Back to:
Tags:
Uniden Cordless Phone
Out of range (by 20 users)
posted by jojo3434 on Sep 01, 2007
I have 2 uniden phones. When you push talk on either one it says out of range. I have tried hanging them up in the base. I have also unplugged the batteries and let them sit for a while. After connecting them back up they still say out of range.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
19 Other Users Have The Same Problem
Comment by Guest, posted on Oct 27, 2008
i have the exact same problem it keeps flashing charging and says out of range then when i pick it up it says searching than just turns off.
Comment by jackieyudico, posted on Oct 24, 2008
this phone does not let me answer or do anything with it. it just say's out of range...
but my other hand set works...how can i get out of out of range... i need both hand set's for my business.
Comment by azzat, posted on Oct 20, 2008
model tru94804802e0406w out of range
Comment by Guest, posted on Sep 08, 2008
i have Uniden phone every time i push talk it says out of range, can someone tell me how i can fix it?
Comment by frednsandyt, posted on Jul 05, 2008
i have removed the batteries.still out of range on all 3 handsets.i have deregistered the 3 handsets per uniden website.told to register them again.tried to but came back as register failed..
Best Solution
posted on Jun 15, 2008
FixYa! (100)
esilva
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
You should do the Deregistration and then do the Registration again
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on out of range:
I don't want to Accept this solution
Solution #2
posted on Sep 20, 2007
FixYa! (100)
Guest
Rating: 0%, 0 votes
Go to Menu then select System Reset, then selct Replacing base, then answer Yes. This will advise you to place in base to register and it will do so in about 5 seconds.
Thank You!
Solution #3
posted on Oct 21, 2007
FixYa! (100)
Guest
Rating: 0%, 0 votes
you need to deregister both handsets.  press end button (red) and # at the same time for about 5-6 seconds.  pick "base unavailable" and then deregister.  put back on base until it reregisters.  repeat with other handset.    JUST A GURL
Thank You!
Solution #4
posted on May 03, 2008
FixYa! (100)
vkd1
Rating: 94%, 5 votes
My phone was brand new out of the box and had the "out of range" error on both handsets. I read thru these suggestions and began by choosing "System Reset" as instructed. This did not work on its own so I tried to "deregister" the handsets. This didn't work either!!!
Out of frustration I took the batteries out of the handsets and once I replaced the batteries and put the handset back in the cradle, everything reset itself and they are all working fine now.
PHEW!!
Thank You!
Solution #5
posted on Apr 15, 2008
Helpful (85)
PDLeichty
Rating: 88%, 6 votes
I called the Uniden support, and although it took awhile, the customer service representative was able to get all three of my phone sets registering again with the base.
Thank You!
Solution #6
posted on Sep 01, 2007
Helpful (85)
skipper360
Rank:Wiz Wiz
Rating: 77%, 85 votes
You have to put the both unit on the BASE for 10 sec. to sync.
Thank You!
Solution #7
posted on Oct 28, 2008
Not Rated (0)
worldkarate
Rating: 0%, 0 votes
my phones say out of range and nothing i do will fix it
Thank You!
Solution #8
posted on Dec 15, 2007
Not Rated (0)
LINKMOSAIC
Rating: 0%, 0 votes
THANK YOU IT WORKED>>>
Thank You!
Can you Help with these Phones problems?
???¹???¯ ?§???§???µ?§??...
How do I switch listening from my handset to the base...
Does this mean that I need new batteries or what? Where to...
model # tcx905 uniden. When I talk on the phone I can...
Grandson pressed buttons on 2nd uniden cordless phone and...
19 Other Users Have The Same Problem - Continued
Comment by dieterdgn, posted on Jun 10, 2008
same problem
Comment by Guest, posted on May 09, 2008
replaced phone on charger
Comment by Guest, posted on Apr 19, 2008
out of range on my phone i tried everythings too, i dont know what to do? i need help please
Comment by ashsha, posted on Apr 12, 2008
I have a same problem , my phone is showing out of range everytime.
Comment by Guest, posted on Apr 07, 2008
cordless is fully charged and receive error message out of range
Comment by krisser, posted on Mar 29, 2008
I have 4 uniden phones 2 out of the 4 phones work and the other 2 phones when the talk butten is pushed there is no dial tone.
Comment by Guest, posted on Mar 26, 2008
My Uniden phones worked ok for about 1 month. Now all three in the set say "Out of Range". Nothing I've tried has worked. Maybe the base unit transceiver is fried.
Comment by tgrue, posted on Mar 22, 2008
Same issue showing out of range on the first handset
Comment by Guest, posted on Mar 03, 2008
message shows 'out of range'. i've hung up, unplugged the adapter & it still shows the message.
Comment by papermum, posted on Feb 26, 2008
My phones all say out of range! i have tried deregistering them and reseting them with the main base but they are still not working. I bought the original base with 2 handsets about a year ago and just added another handset recently, before it all stopped working. Very disapointed.
Comment by LizaS, posted on Jan 03, 2008
i have 2 handsets that are connected to a computer splitter and have been so for about 18 months and working fine. now i have no dial tone and one handset will say out of range every now and again. I can get a dial tone if i disconnect from the splitter and move it to another location but then my computer doesn't work....HELP.
Comment by cherokee_psh, posted on Dec 23, 2007
Same issue. We have only had the phones 2 years! For the price you would think they would last longer! Will not buy this brand again!
Comment by Guest, posted on Dec 11, 2007
two phones read out of range. will not turn on to use.
Comment by yalda, posted on Nov 28, 2007
my two phones display out of range .i tried registering them still not working.what is the solution.
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
