Question about Panasonic PT L735U Multimedia Projector
I have no light or image when I turn on my projector I am thinking that my shutter is stuck closed is their a way for me to fix this
Kodak M1033 LCD black. entire images on SD black. It powers on and makes audio. Flash works as does the the green light. In other words it seems everything works except viewing, taking, and saving...
It might be easily fixed. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 12, 2011 | Kodak EasyShare M1033 Digital Camera
Screen black, i think it's a lens problem
Mar 29, 2011 | Canon PowerShot A470 Digital Camera
Camera will not show image on screeen or in veiw finder. Green status light is on.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Feb 19, 2010 | Canon PowerShot S2 IS Digital Camera
My cannon is showing a black screen in the camera mode and the same after the image is taken..........i think the internal lens is not openeing............pls help?
Your correct in your assumption. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Feb 14, 2010 | Canon PowerShot A540 Digital Camera
There is no image when it is in camera mode but can playback pictures taken before the problem occured. when i take pictures no image in the lcd monitor and no picture taken when i check in playback
Now the A460 is not capable of taking 15 second exposures as recommended for the fix. Instead try setting the camera to manual mode, turn off the flash, got to a darkened room, and take a picture. Open the battery door while the red and yellow light are flashing. If after many tries this does not work, then consider trying Fix #5a on the site. But do so with the camera turned off and the lens retracted to lessen the chance of damaging the lens mechanism.
Sep 24, 2009 | Canon PowerShot A460 Digital Camera
I first experienced a problem with my Canon S2Is camera when it was only taking pictures of blank images. I found a "fix" recommendation which seems to have gotten rid of the black image problem. However,...
Think you need to do the fix more. Believe your shutter was previously stuck in the closed position. Now it sounds like it is stuck in the open position. Again keep trying the fix to loosen it up. Just to confirm, the "fix" you're talking about is taking repeated photos in shutter priority mode with 15 second exposures, and opening and closing the battery door while the shutter is opening, right? You may want to add some tapping of the camera against its padded usb cover in an attempt to get the shutter to jar closed.
Sep 13, 2009 | Canon PowerShot S2 IS Digital Camera
My Canon Ixus 75 will no longer take pictures.The screen remains blank and no image is recorded when the shutter is pressed. All other functions appear normal, including the display ing of previously...
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 12, 2009 | Canon Cameras
I am using canon A430 for 1 yrs bur from bfore 2 mnths when i image on day time the image becomes too bright and when i take at in light i comes parallel lines.i am beliving that u will suerly solve my...
First make sure you are taking pictures in auto, and not in manual (make sure the mode selector dial is not on the little red camera with an M). If it's not...
Now the A430 is not capable of taking 15 second exposures as recommended for the fix. Instead try setting the camera to manual mode, turn off the flash, got to a darkened room, and take a picture. Open the battery door while the red and yellow light are flashing. Repeat as the fix recommends, but please note that there may be only a small hope that this will work as the shutter may be stuck in the open position. This is harder to get unstuck than a closed shutter.
If the above doesn't work, consider attempting Fix 5a listed on the web page. There is some risk of damaging your camera with this fix, that's why I hesitate to recommend it until last.
Jul 04, 2009 | Canon PowerShot A430 Digital Camera
Screen does not show images
Jun 27, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
My screen is black or blank
I think you mean your automatic lens cover opens. A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Feb 23, 2009 | Nikon COOLPIX L18 Digital Camera
Panasonic PT L735U Multimedia Projector Logo
20 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
