Question about Mtd Garden
I have and older Model MTD 14/42 7 speed Industrial Commercial LT Cant find a Manual for it the mower deck vibrates try too see how too may be adjust the deck or maybe some thing else is wrong
steveym
  • 11 Answers
SOURCE: i have a mtd 13.5 horse 38 inch cut 6 speed its
Most mower decks have the diagram on them, if not go to MTD.com and put your model number to see the diagram.
Posted on May 03, 2009
mowerman1857
  • 389 Answers
SOURCE: HOW TO REMOVE MTD BLADE ADAPTER AND INSTALL NEW
Remove the blade bolt and blade, slide the adapter off the crankshaft. If it will not slide off, spray it with a good penetrating oil and let is soak for a bit then take a SMALL hammer and gently tap on the sides of it while pulling at the same time. Slide the new one back on and repklace blade and bolt(s)
Posted on Sep 14, 2009
  • 10 Answers
SOURCE: Trying to put on mower deck belt for cub cadet
Visit this web site http://www.partstree.com/parts/
you can pull up your Cub
Posted on Oct 18, 2009
SOURCE: diagram on how to replace belt on deck 48
This is an older model, but the routing might be similar.
Posted on May 07, 2010
SOURCE: i have an MTD 3.5 hp Tecumseh lawn mower. The
WHAT KIND OF OIL DO I NEED FOR THE LAWN MOWER
Posted on May 14, 2010
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
Video on how to level mower deck on MTD 917.287071 riding mower ?
First the model given is not a MTD it is Craftsman's AYP
There only four adjustments that can be made. Please refer to the owners manual page 21 for the instructions.
Craftsman 917.287071 Owners manual
Nov 15, 2014 | Garden
I need a diagram for deck belt on a 1989 lawn boy lt 12 38 " deck
it's usually on top of the deck clean off the grass and look on top may have to remove it to see
Oct 19, 2012 | Mtd LAWN MOWER PART # 983-04052 DECK...
Vibrating 38" deck on MTD yardman mower
Hi, first replace the blade spindle bearings, if you had to hit them to free them up the bearings are shot. Secondly, replace the deck belt. Because you engaged the blades with a siezed bearing the belt will have a worn section where the v will be thinner thus causing the vibration as it passes through the pulleys. Regards Phil.
Jun 19, 2012 | Mtd Garden
We changed the blades, changes a spindle and checked the deck and tire pressure on our Poulan Pro Mower. It is still cutting uneven. What else should we check.
Well the plane of the spinning blades obviously is not parallel to the ground. While the ground will never be level, do what you can and first get the mower on a good piece of flat concrete. Measure distance between each corner of the mower deck to the concrete. You have had the deck off, the deck hang mechanisms have some adjustment so you can lower the front of the deck relative to the rear and vice versa, and lower the left relative to the right side, and vice versa. Look for threaded rods with adjusting nuts, pins which can go into different holes, etc.
As a last resort you could google "poulan, mower, manual" which would take you to their website and you can download the manual for the mower. All my mowers, MTD, Husq, Simplicity, came with a manual and had explicit instructions for this process. Most all these mowers are made by Roper or AYP and you may find information by googling those companies.
Aug 25, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Diagram on how to replace belt on deck 48
Apr 25, 2010 | Cub Cadet Street Sign- tractor lawn riding...
I have a mtd 13.5 horse 38 inch cut 6 speed its around a 2007 or a 2008 i need to se how all the belts go on the mower deck and drive
May 02, 2009 | Mtd LAWN MOWER PART # 683-04163B FRAME...
88 mtd mower wont go past third gear
Without knowing the model, or type of transmission, I can only suggest checking your owners manual.
You can download a manual here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
You will need the model & serial numbers.
Apr 16, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Need help to reinstall the under mower 42'' unit that out
I have that manual. If you want, give me a postal address and I'll mail you a copy. Mac
Nov 13, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
57 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
