Question about Sharp XL-MP130 CD Shelf System
Cassette Deck doesn't auto reverse
Cassette deck on Sharp Model XL-MP130 does not auto reverse. It only plays one side of the tape and then I must manually turn the tape over to play it. I have checked several tapes on another system and they work fine, so I don't think it's a tape problem. Thanks.
  • Anonymous Nov 28, 2007
    hi, i have a xl-mp131 shelf system.. and it doesn't auto reverse, though i don't think it is even suposed to...
This is a common problem....with tapes.....in the old days there was a shiny end of tape (EOT) sticker placed on the tape end which was detected as the tape end and caused the electronics to reverse the motor drive to play in the teverse direction.
If consumers alter the length of the tape by cutting and joining they used to cut off the EOT sticker and then the tape wouldnt reverse like in your case.
Now days a hi frequency signal is recorded on the tape and a detector circuit inside sees this signal and reverses the tape for you,
I would suggest that the simplest thing to do is to clean the playback head with a cotton bud and some special head cleaning alcohol.
There jusy may be a build up of magnetic material on the play back head which is stopping the high frequency signal getting through to the detector circuitry.
Different manufacturers do this EOT detection in different ways but the head clean is the first line of attack that you can do yourself.
Please turn off the power before doing this activity and be very careful with the cotton bud that you are not rough and dont push too hard on the recording/play back head.. Be gentle...
The cleaning liquid must be proper head cleaning liquid, so dont try shorth cuts and use just anything to do the cleaning or you may ruin the detector head surface.
The quality of play back sound will also improve from a good clean..
Cheers From YUBEUT
Posted on Nov 24, 2007
SOURCE:
Sony dual deck, deck B works fine, deck A won' run the tape but just keeps clicking as it auto-reverses.
Hi amitchell47,
The rubber belts that turns the gears is already worn out. Usually, there are two rubber belts in a cassette deck. You have to replace both belts. I hope everything works out. Good luck.
Jul 25, 2011 | Sony CASSETTE DECK Single Dual Cassette...
Wheels on the tape deck don't turn on either side, forward or reverse on Sony dual cassette tape deck
You have a broken transfer belt and it needs replacement.
This will require you to take the tape deck apart to service it.
Mar 24, 2010 | Sony CASSETTE DECK Single Dual Cassette...
When i push play on either deck - the tape starts to move and then the tape deck switches the tape's direction continually
If you observe the sprockets in the cassette you'll probably see they're not turning. That would indicate a broken belt or something mechanically common to both decks. Deck logic probably interprets the lack of sprocket rotation as end of side and auto-reverses. Take it to a shop.
Mar 19, 2010 | Technics RS-TR272 Single Cassette Deck
Older Teac cassette decks
I had an Aiwa dual deck and by the way your describing it, when you select Cont. Play press play on one deck then play on the other. I am not sure if there's a difference as to which you start with. When the first deck is done playing both sides, the unit will goto the second deck and play both sides, then back to deck 1.
Jul 01, 2008 | Audio Players & Recorders
Remote control for Technics RS TR 272 Dual Cassette Deck
a system remote is the only option for you here. The deck does not have its own remote receiver. Sorry to break the bad news to you.
Jan 09, 2008 | Technics RS-TR272 Single Cassette Deck
Dual Cassette Deck won't stop or auto-reverse
There is a tape tension sensor which, it appears, isn't working. Check to see if the linkage to this sensor may have been misaligned while you were replacing the belts. Also check to see that the sensor isn't binding or sticking.
Nov 27, 2007 | Audio Players & Recorders
Sharp XL-MP130 CD Shelf System Logo
154 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
