Question about Toro Lawnmower Lawn Mower Sp Drive Belt 623900
How do I get the belt off Toro front wheel drive 20331
SOURCE: toro 20016 self propel
If you take the wheels off and remove the belt from the small pulley on the the front axle underneath the pulley you should see a small transmission. You usually can split this unit in half . You will see two gears and sometimes one plastic and one metal. The plastic one is usually the culprit. Hope this will help you out. Donnyb60
Posted on Mar 18, 2009
  • 203 Answers
SOURCE: front drive wheels won't engage
Is it possible that the belt has either broken or come off the pulleys? Next step would be to remove the cover and see if there is something preventing engagement or if you see any broken parts. May even be as simple as lubricating the cable/levers.
Posted on Apr 10, 2010
RonInFla
  • 86 Answers
SOURCE: my toro front wheel drive is not engaging when i
yes...tightening the belt happens when the handle is pulled...take the cover off the belt an see if there is play in the pulley on top of the transmission...if there is the trans is bad and must be replaced...
Posted on Apr 26, 2010
  • 53 Answers
SOURCE: Front wheels quit pulling
Ya most likely the lever that you normally squeeze to make it "go" has a cable. Cables stretch just like belts. If you replaced the belt already then that automatically removes any stretching that the first belt would have suffered from no doubt. Look at the drive lever's cable up at the lever end. There is usually a cable adjuster there. It will be a threaded shaft portion with a nut or knurled ring to spin. tighten up that "go lever" cable a bit. Even better, if you have visual access to the belt as you squeeze the drive lever, then you can see if squeezing that lever moves one of the belt's pulleys enough to cause it to tighten it up enough to transfer spin motion thru the belt to the other pulley. You see that whole system is really a "slip belt clutch" when belt is loose, no forward motion, as you squeeze the "go/drive" lever the pulley moves away tightening up the belt more and more. The tighter the belt, the less the slippage, the faster you go! But the slippage is necessary! ( That's the clutch component) If you simply had the belt tight all the time, the mower would always go full speed! It would be in full time "run away mode" LOL! so watch out. Once you see it in action...you'll get the idea no problem!
Posted on May 10, 2010
SOURCE: grinding gears and no traction for toro front
The transmissions gear is bad need to replace
Posted on Sep 01, 2010
Toro 6.95 push mower front wheel drive not working
if it will spin when you pick up on the front the belt may need replaced. they wear out over time
Apr 11, 2017 | Toro Garden
Where does the armature spring attach to for a toro 20331 mower
Using http://www.partstree.com/parts/?lc=toro&mn=20331 and your serial number you should be able to locate the parts diagram for your mower. This may help you with your problem.
Sep 03, 2013 | Toro Garden
My toro 6.5hp 22" front drive mower does not dive
There is a transmission, a pinion gear connected to the belt end, and a larger bevel gear connected to the axle, all inside an aluminum shell, we could call it a basic transmission. On my Toro the bevel gear had flat spots on about a third of the teeth, hence it wasn't continuously driving the axle. A new pinion and bevel gear where found as a set on Ebay for $30 plus $5 shipping.
Also the plastic gears in each of the front wheels can wear out and you need new wheel assemblies, they cost about $15 apiece at Sears if you pick them up, $10 more if shipped. Take your old one in, they can match it.
Jun 15, 2011 | Toro Garden
Toro model 20331 reat wheel drive doesn't work
Download your model's service guide from here:
https://lookup3.toro.com/request/request.cfm
I had the same problem, & was able to fix mine.
Jun 28, 2010 | Toro Lawn Mower With Toro Power Tools
My toro front wheel drive is not engaging when i pull the lever?the drive belt seems loose . does it always have some play in it.?
Apr 26, 2010 | Toro Lawn Mower With Toro Power Tools
Front drive wheels won't engage
Apr 10, 2010 | Toro Lawn Mower With Toro Power Tools
Self-propelled feature runs slow and won't pull as it should!
Check the belt tension. There is a spring that holds the tension and connects the gearbox to the mower deck. If it has slipped off the belt will not be tightened properly.
Hope this helps.
May 05, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 20016 self propel
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
How to remove plastic front wheel drive cover on Toro Recycler
On my Toro recycler, I also had the front drive stop working -- and fixed it after reading the solutions here.
First, the plastic cover on the top deck that goes over the front drive mechanism must be loosened enough to pull it up. Before you can do that, on the underside there is one screw to take out.
Once that's done, all you have to do is pry the plastic cover up enough to see the belt and pulley that make up the front drive assembly. On mine, the belt had simply come off the pulley. Putting the belt back on, then tightening things back up is all it took to put the Toro back in sel-propelled happiness. Good luck!
Mar 07, 2009 | Toro Garden
Toro Lawnmower Lawn Mower Sp Drive Belt 623900 Logo
18 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
