Question about Food Processors
I have a Kitchenaide Food Processor Model KFP0922WHO when you use it like to process cabbage for slaw the motor starts up then dies down and want process
  • 3 Answers
SOURCE: Food processor died
The plastic "clutch" with the teeth is probably cracked or stripped. you can buy a replacement.
Posted on Feb 24, 2008
magimixman
  • 11 Answers
SOURCE: magimix 5200 just bought it at William and Sonoma
use the 4mm grating disc or for cruchier use the 6mm grater click here http://www.magimix-spares.co.uk/AddToBasket.asp?Prod=17368
Posted on Aug 31, 2008
SOURCE: Broken processing bowl to food processor
I have replacement parts available for the Technque CETOFP263, will only charge nominal fee plus shipping costs. email me or post to ebay seller churkey123.
Posted on Mar 16, 2009
  • 10865 Answers
SOURCE: where can I buy repair parts for food processor
Call 1-800-851-8900 and order what you need directly from Hamilton Beach.
Please mark this as a fixya! thanks
Posted on Mar 18, 2009
  • 56 Answers
SOURCE: I have the Bravetti Food Processor-Model # KP80B.
I went to my manuals sites and they did not list this brand.
the internet indicated the problem with this food processor was the inability to obtain parts.
I advise keeping an eye on ebay if you need something in particular.
(if this has been helpful, please give me positive feedback)
Posted on Aug 18, 2010
I have a Hamilton Beach Scovill 702-4 food processor that I have not used any other blades in for a long time. I wanted to shred cabbage for a salad and I could not figure out how to make the attachment...
I have been using mine for 22 years now! I love it and am actually looking for a replacement blade that I have somehow lost. Anyway, I think the end that looks like a half circle goes down into the base. The other end, starts out thin, then round, then square closest to the center of the 3" long "stick". This goes into the blade holder. Both of them have to be rotated to the correct position to fit right. Hope this helps! If you end up wanting to get rid of your blade, let me know!
Dec 17, 2010 | Hamilton Beach 70100 Food Processor
How do I slice cabbage for cole slaw. How to use the pusher attachment.
You have to cut the cabbage into small enough pieces to easily slide into the chute. once you place it in the chute use the pusher to push it down. J.
May 31, 2010 | Cuisinart DLC-5 Food Processor
I have the Bravetti Food Processor-Model # KP80B. The unit that uses each individual blade (that is stored in the processor) is cracked and won't work with any of these blades (like for cole slaw, etc.)...
Dec 29, 2009 | Bravetti Quad Blade Food Processor
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
I have a kitchen aid food processor, it is on, but motor doess no
This sounds like an issue relating with the assembly of the machine. The motor is definitely getting power if the indicator is lit. However, Kitchenaid food processors are designed (as a safety feature) to remain unengaged if the unit is not assembled in such a way. Here is the proper assembly:
Please disassemble the unit. This means: removing the blade, removing the work bowl, the work bowl cover, and unplugging the unit.
Starting with the work bowl: place the handle at the 9 o'clock position, which is out to the left. Rotate downward to the 6 o'clock position until it locks in, centered over the button panel.
Repeat the process with the work bowl lid.
Depending on which food processor you have, you may need the feed tube pusher depressed at least half way down the feed tube.
Plug in the unit. The blade does not have be installed for unit it to work at this point, assuming everything is assembled properly and the motor is functioning. The motor should now be working.
May 09, 2009 | KitchenAid Food Processors
Replace processing glass jar for bravetti quad blade food process
type bravetti in search bar. There might be something you can use in your quest.
Apr 08, 2009 | Bravetti Quad Blade Food Processor
Blade holding disc for Breville Food Processor Model No. FP7/FP8 Replacement required. Phone numbers required for contact.
Hi. I'm a Breville Service Centre.
No new parts for FP7 or FP8 are available, your best bet is to check out garage sales or you local Salvos/St Vinnies etc as people may sell their odd pieces once their motor dies. Which is rare because they were good machines!
Mar 18, 2009 | Food Processors
Black & Decker F1 CFP 10 food processor bowl cracked
Does anyone want to SELL me their Black & Decker Shortcut Food Process that they cannot get parts for? s.lamos@comcast.net
Jan 25, 2009 | Black & Decker FP1400 Quick N Easy Plus...
Food Processors Logo
74 people viewed this question
Top Food Processors Experts
Ross Keen
Are you a Food Processor Expert? Answer questions, earn points and help others
