Question about Intel D915GLVG Motherboard
Labeled diagram the board is dead no power in pci slot only led lit near power connector
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Intel Master
  • 2,226 Answers
Then get a new one
Posted on May 21, 2014
5 Suggested Answers
compdoctor20
  • 172 Answers
SOURCE: dead graphics on Intel D945PAW
This is your motherboard, and the archecture will take a standard pcie graphics card. The best to go for at a medium price are the Nvidia GEForce 5*** range ot the Radeon 9*** range. These are available at between £25- £55 gbp
more help or info ? compdoctor2005@btinternet.com
http://support.intel.com/support/motherboards/desktop/d945paw/sb/CS-020713.htm
Posted on Dec 13, 2008
Wraiith303
  • 39 Answers
SOURCE: ON BOARD LAN & PCI SLOTS ARE NOT WORKING
Was the board recently struck by lightning? I've had several problems where lightning struck the motherboard through the lan ports, while not destroying the board itself, but just the lan port, and usually not showing up in device manager gives it away.
You will have to replace the motherboard if this is the case
Posted on Dec 30, 2008
  • 13433 Answers
SOURCE: Configuration
Hi
The wires that read +5 -d +d and ground those are USB connectors each usb connector will have 4 wires, +5 -d +d and ground so that goes to usb pins.
The sw must be power switch
The HDD led is the load light
Reset is the reset button
Power led is the front power light
SPK is the speaker / beeper.
Can you tell me the brand and model of the motherboard? They are documented in the user manual. but generally in the bottom right corner of the motherboard you have the connectors for the leds and buttons, its all written into the motherboard with small white text. but I can get clear instructions from the user manual for you.
You can look for the motherboard details between the expansion slots and between the cpu and memory.
Thanks,
Ekse
Posted on Feb 03, 2009
  • 208 Answers
SOURCE: Does this board have a PCI express 2.0 slot?
No, you have PCIe 1.X
Posted on Oct 02, 2009
Not booting
its just a power indicator.
Apr 29, 2008 | Albatron PX865PE Pro Motherboard
Labeled diagram
get a new board then
Aug 02, 2013 | Intel D915GLVG Motherboard
Diagram of xps 630i motherboard connections
xps 630i motherboard layout
1 - unused fan connector
2 - power button (POWER_BTN)
3- front LED
4 - front panel USB connector (FP_USB)
5 - floppy drive (DSKT)
6 - master I/O board USB connector (MIO_USB)
7 - front panel IEEE connector (FP_1394)
8 - reset button (RESET_BUTTON)
9 - RTC reset jumper (CLEAR_ CMOS)
10 - password jumper (CLEAR_PASSWORD)
11 - internal S/PDIF connector (internal SPDIF)
12 - front panel audio (FP_AUDIO)
13 - PCI card slot (SLOT5 and SLOT6)
14 - PCI-Express x16 card slot (SECONDARY GFX SLOT4)
15 - PCI-Express x8 card slot (SLOT3)
16 - PCI-Express x1 card slot (SLOT2)
NOTE: This slot is not available in the dual-graphics configuration
17 - PCI-Express x16 card slot (PRIMARY_GFX_SLOT1)
18 - power connector (12V_ATXP)
19 - processor (CPU)
20 - processor fan connector (FAN_CPU)
21 - black memory module connectors (DIMM2 and DIMM 3)
22 - white memory module connectors (DIMM0 and DIMM1)
23 - main power connector (POWER)
24 - IDE drive connector (IDE)
25 - North bridge fan connector
26 - SATA connectors (SATA0-3)
27 - battery socket (BATTERY)
Dec 06, 2011 | Computers & Internet
My packard bell imedia 3064 computer uses an nec ms-6786 board. does this support AGP or PCI Express for graphics card?
Open the case, and inspect the motherboard.
You should see a few PCI slots (usually WHITE-coloured)
that are identical in shape and location.
You might see one more slot that is offset from the location of the PCI slots, but about the same length of slot.
This will either be an AGP slot, or a PCI-Express slot.
Look at the silk-screened labels near the slot;
it should identify the slot as AGP or PCI-Express.
Aug 25, 2010 | NEC Computers & Internet
Pulled power and led cables off and do not know where they go
If you are lucky the connectors from the front panel may have labels on each connector to indicate what each connector is for.
The motherboard front panel connector pins should also be labelled too.
If not then go to the MSI WEB site to download a motherboard diagram for your model motherboard.
Oct 19, 2009 | MSI : 7125-040 (K8N NEO4-F) Socket...
How to connect power led & reset ledin mother board
firstly u find 9pin jack on motherboard its near about pci slot and their is print power switch,power led and reset switch. some wires are  comnig from your cabinet their is print po sw,reset,hdd,pwd led
Sep 19, 2009 | Advantech 700 Series Intel Pentium ...
Configuration
Hi
Thanks,
Ekse
Feb 03, 2009 | Intel SVM266A VIAP4M266A (SYNTAX SVM266A...
Case connector problem
we would need to know the motherboard you have. most i've worked on have a 7 or 8 pin connector near the bottom of the motherboard.... next to the pci slots. if that front devices uses a modular plug it usually has a blank pin slot so you cannot hook it up to say a usb port.
Get out your magnafying glass and a light... the connectors are often labeled right on the board.
Robert
Please rate this solution.. thanks
Sep 08, 2008 | ASUS A8V Motherboard
Labeled Technical drawing of where the power switch, reset switch, power led, HDD led etc. connectors go on my comp
Most motherboards have near where the pins the wires go what goes where and the wires from case switches have writing on them as well give it a try
Jul 30, 2008 | Computers & Internet
Intel D915GLVG Motherboard Logo
21 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
