven
Microwave Toaster Combe
The button may be stuck... try cleaning the display really well.
Oct 26, 2008 | Microwave Ovens
I needed toaster oven assistance. My year and half year old toaster oven's timing knob has broken. The model number is TOV200. I wondered if Toast Master could let me know how much would cost to send me a...
You may contact consumer_relations@toastmaster.com.
If they refer you to Salton, you should try to get a phone number, because their Web site was not working when i just tried it.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 26, 2008 | Microwave Ovens
Need instruction manual for toaster (there was no category for toasters, so I chose microwaves
If you read my original message, you know that all we need is the instruction manual, etc. for our new toaster. If you can't help me, can you refer me to someone who can?
Apr 01, 2008 | Microwave Ovens
Daewoo KOG867T9 1000 Watt 0.9 cu. ft. Compact Microwave Oven with 2 Sl Logo
14 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
