Question about Exercise & Fitness
York 3350 exercise bike
No resistance on magnetic exercise bike
5 Suggested Answers
  • 16 Answers
SOURCE: What are the different resistances on exercise bikes?
There are three main types of resistances, the fan resistance used to provide resistance with air they push as you pedal. The second type is the belt resistance which uses a belt that runs through a brake providing resistance for the exercise bikes. The third type is the magnetic exercise bike which provides resistance which can easily be adjusted while riding the bike.
Posted on Aug 09, 2012
  • 14 Answers
SOURCE: What forms of resistance are typically used in exercise bikes?
Without a doubt, the most popular form of resistance used in exercise bikes is magnetic.
Posted on Aug 12, 2012
  • 14 Answers
SOURCE: I have a vitamaster magnetic exercise bike and
You should contact the store that you got it from and ask them to send you a battery cover or if you have warranty to give you a new magnetic bike.
Posted on Sep 27, 2012
johnwmaustin
  • 222 Answers
SOURCE: my new magnetic resistance bike is not working
The supplier or manufacturer can probably help you with this. Is there a support web site or toll-free number in the package.
Posted on Sep 29, 2012
Ni-Trac VA-500 exercise bike ( which I bought 2nd hand, in good condition) resistance has stopped working
If it was clicking the resistance motor is stuffed replace it they are quite cheap and easy done, but also make sure the flywheel is tight as they loosen over time as well. You'll need the crank tool, I made one from a m20 metric fine thread and drilled and tapped but you could probably get one from a local cycle shop. Easy job, worth doing these bikes are real nice ??
Jan 30, 2015 | Exercise & Fitness
Resistance settings not working on fitnex r70 magnetic resistance exercise bike
If this is a new bike that may be the way it is. If it worked differently in the past, you may be looking at a busted tension motor or faulty brake.
Jan 03, 2014 | Champion Fitnex R70 Recumbent Exercise...
My new magnetic resistance bike is not working
Sep 29, 2012 | V-Fit Mptcr2 Programmable Recumbent...
Aug 12, 2012 | Exercise & Fitness
Aug 09, 2012 | Exercise & Fitness
Magnetic resistance not working on proform gl105 exercise bike. belt is intact
Just oil the area of magnetic resistance and if the problem continues then contact nearer repairer.
May 15, 2010 | Cycling
No resistance when I pedal the stationary exercise bike
I looked into this thinking is must be a simple belt, or tention wheel, but these devices are much more complex than the average exercise machine. See the Recumbent selection here.
It appears that the tentioning device is a magnetic brake.
This would require that it be plugged into a power source and programmed to provide a desired tention.
I've never used one of these so I can't say what kind of programming options there are or where they are found.
Hope this helps.
Richard.
Dec 07, 2009 | Cycling
Tension
The new and improved exercise bikes have what is called magnetic resistance. This is where your resitance is created by a magnet and some sort of power source such as batteries or your bike being plugged into a wall outlet. If you are using batteries replace them. I found that with my elyptical exerciser new batteries made a world of difference in the resistance settings. Make sure the batteries are strong ones. If changing the batteries doesn't help then there may be another problem. This could be the computer or a magnetic part. These parts are usually replaceable through the manufacturer. Just check your user manual and I am sure you can get it replaced. I hope this has been helpful.
Mar 16, 2009 | Cycling
The tension on the recumbent exercise bike does not get hard
If your bike has magnetic resistance and you changed the batteries this should make your tension work properly. Since it did not I believe that there are magnets somewhere on your bike that are wearing out. Or it could be a computer part. Your manual should tell what part you need to order and replace. I hope this information has been helpful.
Also make sure the batteries that you put in your bike are really new ones. Sometimes you can purchase new batteries at a store and they are actually a little weak. I had this problem with an elyptical trainer and I went and got other batteries and this fixed the problem.
Mar 14, 2009 | Cycling
The tension adjustment does not get difficult enough
If you are refering to a regular bicycle this means the derailer is not making the chain jump from gear to gear. You probably need a new shifter cable or the shifter cable came unhooked from the derailer. I would take your bike to a bike shop to have this reconnected and then they will adjust it for you.
If you are refering to an exercise bike then here may be your solution. From what I have seen on exercise bikes there are three different kind of bikes. I am refering to how there resistance works.
First type has a strap that wraps around the wheel. There is a some kind of a nut and a bolt that holds that strap around the wheel. You simply need to tighten that nut. The strap will stretch over time and that is why you do not have the same resisteace you had when the bike was new. Afer you tighten this you will find that regular tensioner works better.
The Second type of exercise bike has what appears to be brake pads contacting the wheel. Basically your peddaling the bike with the brakes on. Pretty simple concept. Again there should be some sort of adjustment around this pad that is touching the wheel. Probably a screw or a bolt. Some even have adjusters that you can turn with your fingers.
The new and improved exercise bikes have what is called magnetic resistance. This is where your resitance is created by a magnet and some sort of power source such as batteries or your bike being plugged into a wall outlet. If you are using batteries replace them. I found that with my elyptical exerciser new batteries made a world of difference in the resistance settings. If changing the batteries doesn't help then there may be another problem. This could be the computer. Just check your user manual and I am sure you can get it replaced.
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
