Question about Garden
Jcb acr 360
How 2 lower the blade
Where can I buy a JCB mower blade?
http://www.oregonproducts.com/pro/lookups/selguide_bladelookup.aspx
Mar 30, 2015 | Garden
I have a jcb garden shredder ,after using machine ileft it for acouple of days and it would not go again
Did you look at blade assembly? UNPLUG power cord and then using a flat bladed screwdriver push the blades to see if they will rotate. If they don't look for jam or if twine/string got wrapped around assembly...also spray the blade assembly at both sides with spray lube like wd40...if it is free and you've made sure power and reset button is set, then the problem may be the motor itself. Since they no longer make or have parts, you may be done with this tool. It was never a big seller or performance as a shredder.
Jan 03, 2015 | Shredder Office Equipment & Supplies
1 acres =
One acre is about 4047 square meters or about 43,560 square feet.
Feb 20, 2014 | EnGenius FREESTYL1 Slim Design Long Range...
Jcb mitre saw
try ringing jcb on 01889590312 and they will put you in touch with a distributor that has the part.
Jul 28, 2013 | Ryobi Saws
How to stop trimmer line spool from spinning off
I bought a Shakespeare Push-n-Load 3 blade trimmer head at The Home Depot for about 26 dollars and picked up a pack of 12 replacement blades for another 7. Did a whole 3 acres worth of weed whacking and still didn't need to change the blades. I was also powering through some pretty thick bushes with ease. Highly recommended.
Apr 13, 2013 | Craftsman 25cc Gas Line Trimmer
Jcb trimmer ph24 runs well but with bigger branches say 3/8inches blade stops
How sharp are the blades? There is a good video on sharpening blades on youtube by ereplacementparts. He shows you how to do it with a file and with a grinder.
Aug 10, 2011 | Garden
New mower hit small stump, cuts too low now/ can't adjust height
It is a bend blade. I feel your pain...I had a riding lawnmover that took a good two-hours to take apart and chage blades and 3/4 of an acre with old ornamental garden root balls popping up all the time. That was a long summer...
You may want to get the blade ahead of time so whomever can help you look under the mower can change the blade once they confirm it is bent. Even if they can fix the old one it is a blade you will need sooner or later and they are not very expensive.
Dec 17, 2009 | Garden
JCB LS45 lawnmower - 2 stroke or unleaded petrol??
JCB LS45 specs Manufacturer: JCB
Blade Length in cm: 42 cm
Blade Width in cm: 40 - 44 cm
Cutting Width in cm: 42 cm
Electric Start: with Electric Start
Grass Collection Bin: Back
Horse Power: 3.5 hp
Mowing System: Rotary
Power Supply: Petrol 2 Stroke
Type: Walk behind mower
Apr 04, 2009 | Garden
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
