Question about Zenith P42W46X 42 in. Plasma EDTV
Zenith 42" plasma p42w46x
My plasma suddenly didint want to work all i see is yellow lines but i can still hear the audio but cant see anything but vertical lines
  • 3 more comments
  • gmitchell97 Nov 28, 2007
    Have audio, no picture, just colored lines.
  • Anonymous Dec 04, 2007
    Watched a Movie last night with the wife and enjoyey the TV. Turned on the TV today to catch the weather and low and behold... attack of the yellow verticle lines. I have sound but no video. Problem applies to Cable, video etc.. So it is not the input but the TV itself.
    I thought that one of the cables were loose at the conection point, I reset all connections and still get yellow lines.
    Plan on reseting the tube for a few hours but suspect the YSUS board has gone bad.
    This really is a bummer, the TV is not even 3 years old. I remember having TV's last decades, heck my Moms Curtiss Mathis TV still works and it is from the late 60's.
    For the amount of money these pull at the retail level the reliability is not good at all, I would tell anyone looking for a Plasma to get the extended warrenty.
  • rc77 Apr 15, 2008
    i have the zenith 42 in plasma and i have the same yellow lines
  • Anonymous May 26, 2008
    Same thing just happened to mine!
  • contoms Dec 14, 2008
    my zenth p42w46x is D.O.A. nothing but yellow & red lines has good sound, can i buy a board for this problem ?
    mike.. [email protected]
If you know anything about electronics, I have one with the same problem, but haven' looked at it yet. I have two that the screen flickers, found a couple bad electrolytic capacitors on the Y-SUS board. I took a good high voltage capacitor and bridged the aluminum surface mounted capacitors, one by one, and when I bridged the bad one the picture was as good as new, replaced it, no more problem. The TV doesn't have a good design, but they probably designed it so the high heat from the heat sink cooks the capacitors mounted above, just when the warranty has expired. I think I'll mount two cooling fans on the heat sinks to dissapate the heat
Posted on Dec 19, 2007
I have the three zenith plasmas, I've fixed the two that were flickering. The one with the verticle lines, I sawpped the Z-SUS and the Y-SUS from the good TV to the bad and still had the white lines. I looked at the two boards hooked together with 3 aluminum covered ribbon cables that are in the lower center of the TV with all the video inputs, on the far left there is a right angle connector that has about 20 pins, the white cable comes out and goes under to a circuit board this looks like this cable supplies the video signal to the screen. I disconnected the cable and the screen went black, all the voltages going into the video board are normal, so there must be something fried on one of the two boards, there are a LOT of electrolytic caps on those boards. I will post when I figure out whats cooked, you may have the same problem too.
Posted on Dec 26, 2007
I have just had the same problem. It affects both the component inputs but the A/V inputs are OK. If I disconnect the green input, the screen goes black and displays "No signal." Service guy came out and said the Y-board needed replacing. Haven't done this yet
Posted on Sep 05, 2007
SOURCE:
Lot of color line vertical on screen
most comun problem is the TCON-BOARD this card fix colors and sharpness on tv
Mar 04, 2014 | Zenith P42W46X 42 in. Plasma EDTV
The P42W46X is 6yrs old and has developed 1" wide
It means that the inverter cable needs to be re-seated or replaced.
Thank you for visiting FixYa! We answer your concerns promptly for FREE. Please spare a few seconds to click on YES button and leave a short comment to let other people know how I help you. Have a good one!
Aug 21, 2011 | Zenith P42W46X 42 in. Plasma EDTV
My Zenith P42W46X 42 inch tv got two black lines vertical lines on the screen the were coming and going away before but they are more stable now.i opened it up and wiggled all the connections arround the...
There are 4 or 5 ribbon cables on the bottom or on one side, they control part of the plasma screen. Check the ribbon cable near the black lines. Unplug the ribbon cable and look for black chips on the underside of it, I think they say 100 on them, you need to resolder both ends on each chip. Should fix the black line issue.
Oct 08, 2009 | Zenith P42W46X 42 in. Plasma EDTV
I have a 50" zenith 10 months i can hear how can i fix this
If the unit is only 10 months old, it should still be under manufacturer's warranty. Call and request warranty service. DO NOT open up the unit as that would void the warranty.
Keep us posted on what is found.
Thanks,
Dan
Aug 20, 2008 | Zenith P42W46X 42 in. Plasma EDTV
Zenith P42W46X 42 inch EDTV
common problems with these, usually customers here a loud pop. then the screen goes blank. I would try...
Some of these have a 4 pin test on the control board that you can jump with solder to get test pattern. If you get it to do that then these boards maybe good and would replace the control board. if nothing happens, then
the upper & lower drive also the Ysus and Zsus boards all at the same time.
last could be a defective panel.
hope this helps. p/n are on all the boards.
Jul 22, 2008 | Zenith P42W46X 42 in. Plasma EDTV
Plasma Screen not working only sound
It might be one of the power supplies. There are three in this model. One for the sound, one for the video, and one for the computer components. The video power supply is probably shot. They cost about $200 a peice from LG. If there was a "pop" sound when the video stoped, then it might be one of the circuit boards in the back. Yet again, they are three, each costing around $200 from LG.
Dec 26, 2007 | Zenith P42W46X 42 in. Plasma EDTV
P42W46X Zenith Plasma - No Picture - Mostly Yellow on screen
Mine looks like too, but the line running across isn't on my set, picture looks like this, and the sound works fine. I took the tuner board all the way out and turned the set on and it did the same thing, then I unplugged the top wire on the board next to the tuner board and the screen went black. plugged it back in and the screen came back with the scrambled picture. Anyone know why? Bad mainboard maybe? the left of the tuner board?
Nov 25, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Zenith P42W46X 42 in. Plasma EDTV Logo
434 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
