Medion akoya P6612 black screen fine, boot fine and works with alternate monitor.
ssebata paul
  • 159 Answers
SOURCE: My Medion Akoya will not boot
reinstall the operating system
Posted on May 23, 2009
clb199
  • 164 Answers
SOURCE: I have medion akoya s5610 laptop. Power light
  1. Believe it or not, the number one reason why a computer won't turn on is because it wasn't turned on!
    Before starting a sometimes time consuming troubleshooting process, make sure you've turned on every power switch and power button on your computer:
    • Power button/switch on the front of the computer
    • Power switch on the back of the computer
    • Power switch on the power strip, surge protector, or UPS (if you have one)
  2. Verify that the power supply voltage switch is set correctly. If the input voltage for the power supply does not match the correct setting for your country, your computer may not power on at all.
  3. Check for disconnected computer power cable connections. A loose or unplugged power cable is one of the top reasons why a computer doesn't turn on.
  4. Perform a "lamp test" to verify power is being provided from the wall. Your computer isn't going to turn on if it's not getting power so you need to make sure that the power source is working properly.
    Note: If you have a multimeter or another electrical testing device you are welcome to use that to test your wall outlet (and power strip, surge protector, etc.). The lamp test is useful if you don't have an electrical testing device.
  5. Test your power supply. At this point in your troubleshooting, it's very likely that the power supply unit in your computer is no longer working and should be replaced. You should however test it just to be sure. There's no reason to replace a working piece of hardware when testing it is fairly easy.
    Replace your power supply if it fails your testing.
    Important: In the huge majority of cases when a computer isn't receiving power, a nonworking power supply is to blame. I bring this up again to help stress that this troubleshooting step should not be skipped. The next few causes to consider aren't very common.
  6. Test the power button on the front of your computer's case. It's not a very common point of failure but your computer might not be receiving power because the power button on the front of your PC is damaged and is not actually turning your computer on.
    Replace the power button if it fails your testing.
  7. Replace your motherboard. If you're confident that your wall power, power supply, and power button are working, it's likely that there is a problem with your PC's motherboard and it should be replaced.
Posted on Nov 27, 2009
  • 3940 Answers
SOURCE: medion akoya e1210 notebook. failure to boot pxe
Failure to boot PXE 061 is a BIOS message that indicates 2 things:
  1. System failed to boot to the hard drive
  2. System failed to boot to a network connection
The apparent problem is failure to boot to the hard disk. If the system was running yesterday and there have been no hardware changes to the system, then most likely failures are:
  1. HDD failure (Replace the HDD, reinstall OS and applications) I hope you have information backed up.
  2. HDD not being detected by the motherboard due to connection issue (Remove HDD and reseat it, then see if seen in BIOS) If no change replace hard drive, if new drive not seen, replace motherboard
Posted on Jan 11, 2010
Testimonial: " many thanks will get it looked at"
SOURCE: webcam setup on medion laptop
THE SOLUTION!!!!!!
1. Press start button.
2. In the "serch programs and files" tab typen in youcam. This will open up the webcam.
3. Once it is opened it will create a temporary icon on the task bar at the bottom of you desktop.
4. Click on this icon and you will have an option to pin it to the program to the taskbar, select this option and you will be able to easily start the launch of the program at any time.
Note: I really do not understand when Medion have not put direction for the webcam in the instruction manual!!!!!
Hope this helps,
Kathryn from London
Posted on Jan 30, 2010
SOURCE: Need driver for webcam (Medion akoya P6612 Laptop / Ubuntu OS)
Try Manycam and see if it works with Unbuntu. Go to www.google.com and in the search box type: "download cnet" (without the quotes) and go to their site. Look down on the left and you will see a gray box that says find software. Type in: "Manycam" (without the quotes) and go download and install it. It's absolutely free, no trial period and it comes with application and I think driver. Give it a try. Be sure not to accept any buggy stuff that it will ask you during the install.
Posted on Mar 26, 2012
Administrator password akoya
LOL ???? YOUR GOING TO ACTUALLY HAVE TO EXPLAIN THE ISSUE MATE
Dec 03, 2014 | Medion Akoya P6613 16" Ultra Bright Lcd...
BOOTMGR missing
If you have the operating system replacement disc thaT CAME WITH pc, that is what you are going to need. that file is what is missing that initiates the boot
Feb 05, 2013 | Medion Akoya P6613 16" Ultra Bright Lcd...
Mar 26, 2012 | Computers & Internet
May 02, 2009 | Computers & Internet
TV Tuner express card 54 DVB-T Medion
you need to install/re-install the drivers for the expresscard, should be downloadable from medion. Also check in control-panel that the device is there. If you look in My Computer/control Panel/System/Device Manager and the device is listed, with a yellow exclamation mark. try removing/uninstalling. or physically remove from the computer, re-install and go through the new hardware wizard to set it up.
Mike @ compurepair.
Nov 30, 2008 | Medion md40298 Notebook
Medion Akoya P6612 Notebook Cyberlink YouCam
I have just bought the same Laptop, when windows Vista is started the webcam doesn't work. By pressing the keys FN + F9 the webcam will be activated (you have to do this every time you start your laptop)
Nov 17, 2008 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
