Question about Kenmore Elite HE4 Electric Dryer
Kenmore HE4 85088400-wiring problem
I just removed the lint screen to clean it and I unplugged the wires. I did not pay attention to the wiring-two wires. I don't know which wire goes where?
  • 2 more comments
  • methomas88 Sep 01, 2007
    Can someone help me out, I mistakenly said I had the problem solved. I never got an answer. I was trying to reply to someone who asked for more info about the wires. Here is the part # for the grill that has the wire connectors 8299979 There are 2 wires that attach to this part (grill) 1-yellow and red ant the other black. I paid for premium assistance. Thanks
    It is unlabeled.
    I checked my manual but it doesn't have info on this. They look the same.
    The wiring is near the door. I took off the lint guard (grill)-the wires comes out from the dryer and the terminals are located on the grill. I don't even know what the wires are for.
    Sergeant:
  • 279 Answers
Can you describe the individual wires, while I try to find a manual with this information?
Posted on Sep 01, 2007
  • 3 more comments
  • Anonymous Sep 01, 2007
    I'm still here - I'll find the answer for you.
    Black should be the ground. Are the connectors labelled with a + and -?
    If so, Black goes to the -, red/yellow goes to the +.
    I'll look for a wiring diagram in case they're unlabelled.
    Okay, I'm having a hard time finding the diagram. It should be in your user's manual, if you still have it. I checked on Kenmore's website, but while they have a link for it, the link doesn't work.
    I'll keep looking.
    Do the two terminals look different in any way?
    Are we talking about the wires that come from the wall to the back of the unit, or some internal wires?
    Though in either case, if one is ground (which is what the black wire indicates) and one is power, hooking then up backwards won't break anything. I mean, either the dryer won't work until you wire them the right way, or possibly the motor will run backwards. However, it won't cause any damage.
    I've been unable to find a diagram of any kind. Sorta surprising, for so well known of a brand, but I think that's because Kenmore supplies them on their page, so there's no need for anyone else to have them for download. But, since Kenmore's links aren't working...
    I know this doesn't sound very scientific, but I suggest you take a guess, then test the dryver. Worst case scenario, you have to swap them when it doesn't work.
    Oh, those. Those are just to polarize the lint screen so it attracts lint.
    It doesn't matter which is on which side.
SOURCE:
Dryer will not start
If you manually turn on timer can you hear the faint ticking? #1Verify breaker is not tripped. #2 Unplug dryer. Remove back cover. On many makes there are 2 blue wires that connect to a white and black "fuse" towards the bottom of the unit. Unplug both wires and electical tape them together. plug in dryer and start the cycle. If it works, unplug and go buy the fuse. Clean lint out of air system from dryer to lint screen through exhaust.
Jan 09, 2014 | Dryers
Tip
Jeeps - All Windows and/or Locks don' work.
It is widely known that Jeeps have a problem with the Driver's Side Windows/Locks Control Module wiring harness that prevents all window motors and/or Power Locks from working. This may be due to the way the harness was laid out.
Over time, the wires feeding this circuits, brake or came loose from the harness connector on the drivers door.
The solution is to remove the rubber boot at the door, unplug the harness from the door and repair the broken, disconnected wires. Check all wires carefully, sometimes you can't tell they are broken because it's insulation, pay special attention to the BLACK wire, it provides the (-) ground to the whole circuit.
This simple procedure will relieve you from the great head ache that is not to be able to roll up or down your door windows.and/or power locks.
Don't forget to rate this Tip !!!! Thanks!
on Jul 21, 2010 | Jeep Grand Cherokee Cars & Trucks
New Battery but it does not want to start. You just hear the clicking sound.
Thanks for choosing FixYa and welcome. The clicking sound usually means a bad connection. Recheck all your terminals. Clean the post and ends, get rid of any white residue. Make sure no wires are damaged or loose. Make sure the starter is working. Try hitting it a few times, then try to start it. Check your ignition fuse. It is probably good, but check anyway. I believe it is a bad connection to the battery, but it may be the starter. If you have a security light on, it can keep the vehicle from starting also. Pay close attention to the wiring to the battery though. I believe the issue is there. One of the hot side wires from the battery goes to the starter, the other goes to the alternator. Follow the one that goes to the starter. Check for damage or loose connections. Be careful when you are at the starter. The wiring will shock you. Hit it on the body, not the head where the wires are. If it starts when you hit it, the starter is probably bad. If not, check the wiring and clean the post and ends to the battery. If you don't have a good connection, the starter won't crank. Even if the lightd are on inside, still clean it.
Sep 17, 2011 | 2000 Chevrolet Blazer
I have a Lux DMH110 therostat, I have four wires; red, white blue and green I don't know there to put the blue wire. On the direction it has Y for a/c compressor I don;t have a yellow wire. Where do...
