Question about Pets - Others
Remove duratub from wall - Pets - Others
How to repair a wall socket that has stopped working.
turn of breaker --remove wall plate screw ---remove socket disconnect wires ---reconnect --replace --cover and turn on breaker
How to Replace Standard Electrical Outlet For Dummies How To Replace An Old Electrical Outlet Wall Plug Replacement
Oct 10, 2016 | Electrical Supplies
We are looking to remove our travel trailer. what inside walls could be removed. for example the wall between the bedroom and living room and the wall between the bathroom and bunkbeds.
You can remove any walls that you want provided that they are not load bearing. You would need to cut in and place Akro props before removing structural. walls.
Jul 15, 2015 | Miscellaneous
How do I remove wall paper
wet it down and use a blow dryer or a heat gun works to.
Dec 11, 2014 | Victoria Home Decor Mural Art Wall Paper...
Where can I get instructions for removal of a disconnected Vulcan Quasar W/F gas wall furnace? I thought it would be easy to remove the unit from the wall but on inspection I can't see how to do it?
If it has truly been disconnected and you can;t figure out how to remove it from the wall, just remove that section of wall and replace it. If it is mounted on a standard stud wall, cut at least 16" out from each side. Remove the furnace and replace the drywall. That is, admittedly, the brute-force approach, but I am assuming that you have already looked up the installation instructions and simply reversing them didn't work.
Sep 15, 2014 | Video Cameras
Is there a way to make a stud wall for a shower part transparent?
You mean clear plastic dry wall? or how about a window? How about removing the wall and putting in glass panel? Glass block? Anything can be done, depends on your imagination. An exterior wall can be totally removed with a lintel replaced in the top, and interior wall can be totally removed with no lintel, depending on trusses, or rafter placement.If you want to leave the studs exposed in the wall, I would clean them up a bit. The problem with that is you can't clean it and the panels are subject to fogging up inside, condensation will get in there, an exterior wall is a bad idea, no insulation. Hope this helps.
May 20, 2010 | Basco Semi-Frameless Tub Shower Enclosure...
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Removing back stand supports
First I am not to sure about the brand you got there, But if it is not wall supportable you do not need to reove anything but by a wall mount that will hold the bottom in place and yes there are wall mounts for this tpye of arrangment see not all flat panels go on walls thus hence you cannot remove the stand easy. Try finding a wall mount the has a L shape to it, it will hold the bottom of the tv and it comes with a little strap to hold it back into securement. Please do not try to remove the stand I would suggest a diffrent wall mount- Rulds2008 TV expert for 20 years
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 14, 2009 | Sampo PME-42S6 42 in. HD-Ready Plasma...
How do I connect the drain hose from my whirlpool washing machine to my duratub? The washing machine has a corrugated drain hose already attached.
the drain hose needs to be attached appr. 32 inches above the floor and needs to have an airgap between the drain pie and the drain hose in order not to sifon the water out of the machine.
What you can do with the duratub is:
Hole in the side where the washer is. Get a drain pipe for your duratub with a side connector for dishwasher and/ or washer. make sure that the Ptrap is at least 5 inches below the connection point in order not to have the sifon effect
Jun 15, 2008 | Whirlpool Washing Machines
Removal of base
Most LCD HDTV televisions come with the option to remove the base, refer to your manual for proper instructions on removing the base. But make sure the TV is certified for wall mounting before you do anything - some are not certified and will not be wall mountable.
Sep 07, 2007 | ViewSonic N3000W 30 in. HD-Ready LCD...
Pets - Others Logo
Top Pets - Others Experts
Ross Keen
Tom Chichester
Ruth summersides
Are you a Pets - Other Expert? Answer questions, earn points and help others
