Question about ViewSonic VPW505 50 in. HD-Ready Plasma Television
VIEWSONIC VPW505 Screen flickering
Just bought this TV used. the screen flashes and flickes and it is mainly visible on light portions of the picture. Its a steady flicker around 2 times per second. Is this TV worn out? Is this a common problem? Is there a simple fix?
  • Anonymous Dec 28, 2008
    Yep, same thing here. Began as follows: Problem presented only when display was first turned on...that is Cold. As it warmed up, problem went away gradually. Now, problem is constant. Believe it to be the LG control board 50WX1DP_CTRL which essentially decodes the video and then drives all the X-Y boards.
Got it. I was the 'guest' who posted that I had the same problem. Not the CTRL board as I earlier thought. It boils down to the Y-SUS board (right hand side as you face the back of the display) In the upper-upper left hand quadrant you'll find a small capacitor labelled "C70".
This is the naughty one.
You can verify this by removing the back of the display, powering up and then with a small extended flame lighter, GENTLY warming C70. All it takes is about 2 to 3 seconds and the display will steady up just like always.
C70 is a surface mount capacitor, most likely 33uf at 25 volts. Haven't confirmed this yet. Will post again when I've affected the repair on my VPW505.................
BTW: This is not something you want to attempt unless you have experience with electronics. No.....really!
Posted on Dec 30, 2008
  • sparks513 Dec 30, 2008
    After removing and replacing capacitors, it works out to be (for mine at least) C78, which is right above (physically) C70.
    C78 is still (and this is confirmed, just like for C70) a 33 uf 25 volt capacitor. The polarization will be obvious from the markings on the circuit board.
    Again: If you have some skill working with electronics, please do so. If not, then please don't attempt any of this. It could be fatal to you.
Does Not Stay On
When you insert the card and get the CHA Flashing error, remove the card and format it. Reinsert it again.
Should work.
Oct 16, 2007 | ViewSonic VPW505 50 in. HD-Ready Plasma...
LED TV pulsing
How many have 'blinking' issue with Samsung led tv - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJan 26, 2011 - I am trying to get the number of people affected by this nagging blinkingissue with the latest Samsung led tv's. If possible it would be useful to ... Samsung LCD TV Screen flickering (LN55C630K1F)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung LED with flashing standby light on front
Apr 17, 2014
More results from www.cnet.com
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical ...
Jan 18, 2016 | LG Televison & Video
I have this model N3735w Viewsonic LCD flatscreen TV and it is flickering. The screen is also getting darker.
Try turning off the automatic brightness feature . This mode adjusts the brightness according to the light level in the room.
Dec 26, 2013 | ViewSonic N3735W 37 in. LCD TV
Tv powers on, see three birds in color then flickers and fades to white
The problem must be with its main digital processor board. It will be best to make it confirm. Contact any service technician. Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 20, 2013 | ViewSonic N1930W 19 in. LCD TV
Dim and flicking last black screen
It sounds like your monitor went bad. It happens. Call around. There are a lot of deals now. Good luck.
Aug 04, 2009 | ViewSonic VX1940w LCD Monitor
Wont turn on C-160, flicking screen
Dear emjay187,
i have the same camera and experiencing the same problem, it doesn't matter what batteries i put in (fully charged rechargables or dry cell AA) the low battery icon flashes then the screen flickers and goes off. i suspect it to be another onboard battery so i have found a small button 3v battery soldered to the main board. i have desoldered it and am now sourcing one so when i find it and try it i will contact you to confirm my results.
regards
Michael.
Nov 20, 2008 | Olympus Camedia C-160 Digital Camera
Screen flicker when watching 1080i
Component video has a max resolution of 720p. in order to use 1080i or p you have to use hdmi or dvi connections. That is why you get the flicker.
Dec 08, 2007 | Onkyo TX-SR304 Receiver
Screen flicker/jumping
first check loseconection and tube light and nearaset spk for sparking .and check the earth of monitor main waire
Nov 18, 2007 | ViewSonic GA771 Monitor
ViewSonic VPW505 50 in. HD-Ready Plasma Television Logo
373 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
