Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Xp files ---poof-gone!
All my xp files are gone. I can't shut down my computer unless i do it manually and press off. Can I redownload xp and not loose my files? thank you
  • legittips Sep 01, 2007
    Instead of downloading xp, is there something better I should download instead of xp?
Is there anyne free downloads of windows xp home edition coz my cd is naffed n i cant do anything wiv it know.. if you can please tell me asap thanks
Posted on Sep 02, 2007
Try downloading ani(virus,trojan,malware,spyware,etc) programmes if link needed contact me.....it would be waste formatting ur xp
    Problem Solver:
  • 11 Answers
XP is probably your best bet. Unless you were looking to "upgrade" to vista, or were looking to try out one of the many versions of linux. I wouldnt sujest linux for the everyday user because although its been making huge hurdles, it still is for a more advanced user. As for your files, if you still have access to any i would sujest backing them up on a CD or DVD. if they have disapeared off your computer you could also try a file recovery program such as norton ghost. It will scan your harddrive for "ghost images" or what used to be your files. You could also format and then run the file recovery program, but i warn you that in alot of cases when it restores old deleted files they are damaged and will not work correctly.
Posted on Sep 01, 2007
SOURCE:
The touchpad cursor on my laptop suddenly freezes how to fix it.
REDOWNLOAD/REINSTALL THE TOUCHPAD DRIVERS SOMETIMES PEOPLE ACCIDENTLY DELETE SOMETHING IMPORTANT OR A FILE GETS MISPLACED OR THE COMPUTER MESSES UP SOMETIMES.... NOT SAYING ANY OF THESE ARE THE CASE BUT IT COULD BE.
Nov 21, 2012 | Computers & Internet
Installed xp pro over xp home on same partition. data(excel & word files) not being seen. How do find these files?
you need to put the xp on you want shut the computer down restart the computer press f6 and it will start to formatte just follow instrushions dear
kind regards peggy
May 11, 2012 | Microsoft Windows XP Professional Full...
Hi I own a RCA digital voice recorder, model #rp5030A. I cannot figure out how to delete the recordings, can you help me?
Plug it into your computer via USB cable, open file(s), right-click with your mouse on the one(s) you want to delete, one the dropdown menu, go down to the word delete and left-click your mouse. POOF, recording gone.
Sep 29, 2010 | RCA Audio Players & Recorders
When i shut down windows xp, it goes through all and the hard drive shuts down but the cpu fans and coooler fans keep going, then i cannot switch it back on unless i reach to the back of the computer and...
It seens like a motherboard or power supply problem.
If you have a spare PSU, replace it with the current computers PSU. If you don't have a spare, you can always take one from another computer.
If the problem is still showing up, then the motherboard may be defect and will have to be replaced.
Sep 22, 2010 | MSI K9VGM-V Motherboard
Ms office unable to install in xp because while install msoffice2007 pc was shut down when light gone out.
First, uninstall Office 2007 manually:
http://support.microsoft.com/kb/928218
And, delete the following file as well.
  1. Click Start
    Collapse this imageExpand this image vistastartbutton.jpg, and then type cmd in the Start Search box.
  2. Type cd "%allusersprofile%\Application Data\Microsoft Help", and then press ENTER,
  3. Type attrib -h rgstrtn.lck, and then press ENTER.
  4. Type del rgstrtn.lck, and then press ENTER.
  5. Type exit, and then press ENTER.
Jul 27, 2010 | HP Compaq 6510b Notebook
Windows xp was installed on a compac armada 1750 was worling fine but after an hr or so it shut off and now wont boot or run windows all i get is black screen with window xp and 30 sec coutdown and......
On *********** board, there will be a battery, take that out and put it back in. if you have the OS disk. put it in. shut off computer, turn it back on press enter to boot from disk. either re format your hdd by deleting the partioned space or repair.
Apr 11, 2010 | Compaq Armada 1750 Notebook
Won't shut down completely
If shutting down XP takes what seems to be an inordinate amount of time, here are a couple of steps you can take to speed up the shutdown process:
  • Don't have XP clear your paging file at shutdown. For security reasons, you can have XP clear your paging file (pagefile.sys) of its contents whenever you shut down. Your paging file is used to store temporary files and data, but when your system shuts down, information stays in the file. Some people prefer to have the paging file cleared at shutdown because sensitive information such as unencrypted passwords sometimes ends up in the file. However, clearing the paging file can slow shutdown times significantly, so if extreme security isn't a high priority, you might not want to clear it. To shut down XP without clearing your paging file, run the Registry Editor (click Start > Run, then type regedit in the Run box) and go to:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management
  • Change the value of ClearPageFileAtShutdown to 0. Close the Registry, and restart your computer. Whenever you turn off XP from now on, the paging file won't be cleared, and you should be able to shut down more quickly.
    Note: Please be careful when editing the Registry; you can do a lot of damage here. Don't change or delete anything unless you know exactly what it is.
Apr 13, 2009 | Computers & Internet
My sandisk sansa 2gb mp3 player has files i cant get rid of
go to settings then go down to format press that, wait for it to finish, all of the files on the mp3 will be gone. Then you can redownload the music and vid's that you want.
Jan 29, 2009 | SanDisk Sansa e250 MP3 Player
Windows XP stops at "shutting down"....
It seems to me that You need to uncheck the "delete paging file at shutdown". Deleting the paging file slows the shutdown of Your system considerably.
Jan 11, 2009 | Microsoft Windows XP Professional With...
Windows XP professional loop
Glad to hear you have your OS disc handy... let's try this:
Insert your XP CD and when it asks if you want to boot from the CD, press any key (ENTER) to do so. When asked, press ENTER ("To setup Windows XP now") and follow these steps...
To repair a Windows XP installation using Recovery Console, press "R"
To quit Setup without installing Windows XP, press "F3".
Press Enter to start the Windows Setup. DO NOT choose "To repair a Windows XP installation using the Recovery Console". You Do Not want to load the Recovery Console.
Accept the License Agreement and Windows will search for existing Windows installations.
Select the XP installation you want to repair from the list and press "R" to start the repair.
((Note: If Repair is not one of the options, END setup. After the reboot read Warning#2! ))
Setup will copy the necessary files to the hard drive and at some point the system will reboot. When this happens, you want to now allow the system to boot from the hard disk but leave the CD in the drive. So do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Hope that helps.
Sep 09, 2008 | Microsoft Windows XP Professional
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
29 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