The color of the wires is a guide only. The lettered terminals on the thermostat are important To pay attention to. R- is 24 volt power w- is heat g- is for the fan y- is for your ac. Sometimes The wire colors matchup sometimes they don't. Your blue wire should go to the y terminal If you have ac.
Aug 28, 2011 | Heating & Cooling
Dryer will fire and light for about 3 minutes then the gas valve goes shut, igniter will then try to relight it but no gas
sounds like you have bad gas coils located on top of the gas valve,unplug dryer,remove the two phillips screws and lift off the cover,pull off wires and change out coils,give your parts store the model number and thet will sell you the coils,they come in a pack with both coils.easy fix.also when was the last time you cleaned out the dryer?it's gas so you should do this once a year,clean out the duct that the lint filter slides into,then clean out the cabinet where the motor and burner is,if you use a shop vac you can set the vac to blow and blow all the lint out of the motor and gas tube and blow the lint from the back to the front and vac it up so you don't have to remove the drum,then if your vent line is long i use a leaf blower to blow out the vent line,remove it from the back of the dryer,go outside and make sure there isn't a cage or screen on the outside vent,if there is remove it and don't reinstall it,it will hold the lint there and block the vent,if it's clear go back inside and blow out the line,i've seen birds nest fly out of the line also causing flame problems because the air has nowhere to go and the flame goes out.do this once a year,your clothes will dry on time,and you won't damage any parts from overheating problems.
Jul 09, 2011 | Maytag MDG7600AW Gas Dryer
Amp keeps turnning off say to check speaker wires but speaker wires all ok i think
The amp turning off means you've got a shorted output, so I'd unplug your speakers, unplug the wires, etc, then plug it all back in, paying attention to the wires and where they're going.
Jan 08, 2010 | Yamaha 5" 2-Way Bookshelf Speakers (Pair)
I hooked up wires as described. I smell elecrical
If the dryer has been sitting for a while, that may just be dust or lint that has gotten stirred up inside the dryer and ended up on the heating element. This is normal and it will go away. This often occurs after the dryer has been moved or cleaned.
However, just in case, you may want to review your power cord installation one more time. The following link explains:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Verify your installation paying particular attention to how to you have terminated the Ground and Neutral wires. Make sure the terminals are tight and not loose. Loose connections can cause arcing and excessive current which results in burned wiring or melted insulation. If it is correct, make sure you don't have any heavy accumulations of dust or lint inside the dryer cabinet. If the odor does not go away within a day, stop using the appliance and let me know. I hope this helps you.
Dec 05, 2009 | Estate EED4300SQ Dryer
Need wireing help
if you have 2 sets of wires 4 connections just hook up the 2 to one solenoid and set to HOT water or cold water and see which water valve solenoid operates, if wrong just reverse the 2 pairs
Sep 26, 2009 | Washing Machines
My dryer is not as hot and taking much longer to dry the clothes. How do I fix this. I clean the lint trap after every load. I have a ge profile dryer about 5-6 years old.
Three main possibilities:
Either lint is clogging the airflow or a fuse is popped from overheating, or the heating element is broken..
You have to open up and clean out no matter what.
Unplug the unit.
Remove the lint screen and the two screws at the lint slide.
Use a putty knife to release and pry up the clips which hold down the top cover, tilt up the top cover.
Remove the two screws near the top which secure the front cover, tilt out and lift off of the two clips at bottom.
Release the belt tensioner and remove the drum.
Now you can completely vacuum out the entire cabinet. I know some persons who take a pressure washer to it (the motor seems to tolerate the wet treatment).
Remove the rear cover by removing the screws.
On the left (as you look at the rear) you will see a duct leading to the lint screen. Remove the screws and wiring harness (mark the wires). Lift it away and you will see the blower fan. It is invariably loaded with crud, coins, paperclips etc. Clean it out. If you must remove it turn it clockwise as a wrench holds the motor shaft stationary (there is a flat spot near the belt pulley).
Check the heating element. It should not be broken and read "closed" on an ohmmeter.
Clean all and reassemble after you have replaced any fuses.
Fuses should read "closed" or zero ohms. Some person test for bad fuses by temporarily connecting the two wires and then running the unit. If it only gets hot when you do this you should DEFINITELY replace the fuse.
Aug 02, 2009 | GE Dryers
Whirlpool duet dryer no error message but drum won't turn
take the bottom panel off and make sure the belt is attached it would be located to the left rear attached to a pulley and a motor. you also could have a blown thermal fuse which you would have to unplug unit from wall take the bottom panel off remove the lint screen then remove the blower housing this is what the lint screen sits in I think it has3 1/4 inch bolts you need to remove directly behind that you will see a white flat thing with 2 red wires going to it. remove the wires and check continuity. let me know how it goes
Jun 05, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Kenmore Elite HE4 Electric Dryer Logo
98 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
