Question about John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter
John Deere Rx75 - John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter
  • 42 Answers
SOURCE: Lost the bolt/nut to my riding lawn mower!
That is a cap screw you are talking about. The size of it is 7/16" X 1-3/4". The John Deere part # is 19H2563, but I am sure you can just get one at the local hardware store. I could not find out for sure, but on most blades they use a fine-thread bolt/screw. If you can tell the difference, check before you buy, or just buy both and see which one threads in easily. Hope all this helps.
Posted on Apr 01, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Replaced transmission on my John
Hi and welcome to FixYa, I am Kelly
This is a generic response to all John Deere Variator linkages but most likely what you must do with a transmission change.
To adjust the "Variator linkage" do the following.
1. Pry off the buttons on the side that cover the access holes located just below the variable speed lever.
2. Put the variable speed lever in notch #5.
3. Loosen cap screw one or two turns. This is located inside the hole.
4. Disconnect and ground the spark plug.
5. Turn ignition key to crank engine until clutch-brake pedal raises as high as it will go.
6. Take up linkage slack by pushing down on cap screw (see step #2). Tighten cap screw.
NOTE: If the tractor won't move with the variator in the first notch after these adjustments then the primary drive belt needs to be replaced.
I am concerned that maybe you did not connect the linkage properly but you have to do the above steps if no matter what you do you only have slow speeds.
Posted on Apr 22, 2011
  • 3911 Answers
SOURCE: I have a John Deere rx75. The mower deck seems to
find someone who can read and use the internet
go to www.google.com
search for john deere lawn tractors
go to the john deere website and click around under "support" until you find the manuals
download a manual for your model,l but they are all about the same
have the person who can read, read you the part in the manual about adjusting the deck height and how to level it.
there you go, bob's your uncle.
Posted on Sep 19, 2011
jthemixer
SOURCE: john deere rx75 belt routing
Ok, took quite a bit of digging and here's what I came up with. I did a google search for "srx75 john deere riding mower 30'' deck free owners manual" and then I clicked images to the left of the screen. Scrolled down and found this pic! Here's the link below. It is the deck and all pulleys with belt on it for sale on Ebay. Got lucky!! Check it out! Your welcome Jeff Jones {bucket} Va Beach Va
http://www.ebay.com/itm/JOHN-DEERE-RX73-mower-deck-30-cut-/360457788846?pt=LH_DefaultDomain_0&hash=item53ecf55dae
Posted on Sep 17, 2012
  • 100 Answers
SOURCE: Do you know if I can put a motor off of a John Deere GX 85 onto my John Deere Sabre
as long as the lenth and diamather of the crank shaft are the same
Posted on Oct 26, 2012
What type of oil does it use? John Deere RX75
some use straight 30 some 5-30 others 10-30 jd has their own oil as well the following chart showes the type
May 12, 2016 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
Looking for a replacement part number for a magneto for a kawasaki 9 hp on a John Deere rx75
I can find it but it seems to be a bit of money, on ebay using the John Deere number MIU13323 I also searched it with the Kawasaki number 21121-2084 Coil-Ignition , wasn't any cheaper. But there was some used ones on there for half the money.Most places had it as discontinued . Just depends on which you love more , your money or your Deere.
Apr 02, 2016 | John Deere Garden
Keep burning up deck belts on 20yr old John Deere rider rx75. What size belt should I be using
1/2 x 60
Check all deck idler pulleys and make sure no bad bearings or flat spots
Apr 24, 2015 | John Deere Garden
John deere rx75 adjust belt tension
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Apr 21, 2014 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
I have a John Deere rx75. The mower deck seems to be too low when I set it at the highest position. I have no idea how to do that or to level the deck. Please help. The lawn is cutting uneven and its...
Sep 19, 2011 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John deere rx75 belt routing diagram
I found manual on amazon... so you can take a look there Amazon com john deere rx75 manual. I hope this was helpful. cheers
Jun 19, 2011 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
Looking for a manual for a John Deere RX 75
go to the John Deere web site and search for your model number. They have publications there online and some that you can buy.
Jul 14, 2009 | Garden
John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter Logo
23 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
